Old 07-11-2014, 06:26 PM   #1765
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Originally Posted by SPCorBUST View Post
Make sure its rotated properly, it took a bit to make sure it was seated right but I didn't have any complaints besides the 2.5" middle section on a 3"coupler. Makes me wonder what a straight 3"would make in gains.
There doesn't really seem to be a way to get the rotation wrong. It just won't fit right any other way. If I pull the first aluminum pipe away from the frame the bumper won't fit. I'll try messing with it again.
D-VO is offline   Reply With Quote
Old 07-11-2014, 06:47 PM   #1766
SPCorBUST
SPCorBUST's Avatar
I meant within something like 5 to 15 degrees of rotation before finding a good fit with the bumper, wiper bottle neck, bpv, tune back to intake, and connection to blower. It was a fair amount of squirming all around before I was satisfied with it.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-12-2014, 12:28 AM   #1767
D-VO
Ok gotcha. I'll take the bumper off on my next day off. I can feel a vibration in the brake pedal while stopped as well.
Old 07-13-2014, 04:55 AM   #1768
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
97 F degrees outside, R compounds, SC kit and I still managed to achieve 35-36 mpg on the highway ( cruise control set to 66 mph) when driving to track event
I had a chance to test the front splitter and @Wonderbar Driveway Labs T1 diffuser yesterday, woot! thanks @moto-mike for the revised map, car feels even smoother now
ambient temps were about 92 F+ degrees (a more robust oil cooler is a must at this point since my oil temps reached 280-290 F )
[ame="http://youtu.be/lqiiD42H0d0"]http://youtu.be/lqiiD42H0d0[/ame]
glamcem is offline   Reply With Quote
The Following 4 Users Say Thank You to glamcem For This Useful Post:
-AP- (07-26-2014), captain_jack (07-13-2014), JonAvalon (07-14-2014), loogs (07-13-2014)
Old 07-13-2014, 12:39 PM   #1769
SPCorBUST
SPCorBUST's Avatar
Awesome!
The Following User Says Thank You to SPCorBUST For This Useful Post:
glamcem (07-13-2014)
Old 07-13-2014, 06:59 PM   #1770
CSG Mike
CSG Mike's Avatar
Old 07-13-2014, 07:13 PM   #1771
glamcem
glamcem's Avatar
you were right Mike
Old 07-13-2014, 09:10 PM   #1772
CSG Mike
CSG Mike's Avatar
One thing you might want to consider is putting a fan behind the oil cooler, if you mount it in an odd location.
Even with a large oil-air cooler, boxer engines tend to cook the oil more due to cooling restrictions. I'd expect to see 240-250; that's what we see on track with our setup (and our cooler is LARGE). Part of this is due to the FMIC + aftermarket radiator setup. I suspect we'll have the temps back down to 225-230 once we put in an aftermarket fan on the passenger side.
Old 07-13-2014, 09:31 PM   #1773
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Which oil cooler do you have?
post_break is offline   Reply With Quote
Old 07-13-2014, 09:47 PM   #1774
glamcem
glamcem's Avatar
Forester XT OEM oil cooler, it was OK until the ambient temps reached 90+ degrees
Old 07-13-2014, 09:50 PM   #1775
post_break
post_break's Avatar
Yeah thats when I figured it would kind of crap out. I'm not going to track the car in this heat so I should be fine. Hopefully the kraftwerks oil cooler is able to keep up with you in this heat!
The Following User Says Thank You to post_break For This Useful Post:
glamcem (07-14-2014)
Old 07-14-2014, 04:35 AM   #1776
glamcem
glamcem's Avatar
oh no doubt about it, stacked plate oil coolers are great for that I knew they are more efficient even before I installed the OEM cooler but I had my own reasons I was testing something
Old 07-14-2014, 09:39 AM   #1777
Squishy
Drives: 2013 WRB BRZ
Anyone who cares about the longevity of the car beyond stop light sprints will get an oil cooler no matter what kind.
I am still waiting on getting my gauge cluster fixed before I mount my oil temp/pressure gauge. I suspect it is doing just fine as I do not sense any loss of power going home in rush hour. I am pretty proud myself and the effort I made to box in the radiator after the upgrade and loss of the stock air guides due to the intercooler. I am sure I could do better but it was a step in the right direction. Once I get the gauge cluster pod back and finish installing my new gauges, I will add any info about oil temps (note I am running ROBISPEC's radiator oil cooler).
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
The Following User Says Thank You to Squishy For This Useful Post:
CSG Mike (07-14-2014)
Old 07-14-2014, 02:45 PM   #1778
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Kraftwerks Supercharger Owners Thread
Well I got a chance to get over to Drift Office to get a baseline with my car and talk tuning with Bob. Here's third gear and forth gear pulls on my 6AT with the canned Kraftwerks Automatic Transmission tune.
List of relevant mods are :JDL UEL header, Nameless Performance 3inch OP/DP combo, Perrin 3 inch catback and Drive Shaft Shop aluminum drive shaft. And base Kraftwerks SC kit.
Freeman is offline   Reply With Quote
The Following 3 Users Say Thank You to Freeman For This Useful Post:
glamcem (07-14-2014), mit_peid (07-15-2014), Taino-BRZ (07-14-2014)
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
