#15 |
Drives: Moped
A compact V8 sounds tempting...either way, can't wait to see what you decide to do...
#17 |
It's the Mad Cow
I'm worried about that to
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#18 |
in orbe terrum non visi
Drives: violent
There's a thread titled something like "why do people do swaps" that has corner weights for a ls swapped frs. Very much worth it.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | Sportsguy83 (07-07-2014) |
#19 |
Drives: Scion FRS
We have build many FA20 motors. Our motors have been tested extensively. If you have any questions please let us know. Our short blocks does not use any off the shelf parts. All of the components in our blocks are custom to our specs.
#20 |
Drives: violent
I want a fullblown shortblock so bad.
#21 |
It's the Mad Cow
I want a motor that's the same compression ratio as stock basically with forged rods, pistons and head studs that's pretty much it.
#22 |
I Love custom Turbo kits
Drives: Limited BRZ
LSx engines are not "heavy", just a few pounds heavier than FA20 + turbo kit.
@Pure Automotive @Cross I would do the swap if you trust this local shop and will be left a car that all stock components work. 400+ whp N/A >>> 500+ whp Turbo.
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
#23 | |
| The Following User Says Thank You to s2d4 For This Useful Post: | Sportsguy83 (07-07-2014) |
#24 |
Drives: Limited BRZ
At least from quick research I did online on LS1 and LS3 weight, they seemed really close.
I still might be completely wrong....
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | s2d4 (07-07-2014) |
#25 | |
Should be fun either ways.
| The Following 2 Users Say Thank You to s2d4 For This Useful Post: | Astroboy (09-22-2014), Sportsguy83 (07-07-2014) |
#26 |
Drives: Limited BRZ
Yea if its iron block F*ck that....
#27 |
Automotive Connoisseur
Drives: too many cars
All LS1s are aluminum blocks. The truck variants of the LS series have iron blocks (but not all truck variants were Iron either). The LS engines in Aluminum are all pretty light at the end of the day for what they are. Depending on how the swap is done the weight distribution can be decently maintained.
LSx Powered 86/ASE Master Certified Automotive Technician
| The Following 4 Users Say Thank You to AZFA20 For This Useful Post: |
#28 |
NASA SpecE30 Racer
If you have oil in your engine bay, then my guess is that you "windowed" the block. I look forward to the details so I can add you to my list. @nelsmar is the only one I know with a built motor running relatively high compression, but I believe you two don't get along too well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | 86-tundra (07-23-2014) |
| 'Sloane' - Cali first time build | Re~Mix | Member's Car Journals | 6 | 06-24-2015 08:22 PM |
| The time attack build by Rob | SavingManuals | Member's Car Journals | 8 | 04-27-2014 08:01 PM |
| Adventure Time! (E.Ts BRZ/86 Build) | E.T | Member's Car Journals | 4 | 01-20-2014 01:02 AM |
| Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 05:27 AM |
| New FRS owner.. time for a build? | sero901 | Forced Induction | 5 | 10-24-2013 09:40 PM |
