#15 |
Drives: 07 STI
A lot of the turbo Subaru guys (including myself) use Rotella t6 5w40 with really great results. Not sure if that would be too think for the FA engines or not but if you're pushing boost, I would think you would be ok. Whatever you use I would recommend doing some UOAs to get an idea of how well the oil you choose is holding up for your setup.
#16 | |
Drives: Hydra EMS Powered FRS Raven Black
Now synthetic oils are so much more high tech than they used to be an even these 40w race oils flow like a 10w so I wasn't concerned so much as I was aware of some possible negatives. Oil pressure loss has been observed at high rpm on track cars, the bearings are pretty thin so pressure requirements will be high, I'm running an oil cooled and journal bearing turbocharger, so all that added up to my decision. It's warm right now so honestly I haven't observed any side effects at all, and if anything I no longer hear clanky metalic sounds at start up anymore. No doubt this will sap some NA power so those guys might be better off with 5w40. Hope that helps and so far my FRS has taken serious bosted track abuse! Thanks, Phil Grabow |
#17 |
Drives: FRS
AMSoil full synthetic 5w30
#18 |
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
#19 |
Drives: 2014 FRS Raven. 2011 sti red (gone)
Sorry to revive an old thread.
I was wondering if any of you have a new opinion on the oil you were using a year ago, or a change of heart, anything really :P |
#20 |
in orbe terrum non visi
Drives: violent
amsoil 10w30 dominator if you don't have cats and run e85 signature series otherwise
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#21 |
Drives: 4-Runner Sport - 13' BRZ SportTech
I'm using Motul 300v 0w20. I think I'm going to try 30w on the next oil change. Oil pressures get kinda low at the track
Top Tier Imports - Check out my build journal HERE
#22 | |
Y u do dis?
Hit the nail right on the head.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#23 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Mobil 1 05w-30 here w/ Liqui Moly (3721) Cera Tec Friction Modifier.
Following oil changes would be Mobil 1 05w-30 with Liqui Moly 2009 Anti-Friction Oil Treatment .
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#24 |
WILL be running 05w30 Amsoil Synthetic
#25 |
Drives: GT 86
I was told it a heavier oil than 0/20w would interfere with the variable cam timing as it reduces the ability to make adjustments quick enough with a higher viscosity so don't use it .
#26 |
Drives: violent
Then why does Subaru recommend 5w30 in the owners manual and put 5w30 in the fa20dit that has the same cams and clearances?
http://www.ft86club.com/forums/showt...t=reaper+buildLast edited by Reaper; 07-01-2014 at 11:41 PM. |
#27 |
The manual also states 5-30 can also be used.
#28 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
We have tried several different grades of oil. All Motul.
H Tech 0w20 H Tech 5w30 300v 0w20 300v 5w30 After analysing all, we now run 300v 5w30 in both NA and turbo applications. Our results mimick Toyota Racing NZ, who run 5w30 in the TR86 race cars. Stick with 0w20 if your car is mostly a street vehicle, and is NA. It will provide marginally better fuel economy. Which is essentially why it is the factory fill weight. |
| Best oil for turbo engine | whitefrs | Forced Induction | 36 | 10-09-2014 02:45 PM |
| Engine Noise on Turbo FRS | whitefrs | Forced Induction | 23 | 04-18-2013 10:30 AM |
| 1.6L DI TURBO ENGINE | quik1987 | BRZ First-Gen (2012+) — General Topics | 39 | 11-30-2011 06:01 PM |
| FT-86 / FR-S engine will be Toyota 2l turbo!! | Slide | Engine, Exhaust, Transmission | 114 | 07-07-2011 11:58 PM |
| Do you want a turbo engine for the FT-86? Read here | Ramo | BRZ First-Gen (2012+) — General Topics | 86 | 06-23-2011 09:39 PM |
