Sam Strano
Old 07-11-2014, 10:26 AM   #1289
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by Kido1986 View Post
Is there anything in this world MORE innuendo-laden than working on a car?
teenagers conversing at the local mall food court?
Old 07-17-2014, 02:53 PM   #1290
SeanRTR
C-Street AutoX
SeanRTR's Avatar
FYI, full size Koni front dampers (not inserts) are now available.
Part #'s
8741-1560LSPORT
8741-1560RSPORT
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
The Following User Says Thank You to SeanRTR For This Useful Post:
stevo874 (07-17-2014)
Old 07-17-2014, 03:06 PM   #1291
automatic
Drives: WRB BRZ
Pars
8741-1560LSPORT
8741-1560RSPORT
Booo, I just got my inserts last month
automatic is offline   Reply With Quote
Old 07-17-2014, 03:14 PM   #1292
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Pars
8741-1560LSPORT
8741-1560RSPORT
And the best price I've found so far is from tirerack due to free shipping.
G_Ride is offline   Reply With Quote
Old 07-17-2014, 03:41 PM   #1293
Jawnathin
Drives: Toyobaru FRZ
For anyone with a BRZ with the front 22mm Strano sway bar with Konis, what do you think about the setup? Do you find it pushy, and if so have you been able to dial in the shocks, alignment, or tire pressures to get it to be a little more neutral?
Car just got the Konis on earlier this week and the bar is being delivered soon, but recent reading have led me to think it might be a little too big on our cars. Just trying to see if anyone has figured it out yet or if I should look into a different bar.
Jawnathin is offline   Reply With Quote
Old 07-17-2014, 03:46 PM   #1294
mla163
Overthinking it
Drives: BRZ in CS
I just exchanged by unopened inserts. I bought mine from Stranoparts.
mla163 is offline   Reply With Quote
Old 07-17-2014, 03:47 PM   #1295
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I have John's old Strano Bar on my otherwise stock FRS
I found that on a highspeed autocross course (and probably a race track) the combination was quite good.
but on a tighter course I definitely had more push than I would have liked, the car was not responsive at all from throttle inputs.
plus it bangs, unfortunately (although it only bangs on one side, so I'm thinking install error) but the tolerances are definitely narrow.
and I'm in an FRS, I think for a BRZ the Strano bar would be in fact a little too much.
Old 07-17-2014, 03:47 PM   #1296
mla163
Overthinking it
Drives: BRZ in CS
The Strano front bar is really light compared to most others. I'm not sure that there is one out there that is less stiff.
Old 07-17-2014, 03:58 PM   #1297
Jawnathin
Not a bad choice, I'd opt for the complete strut too given the choice now. Would make the install very straight forward.
I went ahead and just used the inserts that arrived last week, overall the install wasn't bad but the cutting of the shock was a real PITA. Most of the DIYs, people seem to not have a problem with it, but it took forever and a lot of muscle/effort to get it done.
One benefit of this setup though is it looks almost like a completely stock car. There are a few details that give it away, but it won't be obvious. The black/OEM housing will be helpful for my dealer visits.
Thanks, I've read the tolerances are a bit tight and the bar needs to be centered, otherwise it'll bang. Crossing my fingers that fitment won't be an issue, not looking forward to troubleshooting this if it pops up. Hoping the later revisions of the bar fixed alot of that.
Was interested in increasing front end stability on higher speed courses but your feedback about tighter courses (can be somewhat common around here) concerns me. I assume by 'otherwise stock', you don't have shocks and just some decent tires? Thanks.
Yes, being hollow it is one of the lighter ones available. Also one of the softer ones, but I think Perrin has a 19mm adjustable bar that is slightly less stiff. Not sure about the Whiteline 20mm.
Old 07-17-2014, 04:13 PM   #1298
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
strano bar
R1Rs (235/40/17)
everything else OEM.
Old 07-17-2014, 05:13 PM   #1299
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I work at a whole sale distributor, send me a PM And I'll find you a dealer that will beat tire rack after freight.
G_Ride (07-17-2014)
Old 07-17-2014, 08:24 PM   #1300
G_Ride
G_Ride's Avatar
If only I didn't already have konis.....
Old 07-17-2014, 09:44 PM   #1301
vroom4
Terry @Maximal is probably your best bet for the new konis
vroom4 is offline   Reply With Quote
Old 07-18-2014, 03:57 PM   #1302
Jawnathin
strano bar
R1Rs (235/40/17)
Thanks for the confirmation. Are you going to get shocks?
Just got the Strano bar on last night, took it for a test drive, so far so good, no banging or noises anything like that. Clearance was tight on the driver side, so I ground down the end of the swaybar next to the endlink for a bit of safety margin. Not sure if it would have been a problem if I hadn't, but I figure i might as well do it while I was in there.
Anyway, car seems to drive pretty decent among my 'test course' consisting of a few on ramps. All somewhat higher speed stuff you wouldn't find in an autocross, but the car does have increased stability and turn in. I'll see how it feels at an autocross, especially the slower tighter stuff, though I won't really know for sure until I get some good tires on it.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
