View Poll Results: What side seal have you had a problem with
Driver's side seal problems 41 47.13%
Passenger side seal problems 4 4.60%
Happend on both sides 19 21.84%
Seal problems? I ain't got no seal problems! 23 26.44%
Voters: 87. You may not vote on this poll
Old 06-25-2014, 10:55 PM   #29
cycleboy
Drives: 2013 Scion FR-S - Argento
Mine do it, driver's side for sure, passenger's I think at time.
My bigger concern is the driver's side has started to leak air at the upper back corner. I can't feel it, but I can hear it and put my hand back there and push the rubber against the glass and make it stop.
Not holding out much hope for a dealer fix, just like the other little issues w/ the car.
cycleboy is offline   Reply With Quote
The Following User Says Thank You to cycleboy For This Useful Post:
suaveflooder (06-26-2014)
Old 06-26-2014, 12:05 AM   #30
suaveflooder
Both my windows make noise, neither leak though which is a good thing
suaveflooder is offline   Reply With Quote
Old 06-26-2014, 03:10 AM   #31
funwheeldrive
I noticed my car doing this after I washed it one day. It's not folding on the top part of the widow, but on the side.
The Following User Says Thank You to funwheeldrive For This Useful Post:
suaveflooder (06-28-2014)
Old 06-28-2014, 02:22 PM   #32
WNDSRFR
Drives: FR-S,GTI
Yeah
My car used to do this. It's caused by the window grabbing hold of the seal and pinching it as it goes up instead of sliding past it.
I stopped it by armoralling it once a week. It makes the rubber soft and slippery as hell.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
extrashaky (06-28-2014), suaveflooder (06-28-2014), unsurety (06-28-2014)
Old 06-28-2014, 04:58 PM   #33
extrashaky
Drives: 2014 BRZ Limited
I was wondering why nobody had mentioned that yet. Mine isn't doing it, but if it were my first thought would be to try Armorall to lubricate the seal. Does it have any down sides? (Discoloration, residue on the glass, etc.)
Old 06-28-2014, 05:51 PM   #34
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I tried 303 protectant, but it didn't work for me. I saw others say that silicone sprays didn't work for them, I guess it goes on a case by case basis. worth a try anyway.
Target70 is offline   Reply With Quote
Old 06-28-2014, 06:54 PM   #35
toeout
I use 1Z Einszett Rubber Care Stick “Gummi Pflege” on mine. http://www.autogeek.net/1z-einszett-...are-stick.html
I didn't have the seal catching problem to begin with, so I can't say that the Gummi Pflege fixes trhe problem or even keeps it from developing, but definitely worth a try.
What I 've heard about tint on windows, is that it's actually more slippery than glass. I'm also tinted.
toeout is offline   Reply With Quote
Old 06-28-2014, 07:56 PM   #36
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
For those with issues, do you have window tint?
And if so, did lube help out?
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 06-28-2014, 09:42 PM   #37
kodyo
Drives: Scion FR-S
Have window tint, lube has worked to a degree, but limited success. I've tried tire shine and I've tried silicone spray.
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
Old 06-28-2014, 10:18 PM   #38
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
I have it too!
-Wind sound on the freeway, I can pull in down to fix it
-Water leaks a little when washing
-No tint on car
-15k miles, started shortly after getting car
Going to wait for more serious problems before going to dealer to get everything fixed.
Problems so far:
-Dash peeling up
-Crickets
-Window seal
Pacific Auto is offline   Reply With Quote
The Following User Says Thank You to Pacific Auto For This Useful Post:
Old 07-01-2014, 03:07 AM   #39
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Mine had been back 3 times to have this fixed. In the end I did it myself. Best option is to align the window internally so it puts less pressure on the seal when it closes. Name:  ImageUploadedByTapatalk1404198315.013768.jpg
This is the relevant adjustment screw. Best to take off the locknut and understand how it works before adjusting. If this concerns you then take note of how you adjust so you can put it back.
86•BRZ is offline   Reply With Quote
The Following 5 Users Say Thank You to 86•BRZ For This Useful Post:
civicdrivr (07-02-2014), extrashaky (07-01-2014), Joon525 (10-26-2017), roddy (09-09-2014), Target70 (07-01-2014)
Old 09-09-2014, 08:38 PM   #40
roddy
roddy's Avatar
Drives: '13 Ultramarine
I spoke with my service manager yesterday. They are going to replace both sides under warranty along with a couple of other things.
Old 10-24-2024, 06:21 PM   #41
rikixass
rikixass's Avatar
Anyone know where one can buy a replacement vapor/moisture barrier?
rikixass is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 05:12 PM
Drivers Side Window (Not Seal) Mister Issues | Warranty | Recalls / TSB 20 12-16-2013 02:56 PM
Window Seal Leaves Marks on Windows AsianStyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-22-2013 03:28 PM
Does anyone else have this problem after lowering their BRZ? (pics included) Calin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-27-2013 11:59 PM
