Drives: 14 WRB BRZ Limited
Positive Camber In Front After Coilover Install
This is my first coilover set up so I am clueless when it comes to lowering cars but I believe negative camber occurs when lowering the car. Sorry if this is a very noob question but couldn't find any posts regarding positive camber from coilover installation which had me further concerned.
I had ST coilovers, RPF1 18x9.5 +38, and 255/35/18 tires installed today and noticed the front wheels poking out with positive camber. Planning on getting an alignment next week but I just want to make sure an alignment will correct this issue and not caused by an installation issue. I can take pictures of different angles if necessary. ![]()
#2 |
Lowering the FRS/BRZ adds negative camber in the rear, but not in the front.
It's hard to tell from the pictures but it looks like you have 0* camber on the front if anything. Do the ST coilovers have slotted front struts? |
#3 | |
No idea if the coilovers have slotted front struts though.. |
#4 |
ST's are slotted up front, loosen the bolts and push the top of the knuckle in as far as you can before you tighten them back up.
| The Following User Says Thank You to wparsons For This Useful Post: | bkstarx1 (07-18-2014) |
#5 |
Drives: WRB LMTD '13
ST coils front struts do have slotted on the top bolts.
Get 16mm camber bolts SPC 80260 if I still remember. Push it in and lock it up and be happy.
| The Following User Says Thank You to hanabie For This Useful Post: | bkstarx1 (07-18-2014) |
#6 |
Will the above just resolve the positive camber? I am more concerned about how much the wheels poke out. I do know that I have fairly wide wheels but pictures of similar setups shows no wheel poke.
#7 |
It will solve the camber, and will make the top poke less WRT the fender, but wheels that wide and that offset will always poke some.
| The Following User Says Thank You to jvincent For This Useful Post: | bkstarx1 (07-19-2014) |
#8 |
It will solve. I have the same setup 18x9.5 +38. Just go with max neg cambers.
| The Following User Says Thank You to hanabie For This Useful Post: | bkstarx1 (07-19-2014) |
#9 |
Before I attempt to loosen the bolts, it's the 12mm bolts and not the 19mm bolts correct? Just loosen it up, push the coilover in and tighten?
#10 |
Ultimate Member
Drives: 2014 Satin White BRZ
Hope this helps |
| The Following User Says Thank You to limitedblkwrx For This Useful Post: | bkstarx1 (07-19-2014) |
#11 |
9.5 +38 is the reason for the poke, camber will make the tops poke less, but the center of the wheel will always maintain its current poke (and the camber will make the bottom half of the wheel poke more actually)
| The Following 2 Users Say Thank You to jshadeck For This Useful Post: | bkstarx1 (07-19-2014), limitedblkwrx (07-19-2014) |
#12 |
| The Following User Says Thank You to jshadeck For This Useful Post: | bkstarx1 (07-19-2014) |
#13 |
Thanks for everyone's help. Finally got a hold of a breaker bar and torque wrench and was able to push the knuckle back before tightening it and solved the poke and the positive camber
| DIY__twincamRob's 5min Whiteline Positive Shift bushing install | twincamRob | DIY (Do-It-Yourself) Guides | 30 | 06-30-2017 10:27 AM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Help! KW V3 install positive camber... | jx86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-29-2013 11:57 AM |
| Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
