#197 |
Drives: Subaru BRZ Limited
Mine is still holding up fine. I dont really drive it much, but still holding good, and im around 320-350wtq on it.
#198 |
Junior
Drives: a car
@Sportsguy83 lol what about that update?
#199 | |
I Love custom Turbo kits
Drives: Limited BRZ
. Exedy TD was initially horrible coming off a dead stop. There was no chance to come off line civil and like a normal car. BUT, it has improved throughout the break in process and now it has become pretty DD friendly. Will still hold final review and judgement until after break in is complete. I'm at 300 miles break in and its minimum 500.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | cdrazic93 (06-20-2014) |
#200 |
Drives: 14 BRZ Limited
I"ll let you guys know how my review is on the act 6puck sprung with flywheel it gets dropped in tom
#201 |
Boosted
Drives: Not a supra....yet
Its great for 2000 miles or so, and after that meh
#202 |
In my previous car had a turbo tc on e85 that put down 391whp n i used a spec 6 puck but no flywheel n it was fine obv each car is diff and my cars makin way more power than that plus rdw>frw another obv thanks for the input though
#203 |
in orbe terrum non visi
Drives: violent
I realize this an old thread but ill throw some knowledge at it. I have the act streetlight and the 6 puck sprung.
The streetlight is about at light as you can go and not get random misfire codes and still be streetable. Install was just like any other clutch, no issues. Feel was extremely chattery at first. Difficult to DD in fact until about 500 miles of driving then it got substantially better. The flywheel is nice for rev matching downshifts but with a factory idle with the ac on there is a lot more noise then factory. Well because racecar. If your into that kind of thing. Starts on hills required more RPMS's than i'd like and I felt like I was excessively hard on the clutch. Mainly because of a lack of feel at the engagement point. Then I looked at my pedal. That damn spring in there makes the engagement point feel awful. I ripped it out. Car is extremely streetable. Pedal pressure is stiffer than stock but that's a good thing. It reminds you to not keep the clutch pedal in at red lights. (bad for crank bearings with a high pressure pressure plate). The noise might be a deal breaker for some but that's the flywheel not the clutch. Removing that damn spring made a huge difference. Clutch is currently holding 380wtq no problem.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#204 | |
Boosted
Very inncorrect, many of us have had the prolite with no isssues, i for my self have had it while the car was fully stock, and racked over 2000 miles and not a single code
#205 |
Drives: violent
well ive seen misfires on ecutek with just a flywheel change.
#206 |
Good info there i mean im sure there is going to be some chatter and stuff like that but like you said because racecar lulz have u had any stalling issues when thrown into nuetral? Also im sure once its broken in it will get better and you get more used to it as well and thats good to know regarding the tq i will post some numbers after it gets retuned. I lit that stock clutch up on the dyno lol car made more power than expected and is pig rich under full boost but could not take any more out due to clutch but all that will change soon
#207 |
Drives: violent
No problems at idle but I did turn my idle up slightly. Its gets rid of some of the chatter when the ac is on.
#208 |
So far I'm happy with my prototype clutchmasters, I'll call it an fx400+ kit. No slip and it is actually lighter than my old fx which is weird oh and it's not as chattery to drive
#209 |
Ok so guys here is my thoughts on the act 6 puck sprung with flywheel...
Very quick engadment a little chatter upon idle at times but nothing serious at all may take some ppl a little to get used to but i had no issue it grabs extreamly well. But i beg to differ from ppl who say its a hassle and a pita to dd. I think it will be fine just like ny 6 puck in my other car was. Noticable difference in reving through gears with the flywheel. Also i would agree you must give it some gas off the start but not much like 1300rpms but easy to get smooth launch well just my 2 cents but who the hell am o |
#210 |
NASA SpecE30 Racer
The streetlite and the prolite on this car are only like a pound different. I doubt anyone could tell the difference between the two unless looking at them.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
