Old 07-03-2014, 01:29 PM   #6469
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I am torn. Do I keel this beloved nimble sports car that I have and pull the trigger on a ESC or put the money to trade in for a 2015 WRX? Decisions. One thing is for certain i, I am bored of the power in my FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-03-2014, 01:34 PM   #6470
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Either way is a great in my opinion (though the fact there isn't a hatchback is a travesty) . Worse case scenario if you buy the esc someone will buy it off you immediately if you still feel you need the wrx.
Installed Mods:
Old 07-03-2014, 02:08 PM   #6471
jflogerzi
jflogerzi's Avatar
Do you need 4 doors? You are going to take a decent size hit that could pay for a good chunk of a boosted twin. I say boost for twin in some form or another.
Old 07-03-2014, 02:10 PM   #6472
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Full throttle Electric Supercharger Build Thread
Stock for stock I might be tempted to go STI, but if you're comfortable modding and go dollar for dollar, the twins are the way to go.
Note I only say tempted. For me, power isn't everything. I love the NA feel of the twins, which is why I went ESC. As close to NA as boost gets, IMO. I also love the RWD and the light, nimble chassis. You would lose all three going to an STI, so if it is something you like, be warned. But you gain AWD, power, and space.
To me; the two are relatively even matched, just pick your preference.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-03-2014, 03:39 PM   #6473
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
just bought my dump packs last night, Atbatt has a 10% off code " JULY4 " which will almost cover the shipping cost.
Target70 is offline   Reply With Quote
Old 07-03-2014, 04:39 PM   #6474
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Originally Posted by fenton View Post
There is a special electrical tape that is orange that Rob used on my 3 motor to controller connections. Mine kept disconnecting due to high current.
I had a early revision of the battery hold down where the posts wouldn't stay tightened down.....one of those things that everyone else gets to benefit from me being the first tester..... Called rob in a panic "car won't start".... He politely asked me to check the terminal connections....2 minutes later I was on the road again
Hey Fenton or anyone who cares to answer,
I understand that Rob has tweaked the controller since its original release to be more " beefy" with better heat dissipation. Can you elaborate as to what changes if any were done for this product in its newer release? Thx
FRS
Old 07-03-2014, 04:41 PM   #6475
Sojhinn
Sojhinn's Avatar
It's a bigger box with a different arrangement of the innards. The retail controller is the new design from my understanding.
Installed Mods:
Old 07-03-2014, 04:55 PM   #6476
fenton
There are better components inside that can handle more load. For reference the old controller could do 3-3.5kw, the newer controller can do 4-4.5.
The motors he is using now have better electronics inside as well. The first ones were good as well he has just beefed everything up because that is what he does
fenton is offline   Reply With Quote
Old 07-03-2014, 04:58 PM   #6477
fenton
Originally Posted by Sojhinn View Post
So Robb and Fenton anything new in development or you want to talk about? Anything we can help with or test?
I have not been asked to test anything new yet. I am continuing to torture test my TQ300 with 1.5 dump and aux charger. The 300 is good but the 250 is also performing really well...plus it has less lag at start up. Rob is fully committed to putting out a solid product for all the people that are currently interested. He has ordered lots of parts and will be fully consumed with putting all the new kits together.
Old 07-03-2014, 07:39 PM   #6478
fenton
Stopped by Robs today and holy is there a lot of stuff going on there.
He has been machining the compressors and has a whole bunch finished however the limiting factor is his order has not came in for the compressor wheels.
@Robftss wanted me to update everyone that a couple more aux chargers have been sent out for test. I think he has a couple left for those that may be interested in adding it to their system. It decreases the recharge rate from 8:1 to 4:1 and helps balance a bit of the load the one controller has to do under load.
I'll let Rob comment on the price.
Old 07-03-2014, 07:42 PM   #6479
Sojhinn
Sojhinn's Avatar
Alright guys just finished up an install video. I stole the idea from @nlowell and I just need to edit it and post it. Give me about an hour.
Installed Mods:
Old 07-03-2014, 08:03 PM   #6480
jpit
Drives: Subaru BRZ
I have two brand new starter batteries (PSH 12180NB-FR) that I can sell for $40.00 each (includes shipping). PM me. Thanks.
jpit is offline   Reply With Quote
Old 07-03-2014, 09:16 PM   #6481
Sojhinn
Sojhinn's Avatar
The install video is currently uploading. But here is the link:
@Robftss and @fenton Let me know if it looks right.
This is the new video with a couple of edits. Very similar though.
[ame]http://youtu.be/qkxPcDUPFdk[/ame]
Installed Mods:
Old 07-03-2014, 10:07 PM   #6482
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Nicely done! - Let's put this on the first post.
nlowell is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
