Old 07-17-2014, 11:13 AM   #99
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by DAEMANO View Post
THX @Robftss !
Install time, 1 hr. going very very VERY slowly and dressing cables.
With 1.5 dump the thing recharges from 23v to 28v in a flash!
How much are the aux chargers? Did I miss the official release?
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 07-17-2014, 11:50 AM   #100
DAEMANO
Time Traveller
Just PM Rob.
Old 07-17-2014, 12:11 PM   #101
Thatruth2001
Drives: Raven FR-S
Rob has not established a price. The Aux Charger is still beta and has been modified to support the 1.5 dump pack. The current unit is the 3rd design version. I have run the previous 2 versions. Hopefully I should receive my repaired unit next week.
After running the 1.5 pack now for a week plus, I recommend everyone running this setup purchases the aux booster. Though the main controller and charger can get the job done, the recharge and ability to put the unit into safety mode is way easier than before when running the 1.0 setup with Aux booster. I believe once the the aux changer is added, the entire setup will be perfect.
Hopefully, I can convenience Rob to play around with the pedal engagement mechanism next......
Thatruth2001 is offline   Reply With Quote
The Following 5 Users Say Thank You to Thatruth2001 For This Useful Post:
DAEMANO (07-18-2014), Gums (07-17-2014), nlowell (07-18-2014), raven1231 (07-17-2014), robwbright (07-17-2014)
Old 07-17-2014, 09:18 PM   #102
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
THX @Robftss !
Looks like I get mine tomorrow. I will be doing an install video for everyone.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
MagicBobert (07-18-2014)
Old 07-18-2014, 01:45 AM   #103
WRB5titch
Drives: WRBrz
I ran into an issue with mounting the aux box per instructions....the HID housing on the BRZ appears to be much larger than the FRS...the heat sink fan is sitting on the housing and isn't flush with the frame of the car...(Red Circle)
it's a bad cellphone picture but best I can do at the moment...
@DAEMANO and I are thinking of going to Lowes/Home Depot to find some sort of bracket to mount the box lower, towards the front of the car. (Green Arrow)
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following 2 Users Say Thank You to WRB5titch For This Useful Post:
DAEMANO (07-18-2014), Sojhinn (07-18-2014)
Old 07-18-2014, 10:42 AM   #104
Robftss
Drives: VW
OK, I can move the slotted bracket to the other side and make it universal.
Thanks!
Robftss is offline   Reply With Quote
The Following 5 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (07-18-2014), Gums (07-19-2014), s2d4 (07-18-2014), Sojhinn (07-18-2014), WRB5titch (07-18-2014)
Old 07-18-2014, 12:01 PM   #105
Sojhinn
Sojhinn's Avatar
I'm going to have that issue too. Thanks for the heads up. If you guys figure out anything can you post it?
Installed Mods:
Old 07-18-2014, 12:39 PM   #106
WRB5titch
Drives: WRBrz
Thanks!
Funny I was thinking the same thing last night...if only the bracket was on the other side..
Is this something we can do ourselves? It looks simple enough...I'm not too sure what to use to mount the bracket on the other side though. Maybe there's more to it than that.
Will do!
Old 07-18-2014, 01:04 PM   #107
shif7i7down
Erected Member
Drives: frs
Will do!
It looks like the bracket is just held in place by two screws. Not sure if removing the screws and flipping the bracket yourself would be considered tampering but it looks easy enough
shif7i7down is offline   Reply With Quote
Old 07-18-2014, 01:41 PM   #108
DAEMANO
Time Traveller
I'd be very cautious about putting screws into the side of a box full of electronics that I couldn't see the inside of first.
The Following User Says Thank You to DAEMANO For This Useful Post:
DC2R (07-19-2014)
Old 07-18-2014, 03:33 PM   #109
shif7i7down
Erected Member
Drives: frs
What i was saying i that there's already screws there. The bracket is held on by two screws -_-.
No drilling required......
Old 07-18-2014, 03:38 PM   #110
DAEMANO
Time Traveller
Just making sure I am imagining properly what you're proposing. So to clarify, you're suggesting rotating the bracket 180 degrees so it effectively lowers the position of the top of the fan and hopefully then clearing the HID?
Old 07-18-2014, 03:47 PM   #111
Robftss
Drives: VW
Will do!
Solved.
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (07-18-2014), WRB5titch (07-18-2014)
Old 07-18-2014, 04:40 PM   #112
WRB5titch
Drives: WRBrz
@Robftss
As usual, AWESOME customer service!
The Following User Says Thank You to WRB5titch For This Useful Post:
Robftss (07-18-2014)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 04:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 10:51 AM
