| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 |
Off Topic
#44 |
Thanks
Yea that is impressive when my car cant even go 130. It's not that impressive when some guy is just putting his foot down a mile straight.
#45 | |
Drives: 2014 BRZ Ltd - DGM
That's a extremely unfair generalization. There are MANY techs out there that are not only exceptionally skilled but treat others cars even better than their own. From someone with an inside perspective of working for Mercedes during highschool and then my wifes father is a BMW & Ferrari Master Tech and has also worked as a advisor I can assure you there are lots and lots of techs that care greatly about every car they work on.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
#46 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#47 |
Drives: LS Swapped BRZ
I have never worked for a dealership, I do however run a privately owned general repair shop.
I take pride and satisfaction in knowing that I run one of the few honest independent shops around. Technicians can make good money by finishing work in half the recommended time. Does that mean he should make less money because he is good/efficient at his job... No of course not. a Slow technician might take twice the allotted time and would you like to pay twice as much for that, No of course not. To be fair there is labor guidelines and if it says it takes 1 hour, then regardless of how long it actually takes, the technician is going to be paid that 1 hour. That's what flat rate technicians get paid and as long as you have honest non-cutting corners kind of techs, you are getting charged appropriately. A lot of people think being a tech is soooo easy, and for the most part on basic cars they are correct, but every day I have people who come in that tried to fix something "easy" and made such a mess of things it ends up costing them more to fix than what we would of charged if they would of just let us do it in the first place. For example I had a guy this week who tried to do his own spark plugs, did an o.k. job on 7 of them, but the last one, he cross threaded it in, and screwed up the aluminum head threads. and guess what, we ended up having to take the head off fix the head, and put it all back together. We could of changed the spark plugs for couple hundred dollars... now he just costed himself 2000$+... trying to do something most of us would say is "easy" because he didn't have the right quality of tools, or the knowledge of putting anti seize on the threads. |
| The Following User Says Thank You to JesseE For This Useful Post: | ZionsWrath (07-03-2014) |
#48 | |
Drives: 2018 BRZ Limited
| The Following 2 Users Say Thank You to Erci For This Useful Post: | AVodka14 (07-03-2014), ZionsWrath (07-03-2014) |
#49 | ||
@JesseE As a independant shop you can't possibly justify the kind of prices you posted. Using the diff as an example. My local DEALER only wants .5hr to change trans AND diff fluid.
2014 BRZ Ltd. - DGM
| The Following User Says Thank You to sluflyer06 For This Useful Post: | Erci (07-03-2014) |
#50 | |
Drives: 2013 Subaru BRZ Limited - CBS
| The Following User Says Thank You to Blackforge For This Useful Post: | Erci (07-03-2014) |
#51 | |
Drives: car
#52 | |
Drives: car
At the point where they've already got the car on stands, and each (basic maintenance) job takes between 5-30 minutes, they're still charging you a full hour for every single itemized service. Again I'll bring up the rear differential service, it's as easy as pulling the plug and draining it and filling it back up, right? That'll be 80 bucks, you savvy subaru owner you. My 30k service included coolant change. |
#53 |
#54 |
#55 | |
Color means absolutely nothing. |
#56 |
Drives: 2013 BRZ Limited
I look at it this way. If you actually know what you are doing then do it yourself. If you don't then take it in. I am an engineer on ships, I am fully capable of following a service manual and documenting everything. In my experience most dealerships employ mostly techs. They may have a couple guys who specialize in stuff like engines, transmissions and electronics but those guys are limited in numbers. A true mechanic is someone who can hear or see something and diagnose it. Techs just do what the computer tells them to do.
As for documentation I recommend having two. One of which is mySubaru for subarus. It allows you to log anything you do as well as showing what the dealer says they did.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
| 30,000 mile service | goke186 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 10-11-2014 09:52 PM |
| 30,000 Mile Service Woes (Rant ITT) | S1owJam | Mid-Atlantic | 24 | 12-19-2013 04:27 PM |
| Dealer service | RevoG | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 06-25-2013 10:13 PM |
| 1000 mile break in service for BRZ? | Tonym427 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 08-27-2012 03:00 PM |
| 7500 mile service done. 30k will suck. | FRSpdDmn | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 08-09-2012 09:34 AM |
