#15 |
#16 |
Drives: fire storm frs 6mt
Intake, header, over pipe, front pipe, catback, crank pulley and Ecutek. install everything in one day and tune it.
#17 |
Drives: 2013 Scion FRS
Hmmm..
HKS EL header is pretty expensive.. Tomei EL header on the other hand is half the price though. Are the front pipe and overpipe worth the extra money? Would I pass inspection with just the Tomei EL header and Greddy SP Elite?( if I were just to get a tune with those) Would I pass inspection with tomei header, sp elite, hks fp, and motive op? As much as I would like to squeeze out as much extra HP n/a, it does get pricey after adding up additional parts that may not be necessary for me....or seriously might as well spend extra and go FI. If I were just to do some spirited driving and maybe track 1-2 times a year would I need an oil cooler?? |
#18 |
Passing inspection will depend on where you live... I can pass inspection on a catless system here...
#19 |
#20 |
#21 |
Drives: '13 Whiteout FRS
Stock tune is garbage for reliability. First thing I would get is a tune. Then header and drop in filter. If you need a cat, either leave stock front pipe or buy a catted front pipe. Don't use a catted header, it defeats the purpose of a properly designed collector.
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship |
#22 | |
I'm just confused because you say to tune it before I install header and air filter? Also would upgrading to a aftermarket catted front pipe be worth it or just keep stock front pipe? Thanks! |
#23 | |
Typically 4-1 headers shift power higher into the RPM range while 4-2-1 give a big bump in the middle, but that's not even always true until you compare if they're stepped or not, what diameter tubes and what length the tubes are. Also, if you look at dynos pre/post manifold spacers, you'll see that you aren't really losing much power up top, it just seems that way because of the big bump they give around 6500 rpm. Forget about peak numbers, area under the curve is what makes the car faster.
#24 |
True... the spacers dont increase peak power by much... but it makes a noticeable differene in the mid range. UELs also make very noticeable gains on the mid range but not much at top end... unless you want to be thrashing the engine all the way to 7400... having peak power lower in the power band is better for day to day driving... and helps male the engune last a bit longer.
#25 | |
Drives: World Rally Blue BRZ
Thanks |
#26 |
FT86SF uel catted header can be used without a tune... as long as you have the rest of the exhaust stock... otherwise the car will run lean and throw a cel. If you run catless you'll have to use o2 spacers so that is doesnt throw a cat code until you can get it tuned and deactivate the sensor
#27 | |
Drives: 2015 WRX
Your car may run poorly and certainly will have a CEL which will prevent the use of your cruise control. You can "fix" it with the O2 spacers but a tuning solution is obviously the better choice. As for "gains", I doubt you'll have any. In fact without a tune I'd venture to say your car will run worse than stock with a catless UEL header. Which tuning solution are you going with? If you are going with openflash, there's no reason to wait as you can flash the tunes as you upgrade the car. If you are going with a different solution my recommendation if you don't want to tune more than once is to just wait until you can afford the whole thing and do it all at once. |
#28 | ||
| Wax Sealant Pad Questions / Care Questions | l0aded | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-25-2014 11:19 AM |
| TRD kit questions | Tofu driver's Fr-s | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 07-30-2013 03:04 AM |
| Two questions | yuicebox | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-25-2013 06:22 AM |
| two questions | Jeong | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 11-26-2012 08:37 AM |
| E85 questions | Grishbok | Engine, Exhaust, Transmission | 17 | 08-08-2012 10:49 PM |
