Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 07-04-2014, 09:00 AM   #71
Model Citizen
Lacking brains
Drives: frz
I haven't heard of any OEM motor mounts failing. 320 whp still isn't really that much.
when i put on the sc, the engine movement of the stock mounts was enough to make the ic piping rub in spots.
mounts solved that.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 07-05-2014, 10:10 AM   #72
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
mounts solved that.
I'm sure you had a vortech kit
Old 03-23-2015, 11:43 AM   #73
Koa
Heat Shields for PERRIN mounts.. on the cheap!
Hey guys, want to necro this and point people to a possible, low cost solution.
DIY is here
@PERRIN @PERRIN_Chris
@FT-86 SpeedFactory @Evasive Motorsports @Sportsguy83 @tg_1981 @FrX @brz2013
The Following 4 Users Say Thank You to Koa For This Useful Post:
ck-GT86 (04-02-2015), FrX (03-25-2015), RobertPaulson (03-25-2015), Sportsguy83 (03-24-2015)
Old 03-24-2015, 06:20 PM   #74
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I did something very similar, good job!!
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Koa (03-24-2015), ramiram1984 (03-24-2015), RobertPaulson (03-25-2015)
Old 03-24-2015, 10:18 PM   #75
Koa
share in the DIY thread! the more the betta
Old 03-25-2015, 12:31 PM   #76
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Pretty nice. I also ended up doing something similar. I ended up plastering my lower sub frame and mounts with [ame="http://www.amazon.com/gp/product/B00029KC2K"]stick-on heat shielding I got off Amazon[/ame]. Pretty good stuff. I covered the plastic cover by the control arm too in the stuff. Unfortunately I sort of blew up the motor at the track recently and am in the process of swapping motors and going back NA for now....
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
Koa (03-25-2015)
Old 03-25-2015, 02:07 PM   #77
Koa
Originally Posted by FrX View Post
Pretty nice. I also ended up doing something similar. I ended up plastering my lower sub frame and mounts with stick-on heat shielding I got off Amazon. Pretty good stuff. I covered the plastic cover by the control arm too in the stuff. Unfortunately I sort of blew up the motor at the track recently and am in the process of swapping motors and going back NA for now....
I used thermaflect tape for my oil pan and honestly thought about doing the same and saving myself the hassle of going w/ the blanket.. curious how the tape has held onto the mounts themselves as they deflect a little.. care to snap some pics and add your insights to the DIY thread? would love to see it
Old 03-25-2015, 02:36 PM   #78
FrX
The vast majority of the tape is attached to the subframe. And there is a small section that covers the mount on the face pointing towards the exhaust. It's not going anywhere any time soon. I'll see if I can not get a good picture of it when I get home later.
Koa (03-25-2015)
Old 03-25-2015, 08:59 PM   #79
Sportsguy83
Drives: Limited BRZ
What I did was wrap them with DEI wrap, and held it in place with wire. I don't have pics
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Koa (03-28-2015)
Old 03-28-2015, 01:20 PM   #80
FrX
This is what I came up with:
Koa (03-28-2015)
Old 03-29-2015, 02:30 PM   #81
Koa
added to DIY Thanks
Old 05-16-2017, 05:59 PM   #82
cevin45x
cevin45x's Avatar
Drives: '13 BRZ Limited
Was thinking about purchasing these. Any updates on any melting issues besides the other 2 reported?
'13 BRZ Limited - CBS MT
STX Build - OFT Stage 2 EL 93oct (etune)/TRD intake/HKS EL catless/Motiv OP/Invidia FP catted/Perrin CBE resonated/All complete Whiteline bushings/MTEC trans & clutch springs/Kartboy SS & mount/Perrin 19mm f & 16mm r/Perrin crank & assessory pulleys
cevin45x is offline   Reply With Quote
Old 05-17-2017, 12:30 PM   #83
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
3 years or so in and mine are still fine
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
cevin45x (05-17-2017)
Old 05-17-2017, 02:18 PM   #84
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Mine are a little gummy after a year of tracking NA. Went with STi
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
perrin engine mounts
Perrin or Cusco Engine Mounts and NVH APS86 Engine, Exhaust, Transmission 7 08-04-2018 02:08 AM
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
engine mounts for FI jamesm Forced Induction 19 04-18-2013 08:57 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
