Old 02-16-2014, 03:00 AM   #57
Retro86
Retro86's Avatar
Drives: Awesome
shiii it works on the monogram
Retro86 is offline   Reply With Quote
The Following User Says Thank You to Retro86 For This Useful Post:
Chad86 (03-29-2014)
Old 02-16-2014, 11:56 PM   #58
trd87t
Drives: Supra, BRZ
Did this on my '14 with ease!
Dealer should do this though
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 02-19-2014, 04:48 AM   #59
br@ndon
br@ndon's Avatar
Drives: 2014 Monogram FR-S
Worked on my monogram, the red light use to blink, now its always on. I guess it should work now!
br@ndon is offline   Reply With Quote
The Following User Says Thank You to br@ndon For This Useful Post:
Chad86 (03-29-2014)
Old 02-21-2014, 09:14 PM   #60
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
So it took me awhile to figured out that the smart key needs to be away from the car to test out the alarm. (Alarm locked. Open door. Alarm sounds) haha. :p this is my first push start car btw haha
Sent from my SCH-I545 using Tapatalk
Zen86 is offline   Reply With Quote
The Following User Says Thank You to Zen86 For This Useful Post:
Chad86 (03-29-2014)
Old 02-22-2014, 09:07 PM   #61
BRZ-One
Drives: 2013 Subaru BRZ
thanks for post...and all this time I thought the alarm was active..
BRZ-One is offline   Reply With Quote
The Following User Says Thank You to BRZ-One For This Useful Post:
Chad86 (03-29-2014)
Old 02-23-2014, 06:34 AM   #62
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Does this work for a non 10 series frs?
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 02-24-2014, 04:08 PM   #63
qganja
qganja's Avatar
Drives: 10 series frs
Originally Posted by tinma View Post
if you have a flashing car with a lock beside it on your dash, does that mean the alarm is on?
i dont think soo, mine was flashing too until i armed it a while ago. it stays solid (the flashing car with lock). btw i got the 10series
qganja is offline   Reply With Quote
The Following User Says Thank You to qganja For This Useful Post:
Chad86 (03-29-2014)
Old 02-24-2014, 04:10 PM   #64
qganja
qganja's Avatar
Originally Posted by Lee358 View Post
The secont post tells you how to turn on the alarm on the limited brz. If you do this then lock the doors the icon on thendash will be solid for 30 seconds then flas after that whicn means your alarm is set the link wont post so here it is.
If anyone has yet to be able to do it here are the steps:
1) Get in the car
2) press the start/stop button two times, with makes the car to be in the start position (all your dash lights light up)
3) Lock the car with the physical button on the door
4) Press the unlock button on the door and open the door while still pressing the unlock door button.
5) Still pressing the unlock button, wait about 10 seconds, the car will beep once for activated and twice for deactivated and the information panel in the cluster will say either "AL on" or "AL off"
thank you! i just armed my alarm, splendid write up...
Old 02-24-2014, 05:25 PM   #65
medina619
medina619's Avatar
Drives: 10 series, MX-5,Mazdaspeed protege
worked on my 10 series! thank you
medina619 is offline   Reply With Quote
The Following User Says Thank You to medina619 For This Useful Post:
qganja (02-24-2014)
Old 03-29-2014, 12:58 AM   #66
brzzz
Drives: White BRZ
So I activated it, put my keys down on my porch and pulled the door handle, knocked on the windows, pushed the car. Nothing happened. What has to happen for the alarm to go off?
brzzz is offline   Reply With Quote
Old 03-29-2014, 12:20 PM   #67
Colombo
Drives: '13 BRZ
Mine is the same. I'm thinking there is an additional shock sensor that needs to be installed.
Colombo is offline   Reply With Quote
Old 03-29-2014, 12:48 PM   #68
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Hello local...Did you end up getting a Monogram?
Chad86 is offline   Reply With Quote
The Following User Says Thank You to Chad86 For This Useful Post:
Retro86 (04-01-2014)
Old 03-29-2014, 12:51 PM   #69
Chad86
Chad86's Avatar
Drives: Toyota GT86
I asked the dealer when I picked up and they said they would have it activated for me and that it was probably activated from factory. So I assume the flashing car with lock symbol is a warning that 'Hey, your car is not armed!'
I will be activating shortly. I also believe this is in the instruction manual on how to arm or disarm...?
Old 03-29-2014, 12:52 PM   #70
Chad86
Chad86's Avatar
Drives: Toyota GT86
Dealer said this was armed
Alarm System on the Limited Smokinbuffalo BRZ First-Gen (2012+) — General Topics 10 05-29-2015 10:17 PM
Delete driver01 Electronics | Audio | NAV | Infotainment 20 01-31-2013 02:02 AM
No Alarm? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 40 07-08-2012 11:35 AM
Put deposit down yesterday. Extra for an alarm? mushilea AUSTRALIA 8 07-02-2012 09:05 PM
Update on alarm ? Dkittrell Electronics | Audio | NAV | Infotainment 4 06-26-2012 02:48 PM
