Old 07-01-2014, 05:40 PM   #2031
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Originally Posted by chas3wba0 View Post
So are there any OFT maps specifically for this header yet?
No... but Stage 2 map works very well. I've been running it for 3 weeks or so now.
355rockit is offline
The Following 3 Users Say Thank You to 355rockit For This Useful Post:
CamryDS (07-02-2014), chas3wba0 (07-01-2014), Kronos (07-01-2014)
Old 07-01-2014, 06:42 PM   #2032
s2d4
s2d4's Avatar
Logs bro.
s2d4 is offline
Old 07-01-2014, 06:49 PM   #2033
calibrz
Turbo 86
Drives: GT86
Originally Posted by STV3 View Post
CEL came right back again (-__-)... Gonna check maybe tomorrow or Monday under the car for any leaks or cracks
no see CEL after install. werid
10 - 1 = 0
real math
calibrz is offline
Old 07-01-2014, 10:22 PM   #2034
355rockit
Originally Posted by s2d4 View Post
Logs bro.
No time...
Old 07-01-2014, 10:55 PM   #2035
s2d4
s2d4's Avatar
No time...
You can set it up to log within the start up period, and only takes 1 tap to stop logging. A couple of minutes for getting the log off the tablet then upload it.
How do you know it is running fine?
s2d4 is offline
Old 07-04-2014, 06:08 AM   #2036
Trettiosjuan
Drives: GT86
Some logs would be really appreciated. Wasn't going to remap but now want to run it on E85...
Trettiosjuan is offline
Old 07-08-2014, 10:09 AM   #2037
nunonuna
nunonuna's Avatar
Well..... My car just threw a CEL :-\. P0420, going to reset it and see if it comes back.
Any updates?
Was it related to this header? Or else?
nunonuna is offline
Old 07-08-2014, 10:33 AM   #2038
STV3
Señor Member
STV3's Avatar
Originally Posted by nunonuna View Post
Any updates?
Nothing yet. Had a little time this past weekend to take a quick look at it. Got under the car and dropped the skid plate and inspected everything and couldn't find anything. No leaks, cracks, loose bolts, etc..
I reset the ECU again and am going to wait and see how long before the CEL comes back. If I have time this weekend I'll pull the header off and inspect inside the cat to see if anything looks out of the ordinary. If all looks ok inside the cat my only other guess would be my secondary O2 sensor. My car only has a little over 10k miles on it so I can't imagine an O2 sensor going bad already, but you never know.
Last resort will be to put the stock header back on and see if the CEL comes back and then go from there.
BTW, Anyone know how to test an O2 sensor to see if it is bad?
STV3 is offline
Old 07-08-2014, 10:48 AM   #2039
tennisfreak
Drives: 2018 BMW M240i
If the cat went out in the header would that cause a CEL?
tennisfreak is offline
Old 07-08-2014, 11:08 AM   #2040
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
It may in the secondary O2 sensor- a P0420 most likely.
What is the CEL code you're getting? (Sorry, I didn't see if it was posted earlier). Autozone or some place will read it for you for free if you don't have a code scanner.
Jyn is offline
Old 07-08-2014, 11:20 AM   #2041
FR-S Matt
This code can be caused by even a high flow catted header. If this is one of the typical magnaflow high flow cats that most companies use, they let a lot of flow through. Just because it's catted doesn't mean it will act like your stock header.
When sensor 2's flow matches sensor 1's, the chance of a CEL is high for P0420. You'll typically see this while cruising, and not spirited driving. This even happens on catless headers. Same concept for either. The only way to truly eliminate it is a tune, otherwise, floor it everywhere you go and don't cruise at one speed. If you're someone that city drives a lot, you probably won't see a CEL. It's the highway drivers it catches due to the closed loop.
FR-S Matt is offline
The Following User Says Thank You to FR-S Matt For This Useful Post:
chas3wba0 (07-08-2014)
Old 07-08-2014, 11:43 AM   #2042
Luis_GT
Spark plug defoulers can help mitigate it... I did that on my bimmer and havent had a cat related cel in 10k miles with my catless headers
Luis_GT is offline
Old 07-08-2014, 12:41 PM   #2043
FR-S Matt
Yeah, they reduce the chance by a good amount. The risk is always there, but it really does depend on how the car is driven before the ECU throws a code.
I went hundreds of miles on my JDL UEL till I went on an hour drive with cruise control only to realize my secondary O2 wasn't disabled in Ecutek, lol. It is now, but I thought it was to begin with.
With my '02 Camaro SS, the primaries were deleted and extension wires were used to the secondary O2's and those were set as the primaries to dodge the CEL on those. Not sure if many people have tried the extensions, but I think it would be a pain wiring these since it's only 1 header.
Luis_GT (07-08-2014)
Old 07-08-2014, 01:33 PM   #2044
STV3
Señor Member
STV3's Avatar
Aaaannndd.... My CEL came right back on again on my lunch break just now. 5 min cruise on the highway.
If there is nothing wrong with my cat when I inspect it. I guess I'll try using a defouler.
STV3 is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
