#15 |
Drives: 2013 MT Asphalt FRS
Thanks for the knowledgeable information guys, was going to pull the trigger on these lights along with blinker and trunk lights.
#16 | |
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | Rio (08-17-2014) |
#17 | |
Drives: 2013 asphalt scion FRS
but...you did recommend led replacements for my high beam location.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#18 | |
Nick C.
#19 | |
I understand that. but you just said..."for either low or high beam". so, should I not order them for my high beam? or do you recommend them for high beam replacements...
#20 | |
Drives: 2013 FRS
People don't understand (nor do most of the designers of these things), you can not just stick a giant powerful LED into a housing and call it a headlight. The housings are designed for the emission pattern from a precisely located halogen coil filament, not a big honking LED. The radiation pattern from a good HID bulbs is MUCH MUCH closer to that of a halogen filament compared to any of these supposed LED headlights on the market. I am in the process of designing a PROPER LED headlight system, and me deeming such a task as difficult is an understatement. Not only the optics challenge, but the thermal issue is another major hurdle. These places clamming 2000+ lumens from their LED headlights are on crack. They will not last. Even so, most of them have temperature dependent current settings where they are running at lower power as they heat up. You might get 2000lm for the first 60 seconds of operation. |
| The Following User Says Thank You to Enlight For This Useful Post: | BabaYaga (01-29-2015) |
#21 | |
Maybe they were referring to using LED's for your DRLs? Since they are in the same part of the headlight.
#22 |
Every single sponsor/vendor on the site says NO LED IN HEADLIGHT. How could you possibly have any doubt?
| The Following User Says Thank You to STS-V For This Useful Post: | BabaYaga (01-29-2015) |
#23 |
Drives: 2013 FRS
We should specifically low beam headlights. They are not suitable for low beam use. However, they are more suitable for high beam function only. This is because for high beam, the housing and un-capped stock halogen really does send light everywhere, well above a low beam cutoff. The optics still suck, but since high beams have a much less-defined and focused beam pattern, the effect is not as significant.
But for the FRS, the DRL and high beam are the same bulb, so with one of these "led headlight" systems, your DRLs would be way too bright for regular use and you would be blinding people all the time. I have not seen any 9005 LEDs that have dual brightness states. Low power for DRL and high power for high beam is needed for proper function. Last edited by Enlight; 07-17-2014 at 09:09 PM. |
#24 | ||
Drives: 2015 Series.Blue
Fog lights don't project light far enough to be of any use over 30mph, so it's NOT safe. Quote:
Well, they could be a bit biased... |
#25 |
Drives: The silvertrooper 10 series
You want LED headlights.. you need to get headlights that are designed to be.. well LED headlights.. Few sets are out there.. but the goal is to be Retrofitting these into a FRS housing in the future...
![]() going to be alot of work to make it look good.. but i love the looks of the light, DRL feature and out put is pretty good.. as good as my retrofit i have now? im not sure.. but no one else will have these lights lol Thomas |
#26 | ||
From the description in our DRL LED product listing: Quote:
Thanks, Paul
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | 86SPEED (07-18-2014) |
#27 | |
Biased towards not selling another product and increasing our sales? Anyone who is selling them would probably be biased...
#28 |
Drives: 2013 FRS
Indeed none of these systems will pass compliance testing.
Last I checked, the latest regulations say you can't legally have any light source in a housing that does not match the type of light source the housing it was designed for. For example, you cannot put an HID bulb into a filament type housing. Or even a filament bulb into a HID housing. Thus making all non- native conversions illegal for road use regardless whether it's LED or HID. OEM retrofit is the only proper solution. |
| FS: OEM Headlight and DRL Bulbs | boredom.is.me | Exterior Parts (Aero, Lighting, Etc.) | 0 | 04-30-2013 07:18 PM |
| 22w LED high power headlight bulbs | BrewCity-FR-S | Exterior Parts (Aero, Lighting, Etc.) | 2 | 04-10-2013 05:30 PM |
| AutomationLED LED Headlight Bulbs Review | Squishy86 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 03-31-2013 12:40 PM |
| AutomationLED LED Headlight Bulbs Review | Squishy86 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-18-2013 06:44 PM |
| FR-S headlight bulbs? | takethat | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 09-14-2012 03:11 PM |
