#99 |
Drives: 23 BRZ
I think you should give @ModBargains a call. They do Full Blown installs if I'm not mistaken. If you're having a shop install for you I suggest you ask them about cooling, clutch and gauges for your type of usage. They should be able to point you in the right direction.
Forums too - do lots of research. |
#100 |
Drives: 2013 all stock frs
#101 | |
#102 | |
| The Following User Says Thank You to SPCorBUST For This Useful Post: | jc1993 (06-28-2014) |
#103 |
the Robispec combo is supposed to be pretty good
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
| The Following User Says Thank You to SPCorBUST For This Useful Post: | jc1993 (06-26-2014) |
#104 |
Drives: A Potential Traffic Ticket
#105 |
#106 |
Wouldnt the stock clutch slip after a certain amount of power? And IDK if 7psi is high enough for one to need a clutch upgrade.
| The Following User Says Thank You to JackSmiley For This Useful Post: | jc1993 (06-28-2014) |
#107 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
go with the fbm oil cooler and radiator + fans, as long as you bought the stage 1 turbo setup it shouldn't have any fitment issues.
#108 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | JackSmiley (06-27-2014), jc1993 (06-28-2014) |
#109 |
Drives: 2013 Black FR-S
Stock clutch will let go at ~220-230 wtq (dynojet). We found this out during our tuning process where torque was incrementally coming up each revision and finally started slipping at this torque level.
| The Following 2 Users Say Thank You to sw20kosh For This Useful Post: | JackSmiley (06-27-2014), rb6freak (06-26-2014) |
#110 |
NASA SpecE30 Racer
It isn't a question of PSI, it is a question of torque. A good tune on 7 PSI will result in clutch slip very soon after it is installed.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#111 |
depends on how you're shifting as well. as they're saying, psi doesn't matter - I was at 15 and it was holding fine except for WOT shifts where the rev was being held when shifting. max torque was 252, hp was 330 on the corn, which is all I really run.
#112 |
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 02:41 PM |
| Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC | mav1178 | Other Vehicles & General Automotive Discussions | 1 | 05-23-2014 10:47 PM |
| 2015 86/BRZ vs 2015 Eclipse | botbs | FR-S / BRZ vs.... | 55 | 04-16-2014 04:07 AM |
