View Poll Results: What oil
Mobil 1 113 41.70%
Castrol Syntec 38 14.02%
Valvoline Synpower 6 2.21%
Quaker state/ Q horsepower 5 1.85%
Penzoil Platinum 17 6.27%
Royal purple 28 10.33%
Eneos 5 1.85%
TRD oil (dont know if still available) 6 2.21%
Castrol "think with your dipstick jimmy" Edge 10 3.69%
..... motorcraft?....... 2 0.74%
Other. please specify 60 22.14%
Multiple Choice Poll. Voters: 271. You may not vote on this poll
Old 04-13-2012, 04:06 PM   #211
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Used to use Royal Purp once upon a time, but I made the switch to Penzoil plat and never looked back.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 04-13-2012, 04:09 PM   #212
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Lol, I guess I'll be this guy: Castrol "think with your dipstick jimmy" Edge
I used to use that until I learned that the US version of the oil had a HTHS rating that was crazy low. 1.3 I think. Good for efficiency, bad for wear.
Old 04-13-2012, 04:15 PM   #213
M-17
Ninja Cat Mod
M-17's Avatar
I was just joking around on that part. I do like Mobile 1, Penzoil, and Castrol but I used Castrol GTX on my old car.
Old 04-13-2012, 04:22 PM   #214
Turbowned
Turbowned's Avatar
Kendall GT1. Old School oil! Actually, I really have no idea. Does anyone have hard data to support that Subarus "don't like Mobil 1"?
Found some interesting info on Kendall Oil, for anyone who cares:
"Part of the ConocoPhillips family of lubricants, Kendall Motor Oil enjoys a dramatic heritage. The Kendall Refining Company was founded in 1881 in Bradford, Pennsylvania, with the goal of refining local Pennsylvania Grade Crude Oil into kerosene, lubricants and greases. With more than 125 years of experience to draw upon, Kendall Motor Oil has led the industry with a number of significant firsts.
In 1928, Kendall introduced the first oil designated for winter use as well as the first 2,000-mile motor oil (unprecedented at a time when the standard was 500-1,000 miles), and later developed the first pre-packaged, factory-sealed, one-quart oil can."
Old 04-13-2012, 04:30 PM   #215
serialk11r
Drives: '06 AM V8V Coupe
Does HTHS directly influence power consumption? Viscosity is going to give the oil pump power consumption, and the friction modifiers and stuff will influence the actual engine mechanical efficiency. HTHS does tend to go up with higher viscosity oils but I think it's just a correlation...
Old 04-13-2012, 04:44 PM   #216
Draco-REX
Corner Junkie
Draco-REX's Avatar
HTHS, High Temperature High Sheer, is a measure of how the oil keeps its viscosity when under high heat and pressure, exactly the conditions in your engine's main bearings and other areas.
If it keeps its viscosity, it "floats" the parts apart better. But, this also puts more drag on the parts. If it's thinner, the parts will move easier, but won't have the protection needed when there's a lot of load on the engine.
So for efficiency, a low HTHS oil is preferable. But for engine longevity, especially an engine that sees high loads, a high HTHS oil is preferred.
Old 04-13-2012, 04:48 PM   #217
Joe@Amsoil
Drives: Evo 9
Hey so why aren't we on this poll?!?!?
Joe@Amsoil is offline   Reply With Quote
The Following User Says Thank You to Joe@Amsoil For This Useful Post:
ESBjiujitsu (05-04-2012)
Old 04-13-2012, 04:49 PM   #218
serialk11r
That doesn't quite make sense to me, retaining viscosity under high temperature and pressure doesn't necessarily cause more drag, although I might be wrong. If the bearing surfaces are closer together the "drag" forces could become greater because the moving surfaces are in closer proximity. Although I don't doubt that higher HTHS oil will generally have higher viscosity and thus higher parasitic power consumption, but I highly doubt that it's a casual thing.
Old 04-13-2012, 04:51 PM   #219
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Royal Purple FTW!
S2kphile is offline   Reply With Quote
Old 04-13-2012, 04:54 PM   #220
Joe@Amsoil
Drives: Evo 9
Amsoil is a PITA to get and they make people jump through hoops. A friend of mine is a distributor for Amsoil. But they won't even deliver their own product. He has to go to their warehouse and pick it up. So he's never sold a single quart of Amsoil. Screw that.
Mobil 1 is out because Subaru engines just don't like the stuff. Not going to even risk it since there are other choices.
Penzoil Platinum has a great reputation on BobIsTheOilGuy.com. So for the BRZ, it'll likely get that with a Purolator PureONE filter (99.9% filtration).
Redline has some of the highest HTHS ratings for US oil. So the STI gets that. For now I use the PureONE filters on the STI, but I'm considering switching to Canton oil filters for their high flow and 8 micron filtration.
Hmmm I dont like to hear that . There shouldn't be any jumping through hoops to order our Oil. We have the option of delivering oil directly to your door or you can pick it up at the warehouse. Im not sure why your friend thinks he needs to pick it up
But on the bright side... IM HERE If you guys want to get Amsoil im real easy to get in touch with and delivery usually takes 2-5 days from the day order was placed. We have warehouses all across the country to ensure fast delivery times.
And if all else fails there's always our website to place orders! http://www.amsoil.com/storefront/?zo=5001506
But if you buy through me off this forum ill be sure to hook it up! :happy0180:
Old 04-13-2012, 05:01 PM   #221
Joe@Amsoil
Drives: Evo 9
Originally Posted by xantonin View Post
I won't buy the car unless the dealer agrees to change all the fluids to Amsoil before it's driven off the lot.
I like the way you think!
Old 04-13-2012, 05:21 PM   #222
Sasquachulator
Pavement Grey
Ive been using Motul since my first change to Synthetic (since that what the stealership uses).
I honestly dont know if any of these oils make a big or even a noticeable difference....
Old 04-13-2012, 05:25 PM   #223
Dimman
Kuruma Otaku
Dimman's Avatar
I think you guys sponsor my buddy. 1015 whp Mk3 Supra. Uses it the Supra and his Yaris daily driver and has nothing but good things to say about your stuff.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Joe@Amsoil (04-13-2012)
Old 04-13-2012, 05:58 PM   #224
Joe@Amsoil
Drives: Evo 9
That really depends on what you consider "Noticeable". Changing your oil 6-8 times a year to changing your oil Once or Twice is pretty noticeable to me. Remember its Oil not a turbo... when you change oil 90% of the people wont notice the difference because they are subtle differences. Cleaner feeling start and idle, smoother shifts and improved gas milage. They're things that the average person doesn't really feel but its there. The average person also wont physically see it. When was the last time you ripped of your head to check the walls on your cylinders?
The things that separate the good oils from great ones you see in the long term with the car. Its the difference from your car dying at 130,000 and 200,000. Its maintaining the 35mpg when the car has 150,000 miles on it.
You may not notice a difference the second you change the oil, but looking back after you've owned the car for 10-15 years and your engine and drivetrain still feels brand new you'll be happy you went with quality oil. :happy0180:
