Old 07-11-2014, 03:42 PM   #15
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
@D K what's your setup?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-12-2014, 12:31 AM   #16
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by D K View Post
I heard it directly from Rotrex.
That doesn't make any sense at all I wonder if you spoke someone from customer service because some of the people are clueless about the details about their products.. "Cogged belts are not recommended because they may not slip/fail as much" joking aside I would like to hear the reasoning behind that
glamcem is offline   Reply With Quote
Old 07-12-2014, 12:44 AM   #17
D K
Stig's dark passenger
Im not sure.
I spoke to the janitor.
D K is offline   Reply With Quote
Old 07-12-2014, 01:02 AM   #18
glamcem
glamcem's Avatar
Im not sure.
If that's the case, it should be correct because they know a lot better than customer reps..
I'm changing my belt tomorrow
Old 07-12-2014, 03:17 AM   #19
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I've fixed that for you
No rumours or crap, and the kit had one of the best tunes out there. The owner is pretty active if he would like to chime in thats up to him.
I wouldnt go talking shit about something if it was only rumours.
Old 07-12-2014, 03:22 AM   #20
D K
Cogged belts have an issue when you snap off the throttle.
Theynalso cause vibration to the internal planetary mechanism because the outside of the cog is larger than the inside, so you dont get the smooth transition that you get with a serpentine belt.
Rotrex or not, there are a lot of people having issues in a roadrace type of a situation.
Makes you wonder why the person who brought Rotrex into the US left KW and is using a non cogged application for their kits.
Just sayin'
Old 07-12-2014, 03:35 AM   #21
glamcem
glamcem's Avatar
Just sayin'
no issues here I personally like KW kit better and I don't really care who brought what.. that doesn't prove anything in my opinion, that person could be anyone who have enough funds and connections..
Old 07-12-2014, 05:07 AM   #22
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
One thing no ones asked.. To the OP do you plan on using your car in winter? Seeing how your location lists NY winters are real there. You should note KW does not make a thermostatically controlled engine oil cooler setup that works with their kit. Just something to consider in the whole process is all.
Old 07-12-2014, 09:19 AM   #23
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Didn't take long for the JR guys to show up
Freeman is offline   Reply With Quote
Old 07-12-2014, 09:24 AM   #24
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
To add to that, the elusive non-thermostatic skunk2 oil cooler adapter plate is still not officially for sale yet as far as I know. It's the only adapter that works with the kit since the giant SC mounting bracket blocks all traditional style sandwich plates. Apparently KW do not have plans to make a full plug and play oil cooler kit with lines and core with mounting solution. Those who have asked have been told by KW to figure it out themselves.
Old 07-12-2014, 09:31 AM   #25
8686
8686's Avatar
Drives: 86
Just to confirm my understanding.
I have to remove my mashimoto oil cooler if I want to use KW super charger?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 07-12-2014, 09:35 AM   #26
ATL BRZ
ATL BRZ's Avatar
That's correct. You would have to run without an oil cooler until KW release their proprietary adapter plate. Then you'd have to figure out the lines, core, and mounting solution yourself.
Old 07-12-2014, 12:23 PM   #27
loogs
Drives: on cruise control
i was going to get the kit and use the mishimoto oil cooler. this all seems pretty random. ive seen and heard from so many KW SC owners and none of them have anything bad to say.
loogs is offline   Reply With Quote
Old 07-12-2014, 12:30 PM   #28
Freeman
Freeman's Avatar
FYI call and order the oil cooler sandwich plate if you want it. It's that easy.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
F/S Kraftwerks supercharger kit captain_jack Engine, Exhaust, Bolt-Ons 27 06-10-2014 10:34 AM
Kraftwerks Supercharger kit-Now stocked at JRP Stav Canada Classifieds 4 05-27-2014 09:07 PM
KraftWerks SuperCharger Ocho Seis CANADA 18 04-06-2014 10:33 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
