Old 04-16-2012, 10:43 AM   #1
rogerdalien
Drives: 07 Corolla CE
Are 17" wheels too big? Might work 16's work a little better?
Stock 17's are fine, I'm sure, but for those who want an additional aftermarket set (maybe dedicated summer tires,) are you considering 16 inch wheels as well?
What are some advantages of 16's? Well, look aren't one but performance might be.
1. 16's can weigh as little as 12 lbs.
2. There may be more tire choices in 16's and they might be cheaper too.
3. 16's might absorb the bumps better before sending the shock to the upper suspension.
4. Many 16' tire choices are lighter.
5. 16's are cheaper.
Do you think 16's will clear the rotors and calipers? Based on the photo, can you tell?
rogerdalien is offline   Reply With Quote
Old 04-16-2012, 10:47 AM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
iirc someone was saying rotor was same size as WRX, so yes, 16's will clear em.
I'm planning to put GC's 5 spoke gold wheels (16's) on my FRS/BRZ for all reason tires & regular 17's for summer tires
Old 04-16-2012, 11:02 AM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
16s will clear as noted above.
IMO tire sizes aren't ideal for 16" because of the gear ratio increase. I like shortening gearing though, not making it taller so YMMV.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 11:41 AM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
huh? Dave, did you forget your meds today? I only ask because you're normally on top of things, this post isn't like you, from what I've read on here.
You wont change the gearing at all if you keep to the same outside diameter of the tire. 16's will just have a taller side wall.
Old 04-16-2012, 11:52 AM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Not necessary true. If you run 205/55-16 well yeah, but if you run 225/50-16 or 245/45-16
Old 04-16-2012, 11:53 AM   #6
Godzpeed
Drives: Nissan GTR
no, i'm putting 19"s on
Godzpeed is offline   Reply With Quote
Old 04-16-2012, 11:56 AM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
^19's? So tires are like 255/30-19? Oh~ that won't be fun ride
Old 04-16-2012, 12:27 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I don't disagree with that. However, what tire size did you plan on using to keep the same outside diameter?
Here's what I made a long time ago:
245/45/16 is very close.. if you want to run R comps only.
Otherwise, I think the shorter gearing of the 235/40/17 plus the additional width will offset the wheel weight difference compared to 225/50/16s.
Only time and testing will tell for sure though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 01:27 PM   #9
Calum
That Guy
Touche. I knew something was missing.
Old 04-16-2012, 01:56 PM   #10
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I think 225/50/16 looks promising. Its just a little bit taller. I'm concern that the 235/40/17 is a little too wide and may change the character of the car slightly.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 04-16-2012, 02:17 PM   #11
GodSays
GodSays's Avatar
Drives: Beater
I'm contemplating 19s but the rides exactly what I'm worries about which makes me wanna get 18s
GodSays is offline   Reply With Quote
Old 04-16-2012, 02:22 PM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
Just go 18's
Old 04-16-2012, 02:52 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
This car is small. 18s will look plenty big, with 19s looking like donks. Not to mention a 215/45 sidewall is on the smaller side of things to begin with. Take an inch out of that and the ride will suck. I wouldn't go bigger than 18s on this car. And performance-wise, more and more shops are thinking 17s might be the larger you want to go.
Old 04-16-2012, 03:13 PM   #14
Godzpeed
Drives: Nissan GTR
most of the demo cars u see are all running 19"
if you really care about ride, just get a camry. this is a sports car
UK work Giccin EUROPE 5 02-09-2012 01:21 PM
Got a little bit of work done on my S14 today MrVito Other Vehicles & General Automotive Discussions 23 01-15-2012 10:00 PM
Off to Work! Exage Off-Topic Lounge [WARNING: NO POLITICS] 2 09-16-2011 11:04 PM
Interior Work S2KtoFT86 Scion FR-S / Toyota 86 GT86 General Forum 10 10-29-2009 06:33 PM
Does anyone work for Toyota? MTD Scion FR-S / Toyota 86 GT86 General Forum 7 10-25-2009 07:40 PM
