Old 04-30-2014, 05:13 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Adjusting radiator fan temps
First, do you think that kicking the radiator fans on at lower coolant temps would be a good idea?
Second can anyone interpret these tables?
I was reading a post on NAOSIC that kinda explained it but I still don't know what the fan modes are exactly (http://forums.nasioc.com/forums/show....php?t=1828462)
The Following User Says Thank You to ML For This Useful Post:
86ft.lb (08-01-2014)
Old 04-30-2014, 05:52 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
This would need to be coupled with a lower temperature thermostat, or else the fans would likely be running constantly and not really doing much.
On topic of lower temp thermostats, I'm not a fan (pun intended)
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-10-2014, 01:25 AM   #3
fstlane
fstlane's Avatar
Drives: BRZ Limited
I used the NASIOC link as a guide and came up with these fan profiles. Both fans should be set on by 200°F regardless of whether the a/c is on or not. @Dezoris mentioned in a post he's been running a similar 200°F fan profile both on and off track for 7 months with no I'll effect.
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
ML (07-10-2014)
Old 07-10-2014, 09:20 AM   #4
ML
ML's Avatar
Originally Posted by fstlane View Post
I used the NASIOC link as a guide and came up with these fan profiles. Both fans should be set on by 200°F regardless of whether the a/c is on or not. Dezoris mentioned in a post he's been running a similar 200°F fan profile both on and off track for 7 months with no I'll effect.
Any positive effects noticed?
Old 07-10-2014, 10:23 AM   #5
charged86
charged86's Avatar
i would like to know the wire that activates so i could have and external switch for track days. turn it on with the hood up. sounds dumb but it will move that hot air around which is smart.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-10-2014, 11:57 AM   #6
nelsmar
I lower these values on my own car as my intercooler heatsoaks at idle from the extreme pavement temperatures in phoenix even if my coolant temp is acceptable. Leaving the fan running non stop will keep my IAT lower and keep air flowing through my bay.
My flickr - Canibeat
Local magazine scout
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Dezoris (07-10-2014), fstlane (07-10-2014)
Old 07-10-2014, 01:06 PM   #7
Dezoris
Dezoris's Avatar
The biggest issue is idle scenarios for most users.
Car sits and builds heat fast with the sealed bay.
Stock Fan Activation 212F
So normal cruising temps in my testing. (8 months)
Coolant: 190F-197F
Oil: 190-205F
IAT: 70-115F (Depending on conditions)
Once you come to a idle stop with normal fan activation points:
Coolant: 200-213F
Oil: 195-215F
IAT: 100-130F
Lowering the coolant fan activation point to 200F drops these idle numbers down about 10-15F during idle and keeps the fans on solid during track operation keeping coolant temps lower. If you have an liquid to air oil cooler up front there are big reductions in oil temps from this as much as 10-20F depending on the core during a 20-30 minute track session.
Idle Temps with 200F Fan Activation:
Coolant: 194-202F
Oil: 190-200F
IAT: 90-120F
IMPORTANT
Setting the temp any lower than 200F will likely cause it to run all the time which clearly is stress on the fan motors. You will only see 200F coolant temps during harder runs and idling. But normal cruising with airflow temps usually stabilize between 190-197F.
The Following 8 Users Say Thank You to Dezoris For This Useful Post:
civicdrivr (01-05-2015), FRSBRZGT86FAN (04-14-2016), fstlane (07-10-2014), kombatlion (07-15-2014), ML (07-10-2014), sato (07-18-2014), Thorpedo (10-23-2014), Wayno (10-23-2014)
Old 07-10-2014, 03:13 PM   #8
ML
ML's Avatar
Coolant: 190F-197F
Oil: 190-205F
Coolant: 200-213F
Oil: 195-215F
IAT: 100-130F
Coolant: 194-202F
Oil: 190-200F
IAT: 90-120F
IMPORTANT
Are you on stock rad?
Old 07-10-2014, 04:16 PM   #9
Dezoris
Dezoris's Avatar
Part of the testing I was, the numbers are similar except the recover time is much faster with Koyo after fans cycle on.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 07-15-2014, 12:23 PM   #10
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
So how we set the fans to 200F?
kombatlion is offline   Reply With Quote
Old 07-15-2014, 04:30 PM   #11
ML
ML's Avatar
If you have to ask, you probably shouldn't. All the info is in this thread.
Old 07-18-2014, 11:45 AM   #12
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
You could have told me: take it to your ecutek tunner he can do it... but thanks anyway!
Old 07-18-2014, 12:48 PM   #13
ML
ML's Avatar
kombatlion (07-21-2014)
Old 08-19-2014, 04:06 PM   #14
sw20kosh
Drives: 2013 Black FR-S
Coolant: 190F-197F
Oil: 190-205F
Coolant: 200-213F
Oil: 195-215F
IAT: 100-130F
Coolant: 194-202F
Oil: 190-200F
IAT: 90-120F
IMPORTANT
Do you know for certain that the fans stay on at track speeds? Genuinely curious if upgrading the fans to higher CFM units will help at all with 230+ coolant temps I am seeing on track.
Adjusting headlights hansthegerman Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-09-2017 11:39 PM
Adjusting the base on coilovers Turdinator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-11-2014 09:56 PM
Adjusting to FR-S Clutch. Mandy Scion FR-S / Toyota 86 GT86 General Forum 19 02-09-2013 01:24 AM
Adjusting Speedo to new tires ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 12-16-2012 12:31 PM
Adjusting the Rearview Mirror pinoyplaya BRZ First-Gen (2012+) — General Topics 2 08-24-2012 11:45 AM
