#6455 |
Drives: 2014 BRZ
Guys. Im intrigued. Was going to go for Jackson SC but this might be a better cheaper alternative. What are your thought owners???
#6456 | |
There are many posts in this thread, lots of info so take your time to read them, you won't regret it.
#6457 |
Drives: 2014 BRZ
yeah you did! thanks
![]() im reading... and reading. lol still a long way to go |
#6458 |
Drives: FR-S,GTI
As far as problems with heat goes,
The other day I started my car and it said the outside temp was 112 degrees! Pretty hot! I had no problems with the ESC whatsoever. And I have a completely "stock" install. No extra fans or ducts or anything. I think you would have to run this thing extremely hard to have any problems with it. (Racetrack) |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | enwave (07-01-2014) |
#6459 | |
I had a early revision of the battery hold down where the posts wouldn't stay tightened down.....one of those things that everyone else gets to benefit from me being the first tester..... Called rob in a panic "car won't start".... He politely asked me to check the terminal connections....2 minutes later I was on the road again
#6460 |
Drives: 2013 Subaru BRZ Premium
Do you have a brand name for this tape? Of the three connections, my black is loose and slips off easily. Duct tape is holding it in place currently.
#6461 | |
#6462 |
Drives: WR Blue BRZ, 240Z
Disconnect the black connector. Grab a crimp tool (or a set of plyers) and slightly crimp the female connector (the outer one). This will tighten the connection AND reduce the chance of arcing. Arcing will lead to corrosion at the connector and eventual failure. All of the tape in the world wont prevent this from happening if you have a loose connector.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| The Following User Says Thank You to Gary in NJ For This Useful Post: | Winjr (07-01-2014) |
#6463 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
I second the crimping. In the case you want tape to be extra certain, I would imagine standard Scotch or Duck electrical tape should do the trick as long as heat ratings are good enough.
[ame="http://www.amazon.com/gp/aw/d/B000BOHK58?pc_redir=1403507906&robot_redir=1"]Duck Brand 299005 Pro 667 Series Electrical Tape, 3/4-Inch by 66 Feet, Single Roll, Orange:Amazon:Home Improvement[/ame] Sent from my iPhone using Tapatalk
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
#6464 |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
This look like the stuff? http://www.xtremetape.com/
There are a couple of similar brands of silicone tape and they are all "self fusing" so they seal extremely well and just about permanently. |
#6465 | |
#6466 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I've been in Yosemite for 5 days with no internet. Sorry it took so long to respond but that looks bad ass.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| The Following User Says Thank You to Sojhinn For This Useful Post: | DAEMANO (07-02-2014) |
#6467 |
Wish it was always 63 degrees out! Car pulls so much harder
#6468 |
So Robb and Fenton anything new in development or you want to talk about? Anything we can help with or test?
| The Following User Says Thank You to Sojhinn For This Useful Post: | DAEMANO (07-03-2014) |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
