#15 | |
13anned.
Drives: Firestorm FR-S
I have a stock header with an HKS resonated front pipe, and tomei 60s on stock tune. With this setup I do get soot buildup on the exhaust but it's not bad where I have soot on the rear bumper. I know it's not the exact setup you want , but hopefully it will help you make your decision.
#16 |
Drives: 2016 STi DGM
I had CEL on my catless hks header, even after a tune...
-2014 SSM BRZ MT
#17 |
Junior
Drives: a car
Cat vs no cat. Fluffy vs no fluffy.
Catalytic converters offer resistance to air flow. These are most prevalent in stock cats. Now, high flow cats are literally at the minimal limits for catalytic converters. In a regular stock cat comparison, you can shine a flashlight through the stock cat and not see anything on the other side, you'll blind yourself if you try that with a high flow cat. Remember this is all about restriction of the air flow, so unless you're pushing about double the hp, you will not see any difference in whp relating to cat vs no cat. I see no benefit of having 2 either, get a catted header and catless front pipe, or vice Versa.
#18 |
Drives: Toyota 86
Thanks all. The only reason I am considering a catless front pipe (vs. a catted one) is that I can get a very good deal on the catless one. Will give it a go and see if the soot build up becomes too excessive.
#19 |
Drives: 2013 Raven FRS MT
The only cat I ran on my old tC was in the header (factory manifold/primary cat) and that made a big difference in sound compared the aftermarket header without a cat. Without the cat in the header. The car sounded horrid. I will run as many cats in my exhaust if I plan going full as possible. Sound over slight HP gains. I don't care because I am going turbo. Let us know how you like it. Cheers!
#20 | |
Drives: 2013 FRS / 2013 427 Vert
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#21 |
Drives: Toyota 86
Am already running Greddy Trust CS GTS v. 2 catback, which is relatively quiet. Is the increased loudness mainly from the header or front pipe?
#22 |
Drives: Toyota 86
Freshly installed HKS EL header + front pipe (both un-catted), with stock overpipe and Greddy/Trust CS GTS v2 catback. No CEL, as I understand is typically the case with HKS exhaust parts on the Middle East / Asian spec models.
Revving, especially in the lower gears, is noticeably significantly louder in the inside of the car. I can really smell the fumes as well, which tend to seep in especially when I am stationary at the lights. Will give it a few weeks before I decide whether to revert to the stock front pipe... ![]() [ame="http://youtu.be/rDlhESloaxo"]http://youtu.be/rDlhESloaxo[/ame] Last edited by jng; 06-25-2014 at 02:05 PM. |
| SARD Japan Header & Mid-Pipe & Header & ECU | nigel-jdmparts | Engine, Exhaust, Transmission | 63 | 01-21-2014 12:20 PM |
| HKS Performance Exhaust HI-POWER SPEC-L / HEADER / FRONT PIPE! !! Instock ! | Speed Element | Engine, Exhaust, Bolt-Ons | 15 | 03-21-2013 01:57 PM |
| FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready | FA20Club.com | Engine, Exhaust, Transmission | 171 | 02-27-2013 09:44 AM |
| Will a resonated front pipe make alot less noise than test pipe? | Mike86 | Engine, Exhaust, Transmission | 8 | 01-26-2013 07:24 PM |
