Old 06-25-2014, 04:02 PM   #29
Roxy86
Roxy86's Avatar
Drives: Diesel daily / FR-S
Nice!
Is it just me or is everyone going FI?!
Roxy86 is offline   Reply With Quote
Old 06-25-2014, 06:10 PM   #30
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Originally Posted by Roxy86 View Post
Nice!
yes but only the cool kids do it on jackstands
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
protpibe (06-25-2014)
Old 06-26-2014, 04:29 PM   #31
Reaper
Reaper's Avatar
Drives: violent
I realized this thread is all cell phone pics so I thought id add something better
The Following 4 Users Say Thank You to Reaper For This Useful Post:
Brinks (07-19-2014), MJones_RB (03-13-2015), sklimo (07-07-2014), Sportsguy83 (07-01-2014)
Old 07-01-2014, 12:58 PM   #32
Reaper
Reaper's Avatar
Drives: violent
brown spring in the bov didn't work. I ground down the coils (cutting is not how you decrease spring rate, making the wire smaller is) until it leaked at idle then shimmed it back. Worked under load in boost but not the right answer. Didn't work revving in neutral and about half the time at partial boost.
Ordered a yellow and a plain spring.
Plain spring leaked at idle bad. Almost completely open. A small animal could have been sucked in there. If I had a vented hood and drove it like that I would be worried.
Yellow closed at idle and bov works just sitting in neutral and revving the crap out of it. Partial boost, full boost, launch control engine braking.....problem solved.
Anyone need a plain BOV spring?
@FullBlown looks like my car likes the yellow spring. 19inhg at idle
Old 07-02-2014, 10:28 AM   #33
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can I say I told you bro? I also ended up with a yellow (-11 psi) spring with a couple washers as the best setup for my Full Blown kit. I found that while the yellow 11 psi spring kept it closed just fine at idle it was still opening up just a little in off throttle engine braking instances, so I added a couple washers to fix that. By the way here is the link for people that don't understand what we are talking about:
http://www.tialsport.com/documents/w3_tial_qqr_sp.pdf
Color PSI (Vacuum)
Brown -12 PSI (-21 to -23 in/hg)
Yellow -11 PSI (-20 to -21 in/hg)
Plain -10 PSI (-16 to -19 in/hg)
Marcoscrdo (05-07-2015)
Old 07-02-2014, 10:32 AM   #34
Reaper
Reaper's Avatar
Drives: violent
I remember reading your review on the fbm kit back in the day and thinking maybe I should order some more bov springs? Nah local shops should stock a handful of them no biggy its just springs right? WRONG. No one stocks bov springs. Most people dont bother getting their bov setup right.
Old 07-02-2014, 10:39 AM   #35
Reaper
Reaper's Avatar
Drives: violent
Been pulling some ecutek logs and realized I have a lot of problems. Uh oh.
Old 07-02-2014, 10:42 AM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
What is your IAM?
Old 07-02-2014, 10:44 AM   #37
J_kennington
Drives: 2013 asphalt scion FRS
Ah, you got your springs in? Glad the website could help out for you.
I still want to see the car run .
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
The Following User Says Thank You to J_kennington For This Useful Post:
Reaper (07-02-2014)
Old 07-02-2014, 11:24 AM   #38
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
OP video pls, pls OP .
Cliu91 is offline   Reply With Quote
Old 07-06-2014, 12:59 PM   #39
deliroast
Drives: 2014 SSM BRZ
Reminding myself to read through everything so I can ask questions lol
M3 > BRZ
deliroast is offline   Reply With Quote
Old 07-07-2014, 02:26 AM   #40
Reaper
Reaper's Avatar
Drives: violent
ask away, that's the point of a build thread.
Old 07-07-2014, 12:18 PM   #41
reeves
I'm curious where you get your E85, if you don't mind sharing your secret? Is there a private/commercial vendor you can buy from or something to have it shipped to your house?
Old 07-07-2014, 12:24 PM   #42
Reaper
Reaper's Avatar
Drives: violent
There's some in Atlanta and ft benning. I live near suches and truck it up here. 3 hours each way to benning.
reeves (07-07-2014)
Just Another (Turbo) Build rb6freak Member's Car Journals 184 03-22-2017 09:25 AM
Sms Al Suwaidi's Frs Turbo to be Build SmsAlSuwaidi Member's Car Journals 327 01-30-2017 09:19 AM
Do Boy's Turbo FR-S build!!! Do Boy Member's Car Journals 417 11-29-2015 02:17 AM
fully build turbo fr-s/gt86/brz Baramzisyan Want-To-Buy Requests 15 03-22-2014 03:26 PM
Turbo Kit & Shop Car Build Carolina Dyno Forced Induction 11 01-22-2014 03:59 PM
