Stig's dark passenger
Eng coolant temp sensor location
Can someone tell me where it s located?
At Buttonwillow and the sensor is getting hot (not the coolant) causing limp mode. David |
| The Following User Says Thank You to D K For This Useful Post: | Zzzquil (05-19-2016) |
#2 |
Boosted Member
Drives: 2013 Subaru BRZ
How do you know it's the sensor getting hot and not the coolant if you don't know where the sensor is..?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
| The Following User Says Thank You to woode For This Useful Post: | stugray (06-28-2014) |
#3 |
By using common sense....
Temp gsuge stays at half then shoots to red. 30 sec later back to half |
#4 | |
Boosted Member
Do you have a real gauge or reading from the ECU? What are the temps while driving and while idling when the car is showing overheated? The gauge on the dash is essentially a fake gauge, it will only show cold/normal/hot. It doesn't linearly scale with the temperature. Your temps are probably within operating range, then barely climbing outside normal operating temp and the gauge goes up to the red, then back down to normal where it goes back to the middle. Most modern cars are like this. The gauge is dumbed down for the masses.
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM Last edited by woode; 06-28-2014 at 06:50 PM. |
#5 |
I have the aim solo dl now.
Reading 185-190 2 minutes after. Pretty sure its the radiating heat from the header, engine and everything else. No smell of coolant or any other symptoms. I have a fbm radiator also so it shouldnt overheat after 3 hot laps. So, the location? |
#6 |
Drives: FT86
http://www.ft86club.com/files/BRZwiringi.pdf
page 38 C35 E.F.I. Engine Coolant Temperature Sensor looks like under intake manifold can you monitor coolant and oil temps with torque or scantool or other device ?? might be dash guage fault or wiring, air pocket ect. |
#7 |
Boosted Member
It's towards the rear on the engine.
Did you just recently install the radiator? Edit- Your sensor isn't getting heat soaked and giving you false readings. Your car is overheating. The gauge on the dash is going up the the red and back down to normal because of the resistors placed inline with it to scale it back and keep the needle steady all the time when it's in the normal operating temperature range. If you were to watch a linear or digital gauge and compare it to your dash gauge you would see what I am talking about.
#8 |
Because compromise ®
Drives: Red Herring
#9 | |
Drives: 2013 GBS BRZ Limited
You have replaced part of your coolant system, now are having these symptoms.... Sounds like you have a large air bubble in your system. As the bubble(s) pass the temp sensor, it is swinging all over the place. |
| The Following 2 Users Say Thank You to stugray For This Useful Post: | DJCarbine (08-27-2014), suaveflooder (06-30-2014) |
#10 |
#11 |
Boosted Member
I'd recommend bleeding your system man..
If your exhaust and block are getting hot enough to effect your sensor, which probe is INSIDE the engine block and 12"+ from the exhaust piping.. you would have much much bigger problems (like a car on fire).
#12 |
I would bet quite a bit you are dealing with an air pocket like others mentioned. Seen it before plenty of times. Try turning the heat and feel the air coming out of the vents, if there is a point where it starts to not be so hot, it's an air pocket.
The ECT sensors aren't very complicated and I don't think I've ever seen one fail due to heat. |
#13 |
Tried all that.....
Will try again. Temps got to 224 after 5-6 hard laps. |
#14 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 06:47 PM |
| p0198 code oil temp sensor malfunction circuit high | kingkai23 | Forced Induction | 10 | 06-17-2014 02:22 PM |
| Coolant Temp Gauge? | Pacific Auto | Issues | Warranty | Recalls / TSB | 4 | 01-20-2014 05:00 PM |
| OEM Oil Temp Sensor Location | Khorne | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 01-15-2014 11:38 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-30-2013 12:50 AM |
