Old 07-08-2014, 07:40 PM   #1401
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Just make sure you download the romRaider definition files from the OFT site as the ones from romraider/github don't have the LC/FFS parameters as the OFT ROM's have a patch to code to insert these extra features.
to disable just set the LC delta to zero "0" and the FFS Delta to "0".
Thanks, I'll do that.
After I look up/research about half those words
Target70 is offline   Reply With Quote
Old 07-08-2014, 08:28 PM   #1402
Wankel Rex
Wankel Rex's Avatar
Drives: Silver Premium Edition BRZ
Originally Posted by Shutter View Post
This and no lift/wot shifting feature we're the only issues I had...for me it was more annoying because I had my launch set to 4k.
As far as I know, the only way to "disable" it is by disabling the launch control.
I am 99.999% certain I could rev all the way to red line on the Stage 1 tune as long as I was in neutral and had my foot off the clutch. Shortly after the tune I was at the DFW Cars & Coffee and first discovered the LC limit when rolling in first with the clutch in.
Wankel Rex is offline   Reply With Quote
Old 07-08-2014, 08:39 PM   #1403
steve99
Drives: FT86
I think you discovered the FFS rpm limit rather than the LC limit.
FFS limit active when clutch depressed
LC limit active (if set) if car doing less than the LC disable speed regardless of clutch or gear selection.
the LC limit is definitly active at a standstill with a gear selected thats the whole point of LC :-)
Old 07-08-2014, 09:23 PM   #1404
Daesondei
Daesondei
Drives: Scion FRS
Originally Posted by Trettiosjuan View Post
IMHO gimmicks that detract from the purity of the car...
??? since when did tuning or modifying a vehicle become a gimmick? increased horsepower and drivability is something all ft86 owners can benefit from. I promise if you test drive someones car with an e85 tune then, you will understand...
Sent from my SAMSUNG-SGH-I577 using Tapatalk 2
"No greater love is this, than a man laying down his life for his friends... I call you friends."
Daesondei is offline   Reply With Quote
Old 07-08-2014, 09:35 PM   #1405
steve99
Drives: FT86
I think they were refering to Launch control and Flat foot shift
Trettiosjuan (07-09-2014)
Old 07-09-2014, 06:49 AM   #1406
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
So quick question...anyone running a vortech sc with the OFT OTS map...if so how is it? I'm starting to look at the vortech SC since I already have OFT. Just wondering what kind of numbers people are pulling?
Triumphrider is offline   Reply With Quote
Old 07-09-2014, 05:47 PM   #1407
Daesondei
Daesondei
Drives: Scion FRS
Apologies. I just love this setup and will always endorse it, and there are always a few people out there that speculate from an ignorant perspective. I miss read that post, doh!:beer:
The Following 2 Users Say Thank You to Daesondei For This Useful Post:
steve99 (07-09-2014), Trettiosjuan (07-09-2014)
Old 07-09-2014, 10:33 PM   #1408
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Took a look through a lot of the tables out of sheer boredom waiting for my OFT... It's very different than what I'm used to (MegaSquirt), heh.
I noticed something that seems slightly odd in the idle speed tables of what seems to be every map in the 1.59 maps. Is there a reason that the 140* column is a higher idle target than the 122* column? Heck, I don't even know when this idle table is used...
Old 07-09-2014, 10:52 PM   #1409
steve99
Drives: FT86
can't think of one reckon it a typo
Imagine they just copy/paste data to maps, pretty sure the 700c 900C A00C A01C maps the same just the calid changes and they are all actually based on A01c calibration. Then they just alter the calid so the oft will load the map corresponding to your calid as the OFT will only load a map with matching calid. In this way the guys on older calid's actually update to latest calid even though the calid shown in map is the original.
Old 07-12-2014, 07:49 PM   #1410
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
hmm. I guess it takes a while for the ECU to re-learn the throttle pedal? First 1/4" at least literally does nothing, doesn't even register. Torque dip is massively reduced and the powerband definitely feels smoother.
I'm a bit less than satisfied (a bit of an understatement, to be honest) with the quality of the OFT and cables, but I guess we're paying more for the programming than anything else.
Old 07-12-2014, 08:24 PM   #1411
Semprini
Spline Reticulator
Semprini's Avatar
Drives: 2013 FR-S Whiteout
@DocWalt That is normal for the throttle. I had the same thing when I reset my ecu for an intake change.
Johnny was a chemist's son, but Johnny is no more.
What he thought was H2O was H2SO4.
Semprini is offline   Reply With Quote
The Following User Says Thank You to Semprini For This Useful Post:
DocWalt (07-12-2014)
Old 07-12-2014, 08:45 PM   #1412
Wankel Rex
Wankel Rex's Avatar
Yep. Both my Stage 1 and Stage 2 tunes had this for a short while. Almost stalled pulling away from stops the first little while.
The Following User Says Thank You to Wankel Rex For This Useful Post:
Old 07-12-2014, 09:47 PM   #1413
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Figured. Didn't go away with ~10 minutes of tooling around, so I was slightly concerned. Any idea how long it takes to go back to normal?
Old 07-12-2014, 09:59 PM   #1414
cnk
Drives: '13 DGM BRZ Limited
After flashing the ecu, turn car on but don't start the engine. Fully depress and release the gas pedal 10-20 times. Turn off ignition. Start car normally and you're good to go with no dead pedal feeling.
Sent from my Transformer using Tapatalk
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
