DIY (Do-It-Yourself) Guides For all DIYs. |
06-29-2014, 10:19 PM | #57 |
Drives: 2013 Toyota FRS Ultramarine
No problems with the windows hitting anything but if you do not put the door all the way down when closing it to latch it will rise and the door will strike against the latch bolt. In order to help prevent further damage to the door I have put a strip of rubber above the latch on both doors.
06-29-2014, 11:25 PM | #58 |
Drives: 2003 Camry Blue | 2013 FR-S White
looks like good solid work and skipping over to the last vid shows that the work looks pretty good.
couple of things that i'm concerned with with the video though... 1 - is it me or does it look like the bottom portion of the door does not line up with the body now? or is that just an illusion? 2 - when I saw you pull the door down, it looks like the metal gives a little and bends a bit. how's the wear and tear of the module? it looks like the mounts don't take stress very well with the bouncing of the doors with the brace. I mean for me i'm not a fan of vertical doors, but it's a bit unique in this term since it actually pulls out and then up so i'm wondering about the build as well as the braces to see how they are reinforced. |
06-30-2014, 12:46 AM | #59 |
Drives: 2017 Camaro 1SS
What if you enjoy something, some movie or musician or something, and then you discover more people like that something than don't? Do you stop liking it when you find out the majority does to avoid being a lemming?
06-30-2014, 03:47 PM | #60 |
Drives: Yes
That's what you call a "desperately different hipster"
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
10-09-2014, 07:13 PM | #61 |
Drives: Scion FR-S White Out
I think it looks pretty damn hot! Nice job on the doors. The FRS is a fun car to customise and is a great hobby.
The Following User Says Thank You to Parappa For This Useful Post: | UF Key Master (10-09-2014) |
10-09-2014, 08:19 PM | #62 |
Drives: 2015 Firestorm Scion FRS
hmmm....that actually looks pretty damn good! nice job!
The Following User Says Thank You to G-awesome For This Useful Post: | UF Key Master (10-10-2014) |
10-13-2014, 05:24 PM | #63 | |
Drives: 2018 Subaru BRZ tS
Also awesome job on the mod, I like it! |
10-13-2014, 05:38 PM | #64 | |
10-15-2014, 07:27 PM | #65 |
Lacking brains
Drives: frz
I hate oxygen cause everyone else likes it.
Good for you op, in for your gullwing door followup |
11-12-2014, 02:39 PM | #67 |
Wondering if you can tell me a bit more about the doors. Can you use them like regular doors for daily use and use the vertical door mode for fun?
When you open the door, does it spring to vertical door mode or easy to accidently bounce into vertical door mode? What happens when the door is vertical and you push door towards the body of the car...it looked a bit wobbly in the video. Any chance of damage to the body/frame of the car. I like the kit, entertaining the idea of getting this done. Just want to make sure its a solid kit. |
11-12-2014, 03:26 PM | #68 |
Drives: car
I think this would look better if it were on some kind of track to swing upward instead of having to go outward with all that play. Really like the look though.
08-11-2018, 12:48 AM | #69 |
Drives: Argento manual
adjustment to keep doors open on hills
Your mod is very impressive to me.
I wonder if you or others know of a way to adjust the standard FRS doors to stay open on slight hills? Mostly my need is on sideway hills, not front to back, but both would be nice. My 2013 has a hard time staying open. Brian in Atlanta |
The Following User Says Thank You to ArgentoAtl For This Useful Post: | jcw99 (08-11-2018) |
08-11-2018, 01:52 AM | #70 | |
Drives: swp mt '14 brz premium
Similar Threads | ||||
DIY: APR Door Mirror Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 53 | 04-26-2019 03:08 PM |
DiodeDynamics Door LED install | Khazzy | DIY (Do-It-Yourself) Guides | 25 | 05-09-2014 09:52 PM |
Red inside door handle grips how to install? | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 03-24-2014 12:21 AM |
Selling a Vertical door kit | FRS-89 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 02-20-2013 02:57 PM |
Anyone install door stabilizer? | russv | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-12-2012 12:08 PM |
