Drives: GTS86 Manual
Perrin or Cusco Engine Mounts and NVH
Hi All,
I am getting the sprintex supercharger fitted very shortly and it has been recommended to change the engine mounts - I have been looking at either the Perrin or Cusco ones but I believe that they increase NVH I was just wondering if anyone has experience with either of these mounts and could guide me in the right direction so as to not increase the NVHJ too much!!!! cheers Andrew |
Drives: Asphalt Scion FR-S
I have the Cusco engine mounts and am pleased with it. I was considering going with the Perrin mounts, but I hear you may have to drill or file the hole on the chassis if it doesn't line up, which doesn't sound like a smart move to me. Cusco drops in once aligned and does not require drilling/filing the chassis in order to work as the hardware is reused.
I also used to have the Perrin transmission support, but vibrations were ridiculous with the combination, so I swapped it out for the Kartboy insert. My car also has Perrin rear shifter bushing, Battleversion rear subframe inserts, TIC solid steering rack mounts, and WL differential mounts - so my idea of NVH may differ from yours. If you get engine mounts, you should get a stiffer transmission mount/insert of some sort if you don't already.
Drives: 2014 Widebody Cosworth FR-S
Have you looked into the STi Group-N mounts or the TRD mounts? We have the Cusco's in our Shop BRZ here and while I love them, they do increase the NHV quite a bit. The STi or TRD mounts would be a nice middle ground where it will help reduce movement without increasing the NHV too much.
However with comfort, it really is such a personal preference item that it would be impossible for me to say what would be too stiff or too soft for any individual person, but I hope the above helps. Thanks, Rick |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | APS86 (12-11-2013) |
#4 | |
cheers Andrew |
Drives: 2013 - BRZ - SWP
any updates ? I am debating on the Perrin or Cusco Engine Mounts...
Drives: 2017 Halo 86
Is it possible to tell if my car already has STi mounts? I have a 2017 86 and as far as I can tell from pics, the STi and ones I have look exactly the same. So how can I tell them apart? Unless of course the STi mounts are sold separately or don't come stock on any of the latest base cars.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
Drives: 2017 BRZ
I took a pic of the STI mounts next to the stock 2017 mounts during my install. STI is on the right.
| The Following User Says Thank You to gtengr For This Useful Post: | Lakitu (08-03-2018) |
Project Shadow
Drives: 2015 BRZ Limited 6MT
I have the cusco mounts and have been very happy with them. And I don't feel that it increased NVH much for me, I also have a solid trans mount too. And this is with a straight cut gear set.
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 04:21 PM |
| FS: Cusco Engine Mounts [SOLD] | cobrabyte | Engine, Exhaust, Bolt-Ons | 11 | 06-18-2013 10:17 AM |
| Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 02:11 PM |
| Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts | ptuning | Engine, Exhaust, Bolt-Ons | 0 | 02-04-2013 10:24 AM |
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 01:03 AM |
