Old 06-27-2014, 12:56 AM   #71
Colombo
Drives: '13 BRZ
Originally Posted by FRSBRZGT86FAN View Post
Not yet, someone on the forum here if ,I remember correctly, went to the extreme and wrapped the area around the pump and the pump itself in some sort of sound deadening material. Other than that there is no fix at least not for awhile also other cars I have driven with HPFP that run off camshaft lobes for DI occasionally get a squeak like the FR-S/BR-Z. I highly doubt there will be a fix to this as toyota and subaru have written this off as "normal" now.
Have you seen documentation of Subaru calling it normal? I've been looking and can't find anything.
Colombo is offline   Reply With Quote
Old 06-27-2014, 01:32 AM   #72
chris912
chris912's Avatar
Drives: 2013 Firestorm 6MT FR-S
i think there's a TSB
chris912 is offline   Reply With Quote
Old 06-27-2014, 09:32 AM   #73
xlid007
Drives: Scion FRS
I'm on the new pump according to the TSB and after 500 or so miles I just noticed the stupid chirping today. I'm so pissed off.
xlid007 is offline   Reply With Quote
Old 06-27-2014, 10:06 AM   #74
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Same here, I'm trying to decide if I have them change it three times so that I can use the Lemon Law to ditch the car if they can't get this fixed. I've seen too many FR-S' burn to the ground for me to trust this pump.
Frishkorn is offline   Reply With Quote
Old 06-27-2014, 10:38 AM   #75
andrew20195
Drives: 2013 Subaru BRZ
These cars aren't burning to the ground because of a fault with the pump. They're burning to the ground because of improper service procedures when working on the fuel system. The crickets have nothing to do with it.
andrew20195 is offline   Reply With Quote
Old 06-27-2014, 10:44 AM   #76
Frishkorn
Hi everybody!
Frishkorn's Avatar
Is that what they've narrowed it down to? I haven't seen much follow up on the posts. Still pissed they changed the pump knowing there isn't a fix yet on the TSB. They (the dealership) should have just told me that there is no resigned fuel pump yet.
Old 06-27-2014, 10:50 AM   #77
andrew20195
If that were the case, they would have updated the TSB saying so. They have not done so at this time.
Old 06-27-2014, 11:31 AM   #78
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I could've sworn there was a TSB calling it normal at one point.
Old 06-27-2014, 11:33 AM   #79
extrashaky
Drives: 2014 BRZ Limited
The TSB updated 4/15/14 is posted in this thread:
http://www.ft86club.com/forums/showthread.php?t=67546
It doesn't actually say that the chirp is "normal." It says, "This result is non-detrimental to the fuel system or engine." What they said is normal is the ticking sound the pump makes, not the chirp.
If I'm reading that TSB correctly, cars manufactured after September 2013 should have the newer fuel pump with the changes to the chamber and plunger. Mine was manufactured early this year, and it still chirps. I think if the chirp could be eliminated, they would have already done it.
As far as I'm concerned, this sound is normal for this pump, and I'd rather drive and grin than obsess over it.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
FRSBRZGT86FAN (06-30-2014), Pseud0logik (06-29-2014)
Old 06-27-2014, 01:47 PM   #80
andrew20195
Correct, and that language has been in the TSB since the original release.
Old 06-29-2014, 12:43 AM   #81
chris912
chris912's Avatar
this may sound like a noob question, but is there 2 "different" fuel systems on this car? port injection and direct? and if so are there 2 different fuel pumps - the normal fuel pump that all cars have and the HPFP? is that correct?
Old 06-29-2014, 09:24 AM   #82
extrashaky
Almost, but the two systems are not entirely separate. There's a fuel pump under the rear seat that feeds the port injection system, but it also delivers fuel to the high pressure fuel pump. The HPFP then delivers fuel to the direct injection system.
Old 06-29-2014, 12:43 PM   #83
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
I've used nothing but ethanol free Shell V91 for almost a year, and I've had chirp issues for 90% of the time I've had the vehicle. I brought the TSB to the dealership, but they sound very unconvinced a replacement pump will make any difference. So basically they know its pointless TSB.
FiRStsc10n is offline   Reply With Quote
Old 06-29-2014, 03:24 PM   #84
chris912
chris912's Avatar
and correct me if I'm wrong, but the port injection is for normal driving conditions and the direct injection is for hard driving like WOT after 4k rpm?
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
DIY-Changing Clock/HVAC LEDs on FR-S Lil Abner DIY (Do-It-Yourself) Guides 113 03-11-2022 01:40 PM
Changing the Horn? mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 21 10-27-2016 12:27 AM
Changing Premium to Limited? zygrene BRZ First-Gen (2012+) — General Topics 32 10-09-2012 11:58 AM
I'm changing my order from World Rally Blue to Lightning Red Subie BRZ First-Gen (2012+) — General Topics 26 06-12-2012 12:59 PM
