Old 07-08-2014, 04:42 PM   #99
steve99
Drives: FT86
Originally Posted by Malt View Post
I had massive issues with cold starting when I was running E85 in the winter and I had loads of help from TD-d and several others. I eventually got it cranking with 2-3 cranks at temperatures below 40 by playing with pulse widths but after my recent attempts of MAF scaling on the 1.5x maps I think the issue is more with the MAF temperature scaling more than injector pulse width. I can see a definite change in trims when the temperature is in the high 90's as opposed to the 60's and 70's. Personally I think if people properly scaled their MAF for their car and mods and someone came up with a modified MAF temp scale adjustment that was more accurate over stock these issues would be resolved for most people. For me it was just simpler to swap back to 93 as there is only one station near me that sales E85 and it wasn't exactly on my way to my typical destinations. I could just be the station I was filling up with had a bad fill of E85 or the percentage was to high for cold temps. I never tried adding a couple gallons of 93 to the tank, which might of fixed my issues.
Either way I won't be using E85 in the winter, it just wasn't worth it to me.
Thanks,
I got cold start issues(2 cranks)here once temps got below 15C but I was using E85 that was actually E85 (tests E90) so had to dilute it down with 5 litres of 98 RON petrol per tank and it started fine. We also have the E85 E-flex fuel available here and its probably better suited to us NA guys as its E% is around E65-E70 so little or no starting issues. The other United E85 is rarely good for the boosted guys who need the higher E% and more consistent E values. Unfortunatly for me (like you) the E-flex station is a long way away, the closest station only sells the high E% stuff.
The other good thing was at the lower E% you get better fuel mileage
Old 07-08-2014, 09:06 PM   #100
wparsons
wparsons's Avatar
Originally Posted by mid_life_crisis View Post
I hope someone is testing with 93.
The beta maps are the 91 maps for now, so testing with 93 isn't a good actual test. Once the 93 maps are released (beta or public) it'll be good to get feedback on them.
flickr
Old 07-09-2014, 04:31 AM   #101
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Not rearly.
Its possible the new E85 tunes will alter the cranking injector pulse width to inject more fuel to make cold weather starting easier on E85 without having to add some straight petrol to dilute the E%.
A couple of guys such as luckrider have already done this with success.
was actually a fair and relevant question :-)
Sorry, I actually meant just this part "cold winter mornings in Sydney" which sounds funny to me
For me cold start is when it's below -25C but I had no problems last two winters (on RON98 though - don't have E85 here)
Efferalgan is offline   Reply With Quote
Old 07-09-2014, 04:53 AM   #102
steve99
Drives: FT86
if it gets below +5c here we think next ice age is coming
Old 07-10-2014, 04:35 PM   #103
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Talking v2.0 OTS maps
I just set out a email to the beta tester mailing list
Shiv@Openflash is offline   Reply With Quote
Old 07-10-2014, 04:43 PM   #104
phrosty
2.0 already?
phrosty is offline   Reply With Quote
Old 07-10-2014, 04:44 PM   #105
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by phrosty View Post
2.0 already?
Yes, all based on the latest and greatest factory B01C and BO1D software. With fully functional Launch Control and Flat-Foot Shift
Old 07-10-2014, 04:46 PM   #106
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
So no need to turn them on, just load and go?
Old 07-10-2014, 04:49 PM   #107
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
I have hard starts even on 70 degree mornings.
Tenchi is offline   Reply With Quote
Old 07-10-2014, 04:52 PM   #108
Shiv@Openflash
Drives: 2013 FRS
It's all documented in the Release Notes. But it's just like it's always been. By default, Launch Control is set to 5500rpm. Flat-Foot Shift is OFF (set to 0RPM). But can be adjusted as the user sees fit by using the correct XML file (which I have not released yet).
Old 07-10-2014, 09:26 PM   #109
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Woohoo!
Old 07-10-2014, 10:33 PM   #110
vynervt
Drives: GT-86
Any chances for international OFT user to be the tester for the V 1.60 or V 2.0??
vynervt is offline   Reply With Quote
Old 07-10-2014, 10:44 PM   #111
Vmax911
Drives: WRB BRZ
That's pretty awesome! I've been rocking my 1.5x tune with modified timing tables to account for 91 octane at 5000ft. I've been holding a solid IAM of 1.0 for the last few tanks, can't wait to do it all over again with the new version! LOL!
Vmax911 is offline   Reply With Quote
Old 07-10-2014, 10:46 PM   #112
Shiv@Openflash
Drives: 2013 FRS
International folks will be able to test v2.0 very soon
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet: USDM Stage 2 EL/UEL testers needed Shiv@Openflash Software Tuning 13 01-05-2014 12:42 AM
