Old 07-08-2014, 05:04 PM   #2045
teamxplizt
teamxplizt's Avatar
Drives: Seibon Style BRZ
Originally Posted by EpicNameBro View Post
As a former resident I can tell you that they are really relaxed compared to California. You will pass smog as long as you don't have a CEL. Most shops don't even do a visual they just plug it into their computer do a run... no CEL=pass...
Great. Thanks for the info!
Aloha,
Ace
http://66.230.196.147/*teamxplizt.org/httpdocs/images/TXP_BRZ.jpg
teamxplizt is offline
Old 07-08-2014, 07:41 PM   #2046
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
Originally Posted by FR-S Matt View Post
This code can be caused by even a high flow catted header. If this is one of the typical magnaflow high flow cats that most companies use, they let a lot of flow through. Just because it's catted doesn't mean it will act like your stock header.
When sensor 2's flow matches sensor 1's, the chance of a CEL is high for P0420. You'll typically see this while cruising, and not spirited driving. This even happens on catless headers. Same concept for either. The only way to truly eliminate it is a tune, otherwise, floor it everywhere you go and don't cruise at one speed. If you're someone that city drives a lot, you probably won't see a CEL. It's the highway drivers it catches due to the closed loop.
My CEL came on today for the second time while on the highway. I typically drive only city so maybe this is my issue. I still need to get the code scanned. I'll report back.
fender9530 is offline
Old 07-08-2014, 07:48 PM   #2047
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Originally Posted by STV3 View Post
Aaaannndd.... My CEL came right back on again on my lunch break just now. 5 min cruise on the highway.
If there is nothing wrong with my cat when I inspect it. I guess I'll try using a defouler.
Have you gotten the code checked? Or are you assuming?
Fett4Real is offline
Old 07-08-2014, 07:51 PM   #2048
STV3
Señor Member
STV3's Avatar
Checked it the first two times it came on and it was P0420 both times. These past two times I have not checked. I'd say its pretty safe to assume at this point though.
STV3 is offline
Old 07-12-2014, 04:38 AM   #2049
teamxplizt
teamxplizt's Avatar
Installed my UEL headers and my CEL is on too. So where do we go from here??
Thanks,
Ace
Old 07-12-2014, 04:52 AM   #2050
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Thanks,
Ace
Read the code to see which code it is throwing. If you just installed it, there may be a leak somewhere if it threw it right away.
husker741 is offline
The Following User Says Thank You to husker741 For This Useful Post:
teamxplizt (07-12-2014)
Old 07-12-2014, 09:36 AM   #2051
fender9530
fender9530's Avatar
Thanks,
Ace
That's not a common issue. Def recheck everything.
The Following User Says Thank You to fender9530 For This Useful Post:
Old 07-12-2014, 05:28 PM   #2052
teamxplizt
teamxplizt's Avatar
I will give it a shot later on today. Thanks!
Old 07-12-2014, 05:56 PM   #2053
kodyo
Drives: Scion FR-S
If mine throws CEL, I plan to go with open flash tablet, so that's an option. Probably get even more power too.
kodyo is offline
Old 07-12-2014, 07:09 PM   #2054
teamxplizt
teamxplizt's Avatar
Thanks,
Ace
***Status update***
Woke up this morning and rather than taking things apart, I decided to start by unplugged both O2 sensors and then re-plugging them back in...It worked! As of now, no CEL.
Old 07-12-2014, 07:29 PM   #2055
jonbonazza
I had CEL on install too way back when. Tune took care of it.
jonbonazza is offline
Old 07-17-2014, 01:41 AM   #2056
teamxplizt
teamxplizt's Avatar
Here are some minor sound clips I made today. Will work on drive by and in cabin sound clips in a bit.
[ame]http://youtu.be/O_OcLHFKUMY[/ame]
The Following 2 Users Say Thank You to teamxplizt For This Useful Post:
akahenry (07-17-2014), JonAvalon (07-17-2014)
Old 07-17-2014, 02:59 AM   #2057
chas3wba0
chas3wba0's Avatar
Drives: Yes
Love it. I like especially how this header gives a more muffled rumble, unlike the hollower sound from the catless ones. Sounds more like the STi's that we are trying so hard to mimic
Installing mine this Saturday so more sound vids to come...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
The Following User Says Thank You to chas3wba0 For This Useful Post:
teamxplizt (07-21-2014)
Old 07-17-2014, 08:28 AM   #2058
Fizzo
Fizzo's Avatar
Drives: Rocket Bunny GT86
Ordered today, god knows how long this is gonna take
Raven Rocket Bunny GT86 in Dubai
Fizzo is offline
The Following User Says Thank You to Fizzo For This Useful Post:
Re~Mix (07-17-2014)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
