Old 07-16-2014, 03:07 PM   #29
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by transition View Post
As requested:
https://www.dropbox.com/s/fdwuxreno7...unFile_012.drf
(all dyno runs were done in 5th gear)
Thanks man. But that's just the one final Ecutek run. I was hoping for all the runs in the tuning session.
Originally Posted by jamesm View Post
Speed Density, custom maps for things like boost control, real flex fuel, AFR failsafes, overboost fuel cuts, boost by gear, better traction control. The list is endless, but pretty much boils down to 'custom maps'.
The real big thing though is speed density, which gets you around the MAF limitation, and the ability to use custom maps to overcome the port injection limitations at high power levels (typically on e85).
Also, just in my personal opinion i wouldn't be comfortable tuning a turbo car without an overboost fuel cut. Mine has already saved my motor a couple times, and i know a couple guys who didn't have it and it cost them a new engine. Not worth not having, imho.
Now with a supercharger the math is entirely different. The vortech kit works great. The JRSC kit, not so much (the MAF is maxed out of the box). The kraftwerks kit seems like it would be fine, but the bigger blower also maxes the MAF in the default configuration, necessitating SD.
The OFT OTS map for the SBD turbo does have overboost protection. Just ask @Neal@EQtuning
Shiv@Openflash is offline
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
raven1231 (07-16-2014)
Old 07-16-2014, 03:09 PM   #30
jamesm
I was unaware. That's great news! Is it a custom routine of some sort? Available to the rest of us?
jamesm is offline
Old 07-16-2014, 03:11 PM   #31
transition
Sorry about that - here's the whole deal:
https://www.dropbox.com/sh/ikfccz30p...I8LO-jzwQrn8qa
transition is offline
The Following User Says Thank You to transition For This Useful Post:
Old 07-16-2014, 03:42 PM   #32
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Haha, saved my damn motor too!
The Racers Line is offline
Old 07-16-2014, 03:55 PM   #33
steve99
Drives: FT86
how was overboost cut feature achieved ?
steve99 is offline
Old 07-16-2014, 04:00 PM   #34
The Racers Line
Shiv would be the one to ask for specifics obviously, but from my understanding, it's a load based ignition cut using the maf. I actually have a log of it if you want to see.
Old 07-16-2014, 04:03 PM   #35
steve99
Drives: FT86
yes be interesting to see
thought it would have needed a custom routine/patch in rom, to enable ignition cut
steve99 is offline
Old 07-16-2014, 04:15 PM   #36
Shiv@Openflash
Drives: 2013 FRS
Thanks man, I appreciate it. I do have a few questions and concerns about your comparison though.
1) According to the run files, it looks like you guys did 2 back-to-back runs on the OFT tune (within the same minute). And in the comparison, you plotted the lower powered run. Is there a reason for this?
2) According to the run files, the Ecutek tune you plotted was the highest hp run of all the other Ecutek tunes. And it looks like it was done a good 20 minutes from from any of the other runs. So presumably, the engine was cooler and the air quality in the dyno cell better.
Also, I'm not sure why the run numbers are inverted. Run 1 was the last one done according to the dynojet time stamps. And run 12 was the first.
Lastly, when baseline in the OFT, you did two back to back 5th gear runs. But when tuning the Ecutek, you alternated between 4th and 5th gear runs. I'm guessing to keep the engine cooler than if doing back to back 5th gear runs.
These are just some observations based upon the actual dynorun run data you were nice enough to post. Sometimes more info is better than less info.
Regards,
Shiv
Old 07-16-2014, 04:17 PM   #37
Shiv@Openflash
Drives: 2013 FRS
By common sense
Just logged load (g/rev) during a normal pull. And incorporated an ignition timing cut at load levels greater than that. Makes it pretty obvious when you have a wg failure. Exhaust note goes "POP". Engine doesn't.
Old 07-16-2014, 04:25 PM   #38
jamesm
By common sense
That's a hack at best, and not a real overboost fuel cut. What happens when the customer stays wide open into it? Couldn't that cause EGTs to skyrocket? Granted we like to think people would be smart enough to get off of it... but in reality they aren't always.
I've tried this same solution in the past on BRZEdit and ditched the idea on the basis that using calculated load to infer boost was as bad idea in general. That what the map sensor is for .
jamesm is offline
The Following User Says Thank You to jamesm For This Useful Post:
Fast_Freddy (07-16-2014)
Old 07-16-2014, 04:29 PM   #39
transition
Thanks man, I appreciate it. I do have a few questions though.
Regards,
Shiv
1) I believe they just went ahead and selected the first run with the OFT without comparing both pulls.
2) I believe the data you need to validate this is in the files? The first pull was done on OFT and didn't come from an overly 'hot' car. My car was sitting in the parking lot all day, it was brought up to temp then ran.
Obviously i would have never posted the files if there was any intent to manipulate. We're open about the results and the work speaks for itself. Interpret the results as you may. Here's another one we did that got similar results a few months back.
The reason ECUTeK was done on my car was the intent to go forced induction. Perhaps i should have just titled the post "Off the shelf tune vs pro tune". The intent here is not in any way to say that OFT's product is somehow inferior. You're producing a great product with very distinct differences than something like the ECUTeK. I'm sure we could have achieved very similar results with a pro tune and the OFT which i'd highly recommend for an N/A car.
Old 07-16-2014, 04:30 PM   #40
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
And the Shiv battle begins...
Cockatoo is offline
The Following User Says Thank You to Cockatoo For This Useful Post:
husker741 (07-16-2014)
Old 07-16-2014, 04:38 PM   #41
Shiv@Openflash
Drives: 2013 FRS
Customer can't stay wide open in it because the engine falls flat and misfires. Neal@EQ can comment on that.
To the engine, all it sees is load (airflow/rev). It doesn't actually see about MAP. MAP is an load estimate. It's just an indication of the air pressure in the manifold. VVT (among other things) effect the correlation between MAP and actual engine load. So to me, engine load cuts (as opposed to MAP cuts) is the better approach.
As always, your mileage may vary.
Old 07-16-2014, 04:42 PM   #42
Shiv@Openflash
Drives: 2013 FRS
That's fine. I'm just pointing out that you chart compares the lower of 2 pulls on the OFT tune to the highest of 10 pulls on the Ecutek. By no means am I saying this was intentional. But I think it's important info to mention because a somewhat different picture is presented when comparing apples to apples. If you give me permission (this is your thread afterall) I can post up another dyno comparison that holds more testing variables constant.
chas3wba0 (07-16-2014)
fi and openflash tune Hachi6 Forced Induction 59 11-20-2015 01:28 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
>>> Circuit Motorsports > Scion FR-S + E85 + HKS Header + EcuTek Tune! Circuit Motorsports Software Tuning 9 12-14-2013 11:38 AM
Borla UEL Header, works automotive parts and ecutek tune clayrush Engine, Exhaust, Transmission 14 06-27-2013 03:37 PM
