Old 07-02-2014, 02:56 AM   #589
DC2R
Drives: 2014 Scion FR-S
Originally Posted by Cal3000 View Post
I have the ELM327 mini. I think everyone uses this one. lol
Can't get OBD2 Bluetooth adapter to work for the life of me. Tried with my previous adapter and then purchased one recommended here from Amazon.I even tried a USB one I had lying around. Torque tells me it can connect to adapter but adapter can't talk to Ecu. I've tried on Android head unit and on my phone actually with same results.
Used to work with previous adapter phone but stooped at some point.
I have Open Flash Tablet and just flashed Stage 1 tune again to make sure there's nothing wrong with the port. Any ideas? How can I tell if if there is problem with port? Using tiny blue Bluetooth dongle from Amazon.
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 07-02-2014, 06:01 AM   #590
steve99
Drives: FT86
does adapter work in another type of car ? if so try using a obd extension cable and plug your adapter into that , the ports in these cars are a bit sus with some devices with slightly short or thin pins.
Old 07-02-2014, 06:37 AM   #591
Dipstik-sportech
Dipstik-sportech's Avatar
Exact same issue I'm having. If it was pin length then why is the adapter getting power but no signal from the ECU?
Old 07-02-2014, 08:10 AM   #592
DC2R
I think some pins get deformed.
Sent from my SM-N900T using Tapatalk
Old 07-02-2014, 08:20 AM   #593
Dipstik-sportech
EcuTek plug works, other scanners work. Just the dongle won't connect
Old 07-02-2014, 09:05 AM   #594
DC2R
Hmmmm so the handheld scanners you get from PepBoys work too?
Old 07-02-2014, 09:07 AM   #595
Dipstik-sportech
Well we don't have pepboys up here but yes the generic ones work
Old 07-02-2014, 11:40 AM   #596
DC2R
In comparing open flash tablet to dongle the pins seem smaller and thinner. I bent them outward(away from middle divider) and will test again
Old 07-02-2014, 01:41 PM   #597
DC2R
Did quick hoon at lunch and it seemed to work. Will order cable as I just received my Open Flash Header and will need to swap in tablet to flash this weekend
Old 07-03-2014, 07:25 PM   #598
Kurtz
Kurtz's Avatar
Drives: Subaru BRZ
Originally Posted by zoomzoomers View Post
So I got my first CEL and slip light today. Fault code U0073? WTH is that? SMH...
Originally Posted by dwx View Post
It happens sometimes when you are using Torque and a BT adapter and keep torque running while the car is turned off and then restarted in a short period of time. I run into it when stopping at a gas station to run in and buy something or even pumping gas sometimes. Just clear it. If you exit torque it won't happen.
I had this happen to me and dug around for a permanent fix--turns out there are a number of threads on the Torque forums about similar issues (e.g. http://torque-bhp.com/forums/?wpforu...topic&t=1693.0)
Looks like it is caused by the Torque application trying to discover the protocol expected by the ECU using a scan, and this scan causing the ECU to bork.
If you go into the profile you set up for your vehicle and scroll to the bottom, there is a drop down menu where you can set the "Preferred OBD2 Protocol." See the attached picture.
In my case--and I'd expect it to be the same for all BRZs--it was ISO15765-4 CAN (11 bit, 500k baud). While connected to the adapter you can go to the "Adapter Status" button on the home screen and you can confirm the setting there. I don't think it would vary based on adapter, but check your car to be sure.
After changing this setting I haven't had a reoccurrence in a couple days of testing.
I'd be interested in hearing if this works for others and if the settings are identical on an FR-S.
Kurtz is offline   Reply With Quote
Old 07-05-2014, 02:26 PM   #599
Cal3000
Drives: Panda FR-S
It seems like these units are a hit or miss whether they work or not. I had to go through 2 before it worked.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 07-05-2014, 08:24 PM   #600
DC2R
Pins in obd2 connector are smaller and thinner than OFT. Had to bend them out. Got it working but when running car hard it seems to disconnect.not sure if adapter or android unit.
Old 07-05-2014, 11:03 PM   #601
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
OFFICIAL Torque Android app PID/Misc Thread
OBD2 ports use a standard, if the adapter you are using doesn't fit, don't modify it. You can literally fry your ECU by causing a short. Some OBD2 adapters are just subpar and have connectivity issues. It could be as simple as shoddy soldering of components. I would say it's never worth a $1800 ECU to use a $9 obd2/elm adapter.
CladMonitor is offline   Reply With Quote
Old 07-11-2014, 06:43 AM   #602
Calle
Calle's Avatar
Drives: Toyota GT86 SWP
Is it possible to use the adresses described in this thread in Torque?
http://www.ft86club.com/forums/showthread.php?t=56432
For example:
E_IAM_1byteExtExt_E96 FFF89B67
E_IAM_4byteExt_E31 FFF816F4
Calle is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
