Old 04-01-2014, 12:36 AM   #71
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by Chad86 View Post
Hello local...Did you end up getting a Monogram?
yes indeed i did i guess i'll see you around
Retro86 is offline   Reply With Quote
Old 05-05-2014, 01:43 PM   #72
neopro2783
Drives: 2013 Subaru BRZ
Originally Posted by Lee358 View Post
The secont post tells you how to turn on the alarm on the limited brz. If you do this then lock the doors the icon on thendash will be solid for 30 seconds then flas after that whicn means your alarm is set the link wont post so here it is.
If anyone has yet to be able to do it here are the steps:
1) Get in the car
2) press the start/stop button two times, with makes the car to be in the start position (all your dash lights light up)
3) Lock the car with the physical button on the door
4) Press the unlock button on the door and open the door while still pressing the unlock door button.
5) Still pressing the unlock button, wait about 10 seconds, the car will beep once for activated and twice for deactivated and the information panel in the cluster will say either "AL on" or "AL off"
2013 BRZ limited. Worked for me. Thanks for the instructions.
neopro2783 is offline   Reply With Quote
Old 06-13-2014, 10:20 PM   #73
n0thing
Drives: Subaru BRZ
Originally Posted by brzzz View Post
So I activated it, put my keys down on my porch and pulled the door handle, knocked on the windows, pushed the car. Nothing happened. What has to happen for the alarm to go off?
Same. I left the window open, locked vehicle with keyless, placed remote far away, reached in and flipped to unlock, opened door but nothing happens?
n0thing is offline   Reply With Quote
Old 06-15-2014, 08:42 PM   #74
chicagokid
Club Member
chicagokid's Avatar
Drives: 2014 Asphalt FR-S Monogram 6MT
Mine works now too. On 2014 Monogram.
chicagokid is offline   Reply With Quote
Old 06-15-2014, 09:29 PM   #75
chicagokid
Club Member
chicagokid's Avatar
Once you active alarm (push lock button on remote) you will see key/lock icon on solid red. After 30+ seconds the icon will blink on and off. Now you can reach in and unlock door (make sure key fob is not on you). Once you do that the alarm will sound.
Old 07-05-2014, 04:52 AM   #76
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I was trying for following the steps from user manual (2015) alarm activation and OP instruction here and cannot get it work. After a long trying and I finally got it to work. here is my revised version might help some people who was having trouble to activate it.
1) press the start/stop button two times, which makes the car to be in the "ON" position without starting the car (all your dash lights light up)
Now you need to following those step rapidly.--> lock, unlock, open door.
5) Still pressing the unlock button, wait about 15-20 seconds, the car will honk once for activated and twice for deactivated and the information panel in the cluster will say either "AL on" or "AL off"
now when you press lock on the keyless remote, you will see the "car and lock" icon stay solid on for 30 second instead of flashing like before.
Speed2th is offline   Reply With Quote
The Following 3 Users Say Thank You to Speed2th For This Useful Post:
Budda (12-16-2016), Chad86 (07-13-2014), SmartedPanda (07-06-2014)
Old 07-06-2014, 02:01 AM   #77
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
After countless tries, this is the best method yet, and works for me.
Never got the honk until now.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
The Following User Says Thank You to SmartedPanda For This Useful Post:
Chad86 (07-06-2014)
Old 07-06-2014, 09:42 PM   #78
*Hachiroku86*
BAZINGA!
*Hachiroku86*'s Avatar
Drives: 15 FR-S
does this work for the standard FR-S??
Colin Chapman - "Adding power makes you faster on the straights, subtracting weight makes you faster everywhere."
*Hachiroku86* is offline   Reply With Quote
The Following User Says Thank You to *Hachiroku86* For This Useful Post:
FRSpappa (07-06-2014)
Old 07-09-2014, 03:34 PM   #79
bluelt1ss
bluelt1ss's Avatar
Drives: 68 Camaro, 14 BRZ Lim, 11 Camaro SS
Got a '14 limited and it wasn't activated. Thanks for the info
bluelt1ss is offline   Reply With Quote
Old 07-13-2014, 01:34 PM   #80
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
Thank you @Speed2th! This worked flawlessly on my 2014 Monogram
Chad86 is offline   Reply With Quote
Old 07-13-2014, 01:38 PM   #81
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
Good question, would like to know also...
FRSpappa is offline   Reply With Quote
Old 07-22-2014, 10:08 PM   #82
Maniak_
Maniak_'s Avatar
Drives: WRB Limited BRZ
Thanks for this. I totally forgot to check and make sure the dealer had it enabled. Of course they didn't.
Maniak_ is offline   Reply With Quote
Old 07-23-2014, 01:40 PM   #83
Chad86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
Further to this, none of these weird pattern lock unlock, open doors, close doors patterns, etc. are necessary. I have located in the manual and confirmed this method works flawlessly every time.
The Following User Says Thank You to Chad86 For This Useful Post:
GotBRZ1691 (07-23-2014)
Old 07-23-2014, 02:57 PM   #84
FRSpappa
FRSpappa's Avatar
Just confirmed this does NOT work on a standard/base model...
Alarm System on the Limited Smokinbuffalo BRZ First-Gen (2012+) — General Topics 10 05-29-2015 10:17 PM
Delete driver01 Electronics | Audio | NAV | Infotainment 20 01-31-2013 02:02 AM
No Alarm? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 40 07-08-2012 11:35 AM
Put deposit down yesterday. Extra for an alarm? mushilea AUSTRALIA 8 07-02-2012 09:05 PM
Update on alarm ? Dkittrell Electronics | Audio | NAV | Infotainment 4 06-26-2012 02:48 PM
