Old 06-29-2014, 08:52 PM   #71
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by extrashaky View Post
And it's no wonder, if you're representative of the norm.
If you are to believed it would be clutch throw away bearings failing. It isn't. Your argument has failed why keep flogging the dead horse?
paulca is offline   Reply With Quote
Old 06-29-2014, 09:01 PM   #72
DeadStar7
Retired formula car racer
DeadStar7's Avatar
Drives: 2013 Scion FR-S Manual
Originally Posted by paulca View Post
So you still had no formal manual training. That's what you are saying. Not on road driving a manual.
You are still at it? Yes, I took a manual driving school. My test was also on a manual. Please stop this. You are making people hate you.
"If one day the speed kills me, do not cry, because I was smiling." - Paul Walker
DeadStar7 is offline   Reply With Quote
Old 06-29-2014, 09:15 PM   #73
paulca
Out of interest, the dead pedal is more there for the purpose of having something to push against to stabilize yourself in the seat. Something that isn't too far removed from the pedals. The passenger can push themselves back into the seat for stability by pushing their feet on the floor. If you have your feet on the clutch and accelerator, you can't push yourself into the seat or have anyway to stabilise yourself for comfort. This use is quite good, but on the public road you should never need it. You often see rally drivers use it this way for example.
Old 06-29-2014, 09:28 PM   #74
markw
Drives: 2014 FR-S
It also makes a convenient foot rest so that you don't ride the clutch and wear it out in 60,000 miles.
markw is offline   Reply With Quote
The Following 2 Users Say Thank You to markw For This Useful Post:
DeadStar7 (06-29-2014), extrashaky (06-29-2014)
Old 06-29-2014, 09:33 PM   #75
DeadStar7
DeadStar7's Avatar
Hahaha!!
Old 06-29-2014, 09:35 PM   #76
Slash
Slash's Avatar
Drives: 2013 FRS
Tldr; has anyone brought up clutch foot positioning in an A/T?
I'll leave.
Slash is offline   Reply With Quote
Old 06-30-2014, 01:56 AM   #77
markw
Drives: 2014 FR-S
I'll leave.
Someone bought the one they made with the auto trans?
Old 06-30-2014, 09:39 PM   #78
DeadStar7
DeadStar7's Avatar
lol
Old 07-08-2014, 03:26 AM   #79
schmearcampain
Drives: 2014 Argento FRS 6MT
Heel and toe shifting is NOT standard or even recommended on the public roads. There is no reason to downshift sequentially through the gears. Slow, select the gear you need, accelerate.
You only actually need to heel and toe when you are so close to the limit that any accidental bump on the transmission from the clutch only downshift could break the car into a slide. If you are that near the limit on public road you will get pulled, points on your license and nasty fine or probably banned if you don't kill someone first.
Alternatively if you are just doing it cause it's cool, then you are wasting brain cycles that could otherwise be used for observation and hazard awareness.
By that logic, we should all drive automatics to save brain cycles that are wasted by using a clutch and selecting the proper gear.
schmearcampain is offline   Reply With Quote
The Following User Says Thank You to schmearcampain For This Useful Post:
Purdue FR-S (07-09-2014)
Old 07-08-2014, 01:58 PM   #80
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Late to the party. Heel-toe is not necessary in street driving, but neither is it dangerous - not all heel-toe has to be done at the limit. I heel-toe low speed turns because I want the practice and because it smooths out the turn - my rev match for such turns will not go above 3k rpm.
As for the whole clutch positioning argument, while the driving culture and skill level varies by country, the engineering does not. Riding the clutch is bad - don't take it from North American - watch some Best Motoring videos as they always show what the drivers are doingnwith their feet. They do not ride the clutch.
Sent from my SGH-I747M using Tapatalk
daiheadjai is offline   Reply With Quote
Old 07-08-2014, 03:47 PM   #81
paulca
I didn't post this because I got bored, but "Riding the clutch", the only definitions I can find on the inter-web is pressing the clutch enough to cause it to slip, which if you do a lot WILL feck your clutch, eventually.
I can sit on CC with my foot resting on the clutch when the switch that disconnects the CC is long before the clutch will slip.
For a laugh I tried taking my foot off the clutch after each change and it looked like a monty python silly walk sketch. Total fecking joke unless you are either cruising or not changing gear enough. Out of a junction, 1st, foot off, foot back on 2 seconds later 2nd, foot off, foot back on 3 seconds later, 3rd, foot back off, braking 2-3 seconds later for a roundabout foot back on, 2nd, foot off. Totally idiotic.
Old 07-08-2014, 05:48 PM   #82
DeadStar7
DeadStar7's Avatar
Here he goes again...
The Following User Says Thank You to DeadStar7 For This Useful Post:
Old 07-08-2014, 07:03 PM   #83
extrashaky
Drives: 2014 BRZ Limited
You're supposed to be watching where you're going, not laughing at your feet.
Old 07-09-2014, 01:48 PM   #84
Purdue FR-S
Boiler Up!
Purdue FR-S's Avatar
Drives: 2018 BRZ tS
Minor Fault (-2 Points)
Purdue FR-S is offline   Reply With Quote
seat positioning rainmonkey Cosmetic Modification (Interior/Exterior/Lighting) 23 12-07-2015 09:38 PM
Gauges Positioning BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 12 12-10-2013 08:24 PM
Anyone here with a foot fetish? switchlanez Off-Topic Lounge [WARNING: NO POLITICS] 47 04-08-2013 03:27 PM
Go Pro Positioning mechaghost Tracking / Autocross / HPDE / Drifting 7 12-15-2012 02:22 PM
