Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Slicks upgraded axles 1/4 mile?
Bought some wheel adapters and some real big boy drag radials. Also upgraded axles. Its time to break into the 11's with this 470@wheels. If i don't then I need a driver mod. I will be making a video with the gopro and having someone record. Next sat is the big event. Guess i'll be the first to test some mickey thompsons Et street radials and see what breaks. Hope clutch holds.
http://www.ft86club.com/forums/showthread.php?t=31807 Last edited by Fabron757; 10-04-2013 at 03:27 PM. Reason: radials |
which clutch are you using?
Drives: Gx 460, FRS, Prius
You shouldn't need slicks, but there definitely going to make a real difference.
Best of luck!!
Thanks
Drives: 85 corolla gts
Yeah it is a 6 puck. It is a bit grabby you could say with light chatter at idle with the ac on. pedal effort is not bad at all and engagement is not that bad to get used to.
Señor Member
Clutch should hold, but then again I've had problems with both clutch masters clutches I had in my other car. But good luck! go run 11s!
Drives: 2003 Subaru Outback
Lets see pics of the wheel setup?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Boosted
Drives: Not a supra....yet
#10 | |
Ill be on boost next month so I guess well see how my theory works.
#11 |
Boosted
Remember the ISF is way heavier and is longer.
#12 |
Drives: 2005 Chrysler Crossfire
What are you currently running now @470?
#13 |
Drives: GT86/GTR R35
I am getting the driveshaft shop - axle and drive shaft alminmum
and ats clutch and lsd |
#14 |
Did u ever get this thing down the track?
| Low car + replacement axles + raising diff advice | JordanWho | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 04-05-2019 08:47 PM |
| should i upgrade axles? | Frs300 | Engine, Exhaust, Transmission | 16 | 07-01-2013 11:00 PM |
| The Driveshaft Shop Custom Axles and Shafts | Sportsguy83 | Engine, Exhaust, Transmission | 26 | 01-11-2013 04:55 PM |
| FS: (Toronto,Canada) Continental Racing Slicks 225/45/17 | OptionJDM | Wheels and Tires | 2 | 09-19-2012 10:48 AM |
| Choice of slicks for HPDE | CB762 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-02-2012 09:25 PM |
