#71 |
Drives: 2013 FRS
The factory sensor isn't a true wideband. Not is it a narrow band. It's a broad response narrow band sensor that is reasonable accurate down to ~11.5 or so. This is why the o2 sensor calibration doesn't extend downwards to the 10:1 as a true wideband sensor/controller would.
#72 |
Erected Member
Drives: frs
Hey shiv, just wondering about the v2.0 beta maps for the esc+1.5dump.
the A01C file looks kinda iffy O_o.. is it suppose to look like that in romraider?
#73 |
Drives: 2013 FRS
| The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post: | shif7i7down (07-12-2014), sw20kosh (07-12-2014) |
#74 |
Drives: WRBrz
Just had a pretty rough start... Starter motor would click over atleast 10 times before the car would fire up... Gonna wait and see if it happens again before I flash back
Edit: It took about 2.5 times longer than normal to start. The idle-hunting while A/C is on hasn't come back so far as I can tell.
EBSC - dt.FF - MXP CompRS
#75 |
Was everyone able to tell a noticeable difference when upgrading from the ESC 1.0 to the 1.5? I'm right on the fence of upgrading.
#76 | |
Drives: Passat
I suppose you can call it whatever you want but Denso calls it a Air/Fuel Ratio Sensor and it has no more in common with a narrow band sensor than a Bosch "true wideband" sensor does. On my previous Scion XB the Denso ECU was able to read the Denso AFR sensor down to ~9:1 (converted from lambda). Perhaps the sensor isn't very accurate below 12:1 but all I said was that it is capable of reading richer than 11:1. Last edited by Fast_Freddy; 07-12-2014 at 01:06 AM. |
#77 |
Umm OK. Reads richer but grossly inaccurate, still useless but totally something to argue about.
#78 |
Time Traveller
#79 |
Drives: Passat
#80 |
Sure, enjoy your modified borla header and visconti tune without logging but then again, inaccurate doesn't mean useless to you so yeah.
#81 |
Drives: Passat
#82 |
Neither of those are accurate, but hey, it floats your boat.
#83 |
Drives: 2013 Asphalt 6spd
as much as I don't want to add fuel to the fire, my factory log afr pegs out at 12.17 the whole time I am wot.
![]() I haven't logged my stage 1 oft tune yet, but with it pegged out, how would I know if I am at 11:1 or even richer? *edit, or maybe my stock tune is just locked at 12.17 as other peoples logs go below that, and stock tune is crap and I don't know what I'm doing. Last edited by Target70; 07-12-2014 at 07:25 AM. |
#84 | |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I am still on the stock header. And I made a mistake - I hit write on the tablet while the ignition was still on. Is that a error that must be corrected? The tune seems to be working alright. The idle seems much smoother. I don't know if I can tell a power difference or not, but the engine seems to sound a bit different, too. Here's a log that has a 2nd gear pull and two 3rd gear pulls 80 degrees F, 80% humidity: http://datazap.me/u/robwbright/71414...og=0&data=7-12 Everything look alright? I see a max boost of 4.79. Should I re-flash the tune with the ignition off? Thanks, guys! And especially thanks, Shiv!
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
| Phantom TQ250 Dyno FBO (Dual Battery Pack) | Shiv@Openflash | Forced Induction | 23 | 04-29-2014 02:40 AM |
| Clutch dump at 5000 RPM? | fasteddy | BRZ First-Gen (2012+) — General Topics | 20 | 08-22-2013 01:55 PM |
| External dump and under tray? | mrk1 | Forced Induction | 5 | 07-30-2013 09:43 AM |
| Photo dump. | CanibeatNoel | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 07-17-2013 02:47 AM |
| Ricepuddin Picture Dump | Ricepuddin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 12-03-2012 12:18 AM |
