Old 07-19-2014, 01:29 AM   #365
Pete156
I like to eat!
Originally Posted by blackfireball5 View Post
I have my oil cooler mounted in the passenger fog light area. I just picked up one of these. Gonna mount it to the fender liner as an exhaust vent.
MFG and Part number please?
Pete156 is offline   Reply With Quote
Old 07-19-2014, 02:11 AM   #366
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I got the 4 inch black model. (easy on the jokes... :p)
http://www.go2marine.com/product/271...lange-abs.html
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 07-19-2014, 02:30 AM   #367
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by Dephective View Post
^ Don't quote me, but i've been hearing they've been having issues with the Robispec combo. I've seen a few posts about it now. I would love one though if I could afford it (and it worked, course.)
Really? Only issues I heard were with fitting front mount turbos.
Old 07-19-2014, 03:13 AM   #368
BadBRZ
Drives: Subaru
I have the robispec cooler, its pretty damn good so far, i don't track my car but i live in houston texas with 100%humidity and triple digit heats... Highest oil temp i've seen is 235 and highest coolant was 215. Normally stays right about 197 coolant 200ish flr the oil..
I've heard issues of people using straight water with a wetter i stead of coolant in the radiator and the wetter water combo ate the welds :-/
I'm running factor coolant and its great so far.
BadBRZ is offline   Reply With Quote
Old 07-19-2014, 04:44 AM   #369
sw20kosh
Drives: 2013 Black FR-S
I talked to Robi himself as my robispec rad is toast too. Core is leaking bad. He says there have been a few that have started leaking. He says it is probably from a bad ground causing current in the coolant or something = electrolysis. I have only used Subaru super blue coolant in mine.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Dephective (07-19-2014), JDKane527 (12-04-2014)
Old 07-19-2014, 08:30 AM   #370
Dephective
Drives: '13 Whiteout FRS
That would be plausible assuming the faulty ground happened after you swapped the cores out. Otherwise the same thing would have happened to the factory one.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 07-19-2014, 08:44 AM   #371
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
@blackfireball5 Nice vent You'll have to trim the back of those. I started fitting the dual 3" vents and the rear shroud will hit your cooler
I have the FBM cooler behind my passenger fog light and have started along the path of an exhaust vent for it.
This is the first version of my fender liner exhaust vent. (it doesn't look ghetto in person). For anyone that is curious, fender liners are cheap as hell so trial and error won't cost a fortune.
It made a noticeable difference at the track. It took longer to heat up and the max heat was about 10-20f lower (maxing out at 260ish). The temp also drops about 30F on the cool down lap where as it would barely move before. I'm guessing that was due to heat soak. In the city, I find that temps are lower overall unless I'm stuck in traffic. If there is no air-flow you may as not even have an oil cooler. I'm thinking of installing a switch operated fan onto the oil cooler to help with this.
I would HIGHLY recommend putting in an exhaust vent to anyone that's running the cooler behind the passenger fog light.
Does anyone have that Japanese oil cooler that goes into the undertray under the rad?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 5 Users Say Thank You to protpibe For This Useful Post:
blackfireball5 (07-19-2014), BRZPDX (07-19-2014), charged86 (07-19-2014), Dinko (07-19-2014), glorydays (07-23-2014)
Old 07-19-2014, 02:31 PM   #372
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
that vent looks awesome. That is where my oil cooler is at currently as well (driver side, took out the washer bottle, cuz racecar!).
Just ordered the VIS AMS hood, lets see if that will be a quick fix to the coolant temp issue. Next step will be moving the rad to the front a bit, make a hole in the front bumper for more air flow.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-19-2014, 03:43 PM   #373
protpibe
protpibe's Avatar
Thanks. For the next one, I'm going to have 2 3" louvered vents side by side. I really want to install a fan as well, but that will probably be a project when it's stored for winter.
Has anyone had success in reducing temps overall with the Seibon vented hood?
Old 07-19-2014, 08:22 PM   #374
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
im building a mock up setup tonight for a oil cooler location similar to the jdl picture I posted above. Im going to force air up to it.
My mock up will be from acrylic since I don't have a way to form and shape aluminum at my current location(sad face)
Old 07-19-2014, 08:59 PM   #375
mike the snake
I'm very interested in what you think of the VIS AMS hood. I'm planning on getting the same hood in the future.
Old 07-20-2014, 12:20 AM   #376
BRZPDX
Boosted Member
BRZPDX's Avatar
I was going back and forth with Seibon and this, but looks like the vents are much bigger which helps for traffic/slow moving heat venting. once I get going on highway speed, I don't have heat issues.
Also living in the PNW, rain guards are pretty important to me. I'll probably switch out to the OEM hood during the winter.
I need to paint match it too. the joys of having SWP.. lol not.
Old 07-20-2014, 11:37 AM   #377
mike the snake
If I'm not mistaken, the VIS AMS hood has rain guards.
Old 07-20-2014, 10:01 PM   #378
Synack
Boosted
Synack's Avatar
Drives: Sideways
I think I'm going to stick mine on top of the intercooler like the picture you posted earlier.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
