#57 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Good to know. I don't use shops like that and don't know anyone that does (for track rubber, that is). Sounds like a buyer would save the shipping cost, too(?) - that's $75 from PT to the Northeast for a set of 215/45-17 NT01s.
#58 |
Drives: 2022 BRZ Limited
I've recently learned that the Discount Tire stores have the best machines/methods for tire balance services so that's what I used for the last couple times.. I personally wouldn't go anything less than 225/45/17 since I would like to run a bit wider tires to get the most out of the tire upgrade..what kind of wheels are you planning to run them with? for an NA car I think 9" wheels and 235/40/17 is a great combo IMO since the overall diameter even smaller than 225/45/17 and running slightly wider wheels will give you stiffer side walls and more mechanical grip ..However, since I am FI now I will most likely go with something wider like 255/40/17 on my next set
#59 |
it also depends on the track too, right Mike?
#60 | |
To make class, on my 2893# / 318 RWHP NASA TT3 car I run 235s on 9" wheels, and they're only marginally slower than the 245s I normally run. Performance-wise, I have the general feeling that 235s are too much tire for a twin with OEM power. |
#61 |
Most tire stores can order any tire with advance notice and a deposit. It's always good to build a relationship with a few, particularly if you go through a lot of tires, since they can help you out in a pinch.
#62 |
It does, but unless the track is all turns, the smaller tire is still faster.
I only have *one* example where a 255 is faster than a 225, and it's one specific track in one specific direction. The 225 is universally faster than a 255 everywhere else. This one track is, literally, all turns that even the FRS can't take WOT, and the major straight is downhill, mitigating most of the power loss. This applied to our testing with FI as well... at least at the power levels that the locals are at. |
#63 | ||
![]() I think 235/40/17 might be an exception because it has slightly smaller in overall diameter (even smaller than OEM 24.4 " vs 24.7") so I thought it might be the sweet spot for NA cars the majority of the tracks.. but with FI, I beg to have more grip in some corners with the added power and would like to try the 255s next time and a bit longer gears would help as in some corners, it feels like I don't have the correct gearing .. I am sure you saw this but in this test even with the bigger 18" wheels (heavier and bigger overall diameter), car was slightly slower than lighter and smaller OEM size tires but provided a lot more lateral grip and slalom speed http://www.roadandtrack.com/cm/roada...1e841088f1.pdf
#64 | |
Generally, for the tracks in Socal, the gearing change is so minimal that it makes no difference. The 235 RC1 was definitely quick in corners, but the straightline losses wiped out some of the cornering gains. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (07-17-2014) |
#65 | |
oh and I saw some videos of the Buttonwillow and that track looks more like a rally course than a road course ![]()
#66 |
Drives: Nevermorange FRS
Heat. A lot of this has to do with heat.
The drag penalty of rolling resistance and aero from wider tires isn't as significant on cars with 200+hp, especially on cars with FI. With low HP cars (spec miata, my CRX etc), it can be a bigger deal especially with longer straights. Another area where going wider doesn't really help on a road course is if your wheel width limited (like I'm limited 7" wide wheels) and thus a wider tire may not be using any more contact patch due to increased lateral rolling of the tire. Secondly, heat is extremely important in the functionality of the tire. If you cannot maintain a certain temp (like >180F) there's a good chance the wider tire isn't an improvement. I've just been through this in my last 6 races. I went from 205 RR to 225 RRs and both weekends were very cool days (under 65, some rain) and I couldn't get the 225's hotter than 150F on the front of my FWD car. On both weekends my fast time of the weekend was on my 25+ heat cycle 205's. Why? Heat. I put 20F more temp in 205's. The difference in track times: 0.5 - 1.0 second.
PRO86 | WTCC | STL
#67 | |
like Mike suggested I will get a pryometer to see what kind of temps I am seeing after fast sessions
#68 | |
I was always curious about the AJR BRZ's weight, as the rear end was stripped out at SLB when Rob ran that lap. Thing was moving! |
#69 |
also shows you how cheap the owners of the track can be when it comes to new pavement haha
#70 | |
![]() he mentioned (on his facebook) that he was running 245s Z214s so I think it also supports your statement about the optimal tire size last year he was doing 1:59s with 265s and 2:00 with 255s respectively.. I don't see any other BRZ/FRS below 2 mins here in RMP
| How to warranty your stock tires and save money on Pilot Super Sports | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 81 | 03-31-2016 09:48 PM |
| Slicks upgraded axles 1/4 mile? | Fabron757 | Forced Induction | 13 | 06-29-2014 06:25 PM |
| Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-26-2014 11:47 PM |
| Auto-x, slicks & tire temps | mtimney | Tracking / Autocross / HPDE / Drifting | 6 | 10-19-2013 09:30 PM |
| Choice of slicks for HPDE | CB762 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-02-2012 09:25 PM |
