Old 07-16-2014, 02:29 AM   #6665
reignerabellera
Drives: GTX 86 2014
Is there anyway I could get one, im living here in Dubai UAE, this is a must upgrade for me instead of going for FI since I cant afford FI. Can anyone assist me how to get this one and ship. thanks
reignerabellera is offline   Reply With Quote
Old 07-16-2014, 04:10 AM   #6666
raven1231
Originally Posted by enwave View Post
By the way, for those interested in my confusion about my 1.5dump tune feeling weaker than my 1.0dump tune due to high altitude, I was totally wrong.
It was temperature and air pressure on the days following my switch of tunes. I had been driving in nice cool, dry temps. My experience with the new tune was with much higher ambient temps. Now that it cooled off again, I can clearly see the 1.5dump 2.0 tune from Shiv is clearly the better tune, even at altitude. AFRs were nearly identical between the two, so the environment had to be the cause.
Edit: I also took another nonbeliever for a ride today and the dude was totally converted. Took him to a nice wide private road and really thrashed into boost -- he couldn't believe I've only spent a total of around $31k on car and mods together. This really is a steal.
So I'm not the only one temperature has a rather significant impact on performance.
Drove to work this morning and it was 50 something degrees, got on it and my head was pinned to the seat LOVE that torque
Old 07-16-2014, 07:43 AM   #6667
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The laws of physics do not discriminate - they apply to all equally.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 07-16-2014, 08:30 AM   #6668
reignerabellera
Drives: GTX 86 2014
Originally Posted by Robftss View Post
Thks Fenton and all the new interested people.
I will be revising the installl manual, after ~30 kits it looks like step by step, circles/arrows, and check boxes are required. I may tag wires and reference them to a # operation, torque specs as well... since 'tighten' is to subjective. I need to evaluate one re-charge board failure and a control board failure. This is ALL new stuff and is primarily a development product not a mass produced product... it can't be... there is 'more' potential here. I'm excited
Rob.
can i also be included in the list. im willing to pay right away, plus the shipment. I live here in DUBAI UAE.
Old 07-16-2014, 08:36 AM   #6669
Gary in NJ
Gary in NJ's Avatar
This is your third post with the same message. You will need to send a PM to Robftss and ask this question directly. Since it is his product, Rob is the only person that can adequately answer that question.
Old 07-16-2014, 08:54 AM   #6670
raven1231
lol I realize that but everyone else seemed to act as if I was crazy when I said it seemed to vary day by day and with temperature.
Old 07-16-2014, 08:55 AM   #6671
raven1231
I told him in the other thread to contact Rob via pm and ask to be added to the list lol. I understand being excited but have some patience.
Old 07-16-2014, 08:25 PM   #6672
shif7i7down
Erected Member
Drives: frs
Maybe You should rig up a heatsink to the compressor and see if that helps.
I was thinking of buying copper tubing and welling it to a copper plate then somehow mount it to the compressor.
But I'm not sure how efficient it would be, but i would be happy just to see 10~15 degrees difference,
shif7i7down is offline   Reply With Quote
Old 07-16-2014, 09:37 PM   #6673
Gary in NJ
Gary in NJ's Avatar
I don't know where to begin with this one...
What heat problem are you trying to solve at the compressor? Have you taken temperature measurements on the outlet of the compressor and compared that to the intake temperature?
What are the cooper tubes going to do? Unless you will be circulating chilled water in the tubing...even then...
What problem are we fixing?
Old 07-17-2014, 03:21 AM   #6674
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Shiv just posted his dyno of the new Phantom 250, 1.5 dump, OFH E85 tune: no other mods, even stock air filter. I wanted to do an overlay, but I haven't seen a dyno for the ESC 1.5 with Shiv's new 91 or 93 tune, so I grabbed his last dyno which was the Phantom 250, 2.0 dump with mods:
OpenFlash Tablet
OpenFlash Header
Single tip cat-back
Modified air duct
93oct (although the it's mapped conservatively enough to make the same power on 91oct)
[Stock run shown for reference]
It's kind of hard to make out, but the E85 runs are the ones making moar powa.
that bottom end just keeps getting stronger.
Target70 is offline   Reply With Quote
The Following 4 Users Say Thank You to Target70 For This Useful Post:
Boofneenee (07-17-2014), DAEMANO (07-17-2014), shif7i7down (07-17-2014), Sojhinn (07-17-2014)
Old 07-17-2014, 07:51 AM   #6675
shif7i7down
Erected Member
Drives: frs
I was not trying to say that I'm having a heat problem, he said that he noticed that the car runs allot better in cooler weather so i was only suggesting that maybe having a heatsink on the compressor might help reduce the charged air since it might keep the compressor cooler.
Sory for the confusion,didn't mean to alarm anyone
Old 07-17-2014, 11:02 AM   #6676
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
OpenFlash Tablet
OpenFlash Header
Single tip cat-back
Modified air duct
Looks great! I'm also excited for E85 performance when not on boost. I find one of my favorite things about this ESC is the ability to still drive my car like normal all the way to redline due to where I've set my throttle switch (at like, 95%). E85 is going to be a solid power improvement in situations where I'm not boosting too -- maybe even more so than boost conditions.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
Target70 (07-17-2014)
Old 07-17-2014, 02:46 PM   #6677
Target70
Target70's Avatar
strangely enough, I didn't even think about that. I guess I'll have to wait till someone else logs some dyno time, and does an ESC off, e85 run.
The Following User Says Thank You to Target70 For This Useful Post:
Old 07-17-2014, 03:44 PM   #6678
enwave
enwave's Avatar
Eh, it'll definitely be a solid improvement. Not sure what you would wait for -- if you have access to and are comfortable using E85 I'd just do it. I'm just saying that I'm excited for off boost performance too, as I was running E85 NA before I bought the ESC and loved it going back to 91 hurt a little.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
