Old 06-24-2013, 02:59 PM   #15
robotvoice
Drives: 07 STI
A lot of the turbo Subaru guys (including myself) use Rotella t6 5w40 with really great results. Not sure if that would be too think for the FA engines or not but if you're pushing boost, I would think you would be ok. Whatever you use I would recommend doing some UOAs to get an idea of how well the oil you choose is holding up for your setup.
robotvoice is offline   Reply With Quote
Old 06-25-2013, 09:14 PM   #16
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by No Limit Motorsport View Post
What is your thoughts about a 40w on stock bearing clearances? My fear with Oil pressure loss is apparent even in NA for at high RPMOil pressure loss is apparent even in NA for at high RPM 40w was it would be a bit too thick. I value your opinion.
It's a compromise really but we know the motor was designed for 0-20w but we know that is primarily for fuel efficiency and maximum HP given relatively low power. Now I know the oil temps we see on our STi and others have noted 270F on stock FRS/BRZ on track so my primary concern was to deal with the high temp and how that relates to viscosity. .
Now synthetic oils are so much more high tech than they used to be an even these 40w race oils flow like a 10w so I wasn't concerned so much as I was aware of some possible negatives. Oil pressure loss has been observed at high rpm on track cars, the bearings are pretty thin so pressure requirements will be high, I'm running an oil cooled and journal bearing turbocharger, so all that added up to my decision.
It's warm right now so honestly I haven't observed any side effects at all, and if anything I no longer hear clanky metalic sounds at start up anymore. No doubt this will sap some NA power so those guys might be better off with 5w40.
Hope that helps and so far my FRS has taken serious bosted track abuse!
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 06-25-2013, 10:45 PM   #17
Nothing
Drives: FRS
AMSoil full synthetic 5w30
Nothing is offline   Reply With Quote
Old 06-26-2013, 04:34 AM   #18
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Fabron757 is offline   Reply With Quote
Old 07-01-2014, 12:59 PM   #19
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Sorry to revive an old thread.
I was wondering if any of you have a new opinion on the oil you were using a year ago, or a change of heart, anything really :P
Kuros is offline   Reply With Quote
Old 07-01-2014, 01:07 PM   #20
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
amsoil 10w30 dominator if you don't have cats and run e85 signature series otherwise
Old 07-01-2014, 01:22 PM   #21
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I'm using Motul 300v 0w20. I think I'm going to try 30w on the next oil change. Oil pressures get kinda low at the track
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 07-01-2014, 02:37 PM   #22
Dream20b
Y u do dis?
Originally Posted by Element Tuning View Post
Also do not forget the more power you make the more critical the oil wedge in your bearings becomes.
Phil Grabow
Hit the nail right on the head.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 07-01-2014, 03:05 PM   #23
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Mobil 1 05w-30 here w/ Liqui Moly (3721) Cera Tec Friction Modifier.
Following oil changes would be Mobil 1 05w-30 with Liqui Moly 2009 Anti-Friction Oil Treatment .
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-01-2014, 06:40 PM   #24
ThisGuy919
WILL be running 05w30 Amsoil Synthetic
ThisGuy919 is offline   Reply With Quote
Old 07-01-2014, 11:25 PM   #25
sam69
Drives: GT 86
I was told it a heavier oil than 0/20w would interfere with the variable cam timing as it reduces the ability to make adjustments quick enough with a higher viscosity so don't use it .
sam69 is offline   Reply With Quote
Old 07-01-2014, 11:27 PM   #26
Reaper
Reaper's Avatar
Drives: violent
Then why does Subaru recommend 5w30 in the owners manual and put 5w30 in the fa20dit that has the same cams and clearances?
Old 07-01-2014, 11:40 PM   #27
zoth
zoth's Avatar
The manual also states 5-30 can also be used.
Old 07-02-2014, 12:05 AM   #28
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
We have tried several different grades of oil. All Motul.
H Tech 0w20
H Tech 5w30
300v 0w20
300v 5w30
After analysing all, we now run 300v 5w30 in both NA and turbo applications.
Our results mimick Toyota Racing NZ, who run 5w30 in the TR86 race cars.
Stick with 0w20 if your car is mostly a street vehicle, and is NA. It will provide marginally better fuel economy. Which is essentially why it is the factory fill weight.
Manji is offline   Reply With Quote
Best oil for turbo engine whitefrs Forced Induction 36 10-09-2014 02:45 PM
Engine Noise on Turbo FRS whitefrs Forced Induction 23 04-18-2013 10:30 AM
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
FT-86 / FR-S engine will be Toyota 2l turbo!! Slide Engine, Exhaust, Transmission 114 07-07-2011 11:58 PM
Do you want a turbo engine for the FT-86? Read here Ramo BRZ First-Gen (2012+) — General Topics 86 06-23-2011 09:39 PM
