Old 07-16-2014, 10:57 AM   #15
The Slow One
Track Junkie
Drives: Argento Scion FR-S
Originally Posted by tennisfreak View Post
Wonder how safe is the ECUTek tune.
What are the A/F ratios and how lean is it running?
If the tune is too aggressive then it will show bigger gains but bad to run long term.
Generally a custom tune will always have more gains over the OTS tunes. Finding a tuner willing to use OFT locally will be a challenge for sure. I rather just run Ecutek. I've been very pleased with my custom tune from Moto-East
The Slow One is offline
Old 07-16-2014, 11:18 AM   #16
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by transition View Post
Just sharing my experience here. Thought this was an interesting result showing the difference between an off the shelf map and a pro tune. What seems especially interesting here is the car does not have a front pipe or catback installed and we've almost gotten 200whp on 93 octane.
+1 very interesting, pretty significant gains! Hopefully this won't turn into an EcuTek vs OFT thread, rather stay as an OTS vs Custom tune thread.
bfrank1972 is offline
The Following User Says Thank You to bfrank1972 For This Useful Post:
husker741 (07-16-2014)
Old 07-16-2014, 11:21 AM   #17
s2d4
s2d4's Avatar
Fair enough. Just wondering since you didn't say anything other than mod list and dyno comparison.
As for OFT vs Ecutek and people thinking it'd be magically different, if it modifies the same maps which I don't see why it wouldn't (since NA), there is no reason why it would be any different. The difference here would be OTS vs Custom Dyno and different tuners plus their tuning philosophy. I have no idea what the TopSpeed guys goes for, shiv's has been fairly vocal and logically sound.
Basically you could have had the same result without paying for ecutek if he was happy to tune using Romraider(OFT flashes the tune).
s2d4 is offline
Old 07-16-2014, 11:57 AM   #18
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
The thing that is nice about the OFT is that you can sell the tablet eventually and get some money back. With a custom Ecutek tune, you really can't do that other than sell the cables or something. So I would rather have a custom OFT tune than a custom Ecutek tune.
husker741 is offline
Old 07-16-2014, 12:02 PM   #19
Malt
Drives: 2015 WRX
Originally Posted by Mad1723 View Post
That an OTS map designed to run on 91 is more conservative and less likely to produce power than a dedicated dyno-tuned profile tuned on 93? Which I guess everyone already knew. It's a nice amount of gains though
Corrected.
I'll be curious of the difference once the 2.0 maps come out with the dedicated 93 octane maps.
Malt is offline
Old 07-16-2014, 12:04 PM   #20
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Originally Posted by Malt View Post
Corrected.
We'll know soon enough, but I doubt we'll see 10WHP out of this. Maybe 2-3 at most. He still has to be very conservative to cover everyone.
Mad1723 is offline
The Following User Says Thank You to Mad1723 For This Useful Post:
transition (07-16-2014)
Old 07-16-2014, 12:07 PM   #21
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
This map proves that NA is the way to go on these cars.
Sent from my GT-N5110 using Tapatalk
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline
Old 07-16-2014, 12:58 PM   #22
Mad1723
Mad1723's Avatar
Depends what you're aiming for.
Mad1723 is offline
Old 07-16-2014, 01:33 PM   #23
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Baseline dyno was with an OpenFlash Stage 2 OTS map. The only changes in the second run is an EcuTeK unit tuned by Doug @ TopSpeed.
2013 Subaru BRZ
- 93 octane
- JDL header & overpipe
- Perrin intake inlet
- Stock intake box, front pipe & catback
- ECUTek tuned @ Topspeed
Good work guys. Would you mind posting up the dynojet run files (.drf) from the custom tuning session?
Cheers
Shiv
Shiv@Openflash is offline
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 07-16-2014, 01:58 PM   #24
transition
Cheers
Shiv
As soon as I can catch Doug off the dyno i'll definitely check. FWIW i was really happy with the OFT tablet and i'd be super interested to see what if any differences exist when an ECUTeK vs OFT tablet are tuned side-by-side.
transition is offline
Old 07-16-2014, 02:20 PM   #25
jamesm
I've tuned both and gotten the same results with either. For an NA car the end result is exactly the same, since you don't use much if any of ecutek's custom mapping stuff, the process is pretty much identical. Same goes for using romraider and a tactrix cable. The only difference lies in the software interface, flash times, workflow etc.
jamesm is offline
The Following 3 Users Say Thank You to jamesm For This Useful Post:
mwjcyber (10-03-2014), themajesticone (07-16-2014), transition (07-16-2014)
Old 07-16-2014, 02:30 PM   #26
Kids Heart
Kids Heart's Avatar
Drives: 2013 BRZ Limited SWP
What are the differences in tunning with ecuteck for forced induction from openflash?
Kids Heart is offline
Old 07-16-2014, 02:39 PM   #27
transition
Cheers
Shiv
As requested:
https://www.dropbox.com/s/fdwuxreno7...unFile_012.drf
(all dyno runs were done in 5th gear)
Old 07-16-2014, 02:51 PM   #28
jamesm
Speed Density, custom maps for things like boost control, real flex fuel, AFR failsafes, overboost fuel cuts, boost by gear, better traction control. The list is endless, but pretty much boils down to 'custom maps'.
The real big thing though is speed density, which gets you around the MAF limitation, and the ability to use custom maps to overcome the port injection limitations at high power levels (typically on e85).
Also, just in my personal opinion i wouldn't be comfortable tuning a turbo car without an overboost fuel cut. Mine has already saved my motor a couple times, and i know a couple guys who didn't have it and it cost them a new engine. Not worth not having, imho.
Now with a supercharger the math is entirely different. The vortech kit works great. The JRSC kit, not so much (the MAF is maxed out of the box). The kraftwerks kit seems like it would be fine, but the bigger blower also maxes the MAF in the default configuration, necessitating SD.
jamesm is offline
fi and openflash tune Hachi6 Forced Induction 59 11-20-2015 01:28 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
>>> Circuit Motorsports > Scion FR-S + E85 + HKS Header + EcuTek Tune! Circuit Motorsports Software Tuning 9 12-14-2013 11:38 AM
Borla UEL Header, works automotive parts and ecutek tune clayrush Engine, Exhaust, Transmission 14 06-27-2013 03:37 PM
