Old 07-11-2014, 05:53 PM   #71
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Fast_Freddy View Post
Wrong on both counts. Our Denso "AFR sensor" is a wide band and can read richer than 11.02:1. The resolution limit in this case is the software.
The factory sensor isn't a true wideband. Not is it a narrow band. It's a broad response narrow band sensor that is reasonable accurate down to ~11.5 or so. This is why the o2 sensor calibration doesn't extend downwards to the 10:1 as a true wideband sensor/controller would.
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-11-2014), Khyron686 (07-11-2014)
Old 07-11-2014, 07:09 PM   #72
shif7i7down
Erected Member
Drives: frs
Hey shiv, just wondering about the v2.0 beta maps for the esc+1.5dump.
the A01C file looks kinda iffy O_o.. is it suppose to look like that in romraider?
shif7i7down is offline   Reply With Quote
Old 07-11-2014, 08:00 PM   #73
Shiv@Openflash
Drives: 2013 FRS
You will need a new XML file for the v2.0 maps. Please do not try to edit until we provide this
shif7i7down (07-12-2014), sw20kosh (07-12-2014)
Old 07-11-2014, 09:21 PM   #74
WRB5titch
Drives: WRBrz
Just had a pretty rough start... Starter motor would click over atleast 10 times before the car would fire up... Gonna wait and see if it happens again before I flash back
Edit: It took about 2.5 times longer than normal to start. The idle-hunting while A/C is on hasn't come back so far as I can tell.
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 07-11-2014, 10:23 PM   #75
Urmyson
Was everyone able to tell a noticeable difference when upgrading from the ESC 1.0 to the 1.5? I'm right on the fence of upgrading.
Urmyson is offline   Reply With Quote
Old 07-12-2014, 12:52 AM   #76
Fast_Freddy
Drives: Passat
I suppose you can call it whatever you want but Denso calls it a Air/Fuel Ratio Sensor and it has no more in common with a narrow band sensor than a Bosch "true wideband" sensor does.
On my previous Scion XB the Denso ECU was able to read the Denso AFR sensor down to ~9:1 (converted from lambda). Perhaps the sensor isn't very accurate below 12:1 but all I said was that it is capable of reading richer than 11:1.
Fast_Freddy is offline   Reply With Quote
Old 07-12-2014, 02:43 AM   #77
s2d4
s2d4's Avatar
Umm OK. Reads richer but grossly inaccurate, still useless but totally something to argue about.
Old 07-12-2014, 02:47 AM   #78
DAEMANO
Time Traveller
A resounding YES. No other power mod for the price will touches it.
Old 07-12-2014, 03:00 AM   #79
Fast_Freddy
Drives: Passat
Not "grossly inaccurate" or "useless" but thanks anyway for your typically inaccurate and useless commentary.
Old 07-12-2014, 03:08 AM   #80
s2d4
s2d4's Avatar
Sure, enjoy your modified borla header and visconti tune without logging but then again, inaccurate doesn't mean useless to you so yeah.
Old 07-12-2014, 03:15 AM   #81
Fast_Freddy
Drives: Passat
Sure, enjoy your modified borla header and visconti tune without logging.
I am, thanks. Enjoy your toy e-charger and richer than 11:1 OFT tune.
Sorry, are you done editing yet?
Old 07-12-2014, 03:16 AM   #82
s2d4
s2d4's Avatar
Neither of those are accurate, but hey, it floats your boat.
Old 07-12-2014, 07:13 AM   #83
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
as much as I don't want to add fuel to the fire, my factory log afr pegs out at 12.17 the whole time I am wot.
I haven't logged my stage 1 oft tune yet, but with it pegged out, how would I know if I am at 11:1 or even richer?
*edit, or maybe my stock tune is just locked at 12.17 as other peoples logs go below that, and stock tune is crap and I don't know what I'm doing.
Target70 is offline   Reply With Quote
Old 07-14-2014, 08:04 PM   #84
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by Shiv@Openflash View Post
Hi guys,
Thanks to Rob and Phantom, we've been rocking the 1.5 dump pack on our shop FR-S. The extra boost necessitated some revisions to our single dump pack OTS maps. More fuel, a bit more timing, revised engine load limits, and some changes to open/closed fuel settings.
Those running the old single dump pack maps on their 1.5 dump pack set-ups will notice a nice bump in power and smoother overall performance-- especially in the low end.
Cheers,
Shiv
I've been off the forum for weeks - a lot going on - but I decided to check in and see if there was a new 1.5 map... low and behold, I've been missing out for the last 10 days!
I am still on the stock header. And I made a mistake - I hit write on the tablet while the ignition was still on. Is that a error that must be corrected? The tune seems to be working alright. The idle seems much smoother. I don't know if I can tell a power difference or not, but the engine seems to sound a bit different, too.
Here's a log that has a 2nd gear pull and two 3rd gear pulls 80 degrees F, 80% humidity:
http://datazap.me/u/robwbright/71414...og=0&data=7-12
Everything look alright? I see a max boost of 4.79.
Should I re-flash the tune with the ignition off?
Thanks, guys! And especially thanks, Shiv!
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
