Old 06-19-2014, 08:35 PM   #197
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Mine is still holding up fine. I dont really drive it much, but still holding good, and im around 320-350wtq on it.
gdrider77 is offline   Reply With Quote
Old 06-19-2014, 09:01 PM   #198
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Sportsguy83 lol what about that update?
Old 06-20-2014, 07:45 AM   #199
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I've been updating in my build thread .
Exedy TD was initially horrible coming off a dead stop. There was no chance to come off line civil and like a normal car.
BUT, it has improved throughout the break in process and now it has become pretty DD friendly. Will still hold final review and judgement until after break in is complete. I'm at 300 miles break in and its minimum 500.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
cdrazic93 (06-20-2014)
Old 06-26-2014, 03:21 PM   #200
johnnyb305mia
Drives: 14 BRZ Limited
I"ll let you guys know how my review is on the act 6puck sprung with flywheel it gets dropped in tom
johnnyb305mia is offline   Reply With Quote
Old 06-26-2014, 03:55 PM   #201
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Its great for 2000 miles or so, and after that meh
Old 06-26-2014, 10:40 PM   #202
johnnyb305mia
In my previous car had a turbo tc on e85 that put down 391whp n i used a spec 6 puck but no flywheel n it was fine obv each car is diff and my cars makin way more power than that plus rdw>frw another obv thanks for the input though
Old 06-26-2014, 10:50 PM   #203
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I realize this an old thread but ill throw some knowledge at it. I have the act streetlight and the 6 puck sprung.
The streetlight is about at light as you can go and not get random misfire codes and still be streetable. Install was just like any other clutch, no issues.
Feel was extremely chattery at first. Difficult to DD in fact until about 500 miles of driving then it got substantially better. The flywheel is nice for rev matching downshifts but with a factory idle with the ac on there is a lot more noise then factory. Well because racecar. If your into that kind of thing.
Starts on hills required more RPMS's than i'd like and I felt like I was excessively hard on the clutch. Mainly because of a lack of feel at the engagement point. Then I looked at my pedal. That damn spring in there makes the engagement point feel awful. I ripped it out.
Car is extremely streetable. Pedal pressure is stiffer than stock but that's a good thing. It reminds you to not keep the clutch pedal in at red lights. (bad for crank bearings with a high pressure pressure plate). The noise might be a deal breaker for some but that's the flywheel not the clutch.
Removing that damn spring made a huge difference.
Clutch is currently holding 380wtq no problem.
Old 06-26-2014, 11:01 PM   #204
SmsAlSuwaidi
Boosted
Very inncorrect, many of us have had the prolite with no isssues, i for my self have had it while the car was fully stock, and racked over 2000 miles and not a single code
Old 06-26-2014, 11:03 PM   #205
Reaper
Reaper's Avatar
Drives: violent
well ive seen misfires on ecutek with just a flywheel change.
Old 06-26-2014, 11:03 PM   #206
johnnyb305mia
Good info there i mean im sure there is going to be some chatter and stuff like that but like you said because racecar lulz have u had any stalling issues when thrown into nuetral? Also im sure once its broken in it will get better and you get more used to it as well and thats good to know regarding the tq i will post some numbers after it gets retuned. I lit that stock clutch up on the dyno lol car made more power than expected and is pig rich under full boost but could not take any more out due to clutch but all that will change soon
Old 06-27-2014, 09:45 AM   #207
Reaper
Reaper's Avatar
Drives: violent
No problems at idle but I did turn my idle up slightly. Its gets rid of some of the chatter when the ac is on.
Old 06-27-2014, 11:47 AM   #208
Dipstik-sportech
Dipstik-sportech's Avatar
So far I'm happy with my prototype clutchmasters, I'll call it an fx400+ kit. No slip and it is actually lighter than my old fx which is weird oh and it's not as chattery to drive
Old 06-28-2014, 12:39 AM   #209
johnnyb305mia
Ok so guys here is my thoughts on the act 6 puck sprung with flywheel...
Very quick engadment a little chatter upon idle at times but nothing serious at all may take some ppl a little to get used to but i had no issue it grabs extreamly well. But i beg to differ from ppl who say its a hassle and a pita to dd. I think it will be fine just like ny 6 puck in my other car was. Noticable difference in reving through gears with the flywheel. Also i would agree you must give it some gas off the start but not much like 1300rpms but easy to get smooth launch well just my 2 cents but who the hell am o
Old 06-30-2014, 02:50 PM   #210
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The streetlite and the prolite on this car are only like a pound different. I doubt anyone could tell the difference between the two unless looking at them.
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
