Old 07-21-2014, 01:25 PM   #1
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Alignmemt w/ Crash Bolts. Thoughts?
Car had some interesting toe stock. Might that explain wearing the stock tires in 11k miles? Anyway, -1.2 makes me happy.
Old 07-21-2014, 01:30 PM   #2
CSG David
CSG David's Avatar
Yes. You need to get an alignment after getting the crash bolts installed. Toe is what affects tire wear the most.
The Following User Says Thank You to CSG David For This Useful Post:
EAGLE5 (07-21-2014)
Old 07-21-2014, 01:59 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
For some reason, the photo didn't come through on the original post. Fixed now.
Before shows before crash bolts, stock and only ever aligned at the factory. After is after crash bolts.
Should I be worried about the remaining .01 on toe?
Old 07-21-2014, 02:06 PM   #4
CSG David
CSG David's Avatar
0.01" is within error. You'll be fine...better than your previous setting.
EAGLE5 (07-21-2014)
OEM crash bolts and alignment question Ocean-Grown 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 07-07-2014 10:27 AM
Crash bolts alignment change ABQautoxer Tracking / Autocross / HPDE / Drifting 39 03-24-2014 05:45 PM
Cheapest Crash bolts FReSh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 08-14-2013 11:12 AM
FS: OEM Subaru crash bolts (2) ayau Brakes, Suspension, Chassis 0 12-27-2012 11:29 PM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
