Old 04-16-2012, 03:23 PM   #15
Capt Canuck
Drives: BMW E36 323is
^Which will have a good deal of its sportiness ruined by 19" wheels.
But if you equate filled wheel arches with sportiness, then by all means have at it.
Capt Canuck is offline   Reply With Quote
Old 04-16-2012, 03:46 PM   #16
Godzpeed
Drives: Nissan GTR
running high profile tires on tiny rims is consider sporty nowadays?
even if i'm tracking this car, I'd consider at least 18"
Godzpeed is offline   Reply With Quote
Old 04-16-2012, 03:46 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What he said. Big wheels do not mean "sporty".
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 03:54 PM   #18
WhiteGDB
WhiteGDB's Avatar
Drives: Civic Si sedan
Not necessary true. If you run 205/55-16 well yeah, but if you run 225/50-16 or 245/45-16
Both of which have a taller sidewall than 215/45/17
WhiteGDB is offline   Reply With Quote
Old 04-16-2012, 04:06 PM   #19
GodSays
GodSays's Avatar
Drives: Beater
Does anyone have a collection pics of the car with 16-19" wheels for comparison of the look of the tire to rim ratio
If not I will search and post
GodSays is offline   Reply With Quote
Old 04-16-2012, 04:13 PM   #20
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
245/45-16 is? Last time I've check tire spec reading goes
width/sidewall/wheel size
but if you wanna go technical then yes, 245/45-16 run .04 inches bigger in radius then 215-45-17
Old 04-16-2012, 05:07 PM   #21
WhiteGDB
WhiteGDB's Avatar
Well Calum was talking about having to use a taller/thicker sidewall on 16s to have the same overall diameter of stock(215/45/17). His statement was absolutely true and no way around it.
I'm not getting technical about the overall diameter of 245/45/16 tires, because we're talking about sidewall height/thickness. Maybe you didn't realize, but you did quote Calum's "16's will just have a taller side wall".
245/45/16 has a 110.25mm side wall (245 X .45) where as:
215/45/17 has a 96.75mm side wall (215 X .45)
Old 04-16-2012, 05:23 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
.03" (radius, .06" diameter total) but who's counting? I do have a graph above with that info in it.
The biggest problem with 245/45/16 is tire selection. There are choices for R comps in that size but none of the top street tires are available in that size.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Last edited by Dave-ROR; 04-16-2012 at 05:25 PM. Reason: didn't see the radius part in your earlier post at first.
Old 04-16-2012, 05:26 PM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I think both are being discussed.
I was originally talking about gearing (diameter), Calum stated the gearing wouldn't change unless diameter does (true) and that the 16s would have a taller sidewall for that same overall diamter (also true).
I think ichi is talking about diameter and not side wall. Either way, 245/45/16s are larger in both, side wall and overall diameter. As are 225/50/16s. Maybe not though since he did bold the side wall part. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Crashoverride (04-17-2012)
Old 04-16-2012, 05:28 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
IMO if you are doing this for looks you need to see them on the car you are buying. 20s on a Bentley look much different than 20s on a Civic.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 05:32 PM   #25
WhiteGDB
WhiteGDB's Avatar
Didn't make sense when he quoted in bold 16's will just have a taller side wall and then counter with "not necessar(ily) true"
Old 04-16-2012, 05:34 PM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah I noticed that later and edited my post, after you read my reply probably. I was basing that off his recent post when he talked about the radius difference and only noticed that he bolded that part when I went back further.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 05:41 PM   #27
ichitaka05
Site Moderator
ichitaka05's Avatar
Alright, alright, I'm the bad guy here. Flame me now! Lol
Old 04-16-2012, 06:01 PM   #28
WhiteGDB
WhiteGDB's Avatar
It's not about flaming/trolling. We're all here for mostly the same reasons and just want good technical discussions with accurate info. Sorry if it seemed like I was attacking you, wasn't my intention.
UK work Giccin EUROPE 5 02-09-2012 01:21 PM
Got a little bit of work done on my S14 today MrVito Other Vehicles & General Automotive Discussions 23 01-15-2012 10:00 PM
Off to Work! Exage Off-Topic Lounge [WARNING: NO POLITICS] 2 09-16-2011 11:04 PM
Interior Work S2KtoFT86 Scion FR-S / Toyota 86 GT86 General Forum 10 10-29-2009 06:33 PM
Does anyone work for Toyota? MTD Scion FR-S / Toyota 86 GT86 General Forum 7 10-25-2009 07:40 PM
