Old 06-22-2014, 08:27 PM   #1905
k.houan
k.houan's Avatar
Drives: BRZZZ
Originally Posted by Malt View Post
The first thing I'd do is take some logs and post them up to datazap. People much smarter than me could look at your logs and determine if there really is an issue.
Sent from my SCH-R970C using Tapatalk
I took a log from a long drive I recently did, tried to upload it and the file size is above the 2mb limit. Does the log of the size increase with the duration of it?
Sent from my LG-E980 using Tapatalk
k.houan is offline   Reply With Quote
Old 06-22-2014, 11:28 PM   #1906
k.houan
k.houan's Avatar
Drives: BRZZZ
Just a short drive, but could you guys take a look at this?
http://www.datazap.me/u/khouan/drive-shila?log=0&data=1
Old 06-23-2014, 12:39 AM   #1907
chris912
chris912's Avatar
Drives: 2013 Firestorm 6MT FR-S
subd
chris912 is offline   Reply With Quote
Old 06-23-2014, 05:31 AM   #1908
steve99
Drives: FT86
Originally Posted by k.houan View Post
Interesting. I really don't think I could possibly have an exhaust leak. Could it be the filter? I made sure it was installed correctly and sealed properly. I really don't know what to do. Can i damage the engine running this way?
It unlikely to be the filter. as its upstream from maf.
It might be you dislodged a hose sound tube ect or have a small vacuum leak in the intake tube where maf sits cause when you were manipulating air box to get filter in.
In your log the high fuel trims are only around idle and below 1000 rpm elsewhere when your on the throttle trims look ok but AFR looks slight lean for OFT tune at top end your mid 12 afr usually shiv tunes run a bit richer than that.
check all the hoses and clamps, sound tune and resonator connection in intake area
it could also be an exhaust gasket leak as @Malt said you wont always hear it but sometimes you can smell it
What were your ltft like on petrol ??
Old 06-23-2014, 09:17 AM   #1909
Malt
Drives: 2015 WRX
Steve, I think there might be something else going on here. From looking at my latest logs I've noticed some wide variations in trims. I started to try and rescale my MAF to get my trims +-1 but using the java app I didn't have enough data to get a nice smooth scale. I've noticed while steady state cruising looking at torque that commanded AFR seems to fluctuate quite a bit which might be causing the wide variations in trims people are seeing. Here's and example
http://www.datazap.me/u/malt/scaling...zoom=4344-4444
Commanded AFR going from 14.94 to 14.47 over and over, which doesn't seem normal. This is happening around 3200rpm.
Here's another example of the jumping commanded rate.
http://www.datazap.me/u/malt/scaling...zoom=4714-5111
What in the world is going on here? The closed loop pulls I've done look perfect but open loop still have LTFT's running from -3.9 all the way up to 5.4. Its fairly obvious to me that the higher positive trims are coming from very light partial throttles at somewhat lower rpms and as the rpms rise in open loop the trims get markedly lower. Just seems pretty odd that there would be such a massive difference in trims. Its been pretty hot here along with higher humidity than I care for which is necessitating running the AC. I can watch the trims change quite significantly when turning the AC on and off (which is expected obviously due to engine load). I'm starting to wonder if the newest CalID B01c might "fix" this as I think the bumping trims is caused by AC compressor cycling.
Any Ideas @shiv@vishnu
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
steve99 (06-23-2014)
Old 06-23-2014, 10:48 PM   #1910
k.houan
k.houan's Avatar
Drives: BRZZZ
Here is another log of a drive today. Look any better? No way I have an exhaust leak, the damn car is only about to hit 7k miles!
http://www.datazap.me/u/khouan/drive...e?log=0&data=1
Old 06-23-2014, 11:20 PM   #1911
k.houan
k.houan's Avatar
Drives: BRZZZ
To be honest I have no idea what my ltft looked on regular 91. As soon as I got my OFT I ran empty, filled up with E85 and flashed stg 2 el tune. Drove easy until trims leveled out, ltft below 10 and figured I was good. Once I ran that first E85 tank empty, I installed the HKS filter and filled up again. Then things started looking funny. Maybe nothing is wrong, I wouldnt know. Thats why I'm asking for your guys help. Input from Shiv himself would be nice.
Old 06-23-2014, 11:24 PM   #1912
s2d4
s2d4's Avatar
Get it done with a much more sufficient log for both close loop and open loop, then rinse and repeat a couple more times.
Torque is too slow, use the real time graphing display to see AFR vs command AFR, you'll see the behaviour much much more clearly.
Here's and example
Normal, look at the fueling map for that rpm vs low load, doesn't deviate much.
The real time graph of afr vs commanded afr would help with this too.
Old 06-24-2014, 01:43 AM   #1913
steve99
Drives: FT86
First tank of E85 will generally have about 8-10 litres of straight petrol as thats when light comes on..
Your second tank will have much higher E% than first and require a bit of learning, looks like its starting to sort itself ltft down to about 8% from about 15%.
It not unusual to see ltft around 7 or 8% with a stock car that has not had maf scaled some are better some are worse.
Old 06-24-2014, 03:07 PM   #1914
k.houan
k.houan's Avatar
Drives: BRZZZ
Yeah, but I ran the tank way down after the light came on. Either way probably is what's happening. So 7 or 8 average should be safe? And what is a good afr for idle and wot? I'll post another log after more learning time.
Old 06-25-2014, 02:31 PM   #1915
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
does anybody know if the stock MAP sensor can also be rescaled so it can read about 1bar/15psi? stock it seems it can read up to 0.4bar
or do i need the denso/honda K20 map sensor?
ST-A is offline   Reply With Quote
Old 06-27-2014, 09:17 AM   #1916
DuroSquad
DuroSquad's Avatar
Drives: 2013 Scion FR-S Asphalt
Just ordered my OFT! Can't wait
DuroSquad is offline   Reply With Quote
Old 06-27-2014, 09:42 AM   #1917
steve99
Drives: FT86
I think your going to have to buy a new sensor but PM @nelsmar or @jamesm they should know.
Old 06-28-2014, 12:22 PM   #1918
nelsmar
This is correct you will need a new sensor.
My flickr - Canibeat
Local magazine scout
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
