Old 07-14-2014, 11:39 PM   #1
tez2013
Best Slicks / Race Tires for the Money
Hey guys,
I'm currently running Dunlop's Direzza Z2 on a stock set-up, and looking to take it to the next level at the track.
What's the consensus on the best value for money track-only tires? I'm currently looking into Hoosier A6, R6, and NT-01.
Also, is the 17 inch rim the smallest rim we can fit on the car? I'm trying to go with the smallest rim for the track to minimize rotating mass as well as tire cost. Assuming 245 is the widest that will fit without rubbing (stock alignment/ride height)?
Thanks all.
tez2013 is offline   Reply With Quote
Old 07-15-2014, 12:30 AM   #2
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Khumo 710's or Hankook Z214's are very similar to R6's at 60% of the cost.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 07-15-2014, 12:59 AM   #3
Racecomp Engineering
Originally Posted by tez2013 View Post
Hey guys,
Thanks all.
What are your goals?
Long tire life?
Fastest single lap time?
Budget?
Also, stock alignment with these tires will not be a good thing.
- Andy
Old 07-15-2014, 01:26 AM   #4
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Add BFGoodrich R1s in 235/40-17 to your list. Or in 245/40-17 if you want 3/10" wider tread. Excellent pricing and service can be found at Phil's Tire Service in Cragsmoor, NY: http://www.philstireservice.com/. Phil has the concession for all of the NASA Northeast and NASA Mid-Atlantic events.
dradernh is offline   Reply With Quote
Old 07-15-2014, 04:15 AM   #5
Hey guys,
Thanks all.
What exactly is your goal?
Will you be driving on them to the track?
How much are you willing to spend?
Old 07-15-2014, 01:28 PM   #6
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Hey guys,
Thanks all.
one thing to mention that the tires that you listed are not in the same league, A6, R6 and Z214s are the real R compound tires whereas the NT01s, R888, MPSCs are relatively closed to each other .. general consensus really depends on what is your ultimate goal as others mentioned..
I prefer Nitto NT01 for now since it's widely available, cheap, last longer, you can drive them on the street or to track, and people on rennlist forums and a few other forums also seem to like them ..they even run them to the cords.. you can even flip them on the same wheel and run inside and out (not in the rain of course since you change the tread directions)
For the record I had some minor rubbing with stock suspension and ride height and that was with 235/40/17s, you will definitely rub them if there are some serious elevation changes at the track you use them..
People seem to like the Z214s, I heard nothing but good things about them and it's similarly priced with NT01s ( costs about $25-30 more than NT01s)..Did you get a chance to compare Z214s to NT01s? Are those light years ahead of the NT01s? heat cycled out quickly?
Also, not really popular but Ventus TD Z221 also looks like another nice option but I don't think it's widely available in the U.S as of now.. in a recent test it showed some serious gains against to NT01s
http://ventustd.com/technicaldata.php
the guy who ran the test was on the renntrack forums
see his impressions
http://www.renntrack.com/forums/show...4559#post24559
glamcem is offline   Reply With Quote
Old 07-15-2014, 03:24 PM   #7
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I know people in the time trial community that like the Maxxis RC-1. I plan on giving them a go next season.
http://www.maxxis.com/catalog/tire-450-107-victra-rc-1
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following User Says Thank You to SubiePig For This Useful Post:
glamcem (07-15-2014)
Old 07-15-2014, 03:38 PM   #8
I'll group the tires by category (no particular order within a category)
"R-comp" 100TW
Toyo R888
Toyo RA1
Nitto NT01
Maxxis RC1
"R-Comp" 80TW
Hankook TD
"R-Comp" 60TW
Toyo RR
"Slick" 40TW or lower
Hoosier A6
Hoosier R6
Kumho V710
BFG R1
BFG R1S
Old 07-15-2014, 03:42 PM   #9
glamcem
glamcem's Avatar
yes, I've heard about them too I wonder if they are one of those softer compounds since they didn't mention ..maybe I should try something new on my next set but I am not sure about the longevity and predictability of the other tires besides the NT01s and the only way to tell is to try them..
also heard about these too, it seems like they come in both Soft and medium compound
http://www.federaltire.com/en/produc...ts_detail_sn=3
Old 07-15-2014, 04:59 PM   #10
CSG David
CSG David's Avatar
It's a quieter tire that's for sure and a very good daily dry tire. Doesn't require much of a warmup time to get them running.
The Following User Says Thank You to CSG David For This Useful Post:
Old 07-15-2014, 05:11 PM   #11
glamcem
glamcem's Avatar
How would you compare them against the NT01s or R888s?
Old 07-15-2014, 05:14 PM   #12
CSG David
CSG David's Avatar
NT01 requires a little warm up time, but grip is comparable. NT01 strives better in hot situations, RC-1 is better for cooler situations. Either way, you shouldn't be overheating either tire. If you are, you are over-driving the car.
R888 are not as consistent as the NT01 or RC1.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
glamcem (07-15-2014), hmong337 (08-18-2014)
Old 07-15-2014, 05:21 PM   #13
glamcem
glamcem's Avatar
awesome, yes I know the R888s are notorious for being inconsistent and consistency is the main reason I picked NT01s over the hardcore lower TW R comps.. it seems like the NT01s are still the magic tire when all considered :/
if you saw the comparison between the Hankook TD and NT01s that I posted above, TD might be another good alternative ..since I do care about the tread when I drive to closer tracks within 100 mile radius. too bad there are not so many places offer the Ventus TDs and I don't hear as much feedback except that test
Old 07-15-2014, 05:28 PM   #14
CSG David
CSG David's Avatar
TDs are faster than the mentioned R-Comps, but the wear rate is higher. There are pros/cons to each setup. It's all a balance when it comes to your application, scope, quality, and budget.
We do our best to post positive results and suggestions based on our findings, experiences, testings, and data.
How to warranty your stock tires and save money on Pilot Super Sports SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 03-31-2016 10:48 PM
Slicks upgraded axles 1/4 mile? Fabron757 Forced Induction 13 06-29-2014 07:25 PM
Track-only Race Compound Tires recommendations & Q's. On stock wheels. fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 03-27-2014 12:47 AM
Auto-x, slicks & tire temps mtimney Tracking / Autocross / HPDE / Drifting 6 10-19-2013 10:30 PM
Choice of slicks for HPDE CB762 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-02-2012 10:25 PM
