go_a_way1
Old 06-13-2014, 05:53 PM   #2423
GREDDYGT/86
Drives: 2013 Scion FRS
I have searched can not find definite answer will this fit.
Enkei rpf1 17x9 +45
Dunlop Star Spec ZII 245/40R/17
Stock suspension
GREDDYGT/86 is offline   Reply With Quote
Old 06-14-2014, 09:51 AM   #2424
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Enkei rpf1 17x9 +45
Stock suspension
It will fit, but only if you are stock. As soon as you add camber or lower the car, then it won't anymore (or you'd have to add spacers in the front).
Best to stick with the +35 offset in that wheel, keep an eye on the group buys on this forum.
Edit: example here (note the 3mm spacer required with lowering springs)
http://www.ft86club.com/forums/showthread.php?t=48453
Slick is offline   Reply With Quote
Old 06-22-2014, 07:18 PM   #2425
Tranz
Tranz's Avatar
Drives: 86 GTS
Function guys will probably cringe at this, so look away now if you are.
Looking at a set of wheels 18x8.5 +17 / 18x9.5+17 with 205/40, 225/40 tires on them. Dropping just over the legal height in Australia (100mm lowest point).
How much camber would be needed to tuck the top of the wheel (not just the tread, the entire top of the wheel)? Would coilovers be 100% needed? Will I need rear lca's? And can anybody post photos of the ride height, with 100mm minimum clearance? I honestly have not been able to find any photos of our cars dead on that height.
Tranz is offline   Reply With Quote
Old 06-23-2014, 07:55 AM   #2426
Xafae
Xafae's Avatar
Drives: MAN 86 GTS Pegasus White
Hey guys,
I'm looking at getting some 18x9.5 +29 with 235/30-35 all round.
BC Racing (BR) coil overs.
Willing to go as low as I need, and as much camber as I need. Just curious. One of the other guys here has the same rims with +40, 255/35 and it looks wicked, but feels a little conservative.
Xafae is offline   Reply With Quote
Old 06-24-2014, 03:58 AM   #2427
Cards88
Drives: Monogram FRS ...soon?
I'm sorrry guys but I could only mostly find quotes about lowered cars but what would the recommended tires for 18x8 + 45 both front/rear for a stock height vehicle? (I would prefer close to flush...but more emphasis on practicality and not rubbing for now)
Cards88 is offline   Reply With Quote
Old 06-24-2014, 09:28 AM   #2428
Slick
Slick's Avatar
Those are pretty aggressive offsets.
Not sure we can help you but this crew might (or you can browse that thread for more info):
http://www.ft86club.com/forums/showt...25171&page=111
The Following User Says Thank You to Slick For This Useful Post:
Tranz (06-24-2014)
Old 06-24-2014, 09:55 AM   #2429
Slick
Slick's Avatar
Originally Posted by Xafae View Post
Hey guys,
Looks like you are going for the stretched look? 235/35 will be closer to stock diameter tire. 235/30 is too short (do they even make a 235/30R18?)
Above post may help you as well but you're a bit closer to normal offsets so you could make it work with extra camber. You have more inside clearance with the coilovers, but I'm guess-timating that you'll need at least -3 of camber to make those wheels fit.
You'll gain camber as you lower, so I would say choose the height you want and adjust camber from there.
Old 06-24-2014, 10:05 AM   #2430
Slick
Slick's Avatar
The ideal tire for an 8" wide wheel is a 225/40R18. Same diameter as stock and will be flush with your wheel (i.e. not stretched or too wide).
You shouldn't rub at stock height at all, but if you start lowering, the high wheel offset will put the rim closer to the strut.
It shouldn't get close enough to rub but if it does, you could just add a front spacer, like 3mm or so.
This will only be needed if you drop it ALOT (2"+), otherwise you will be fine either stock or lowered 1-1.5".
Old 06-24-2014, 11:26 AM   #2431
Amir Ghadiri
Amir Ghadiri's Avatar
Hey guys,
You'll need to be at or near the max negative camber the front top hats on the BC coilovers will allow.
You shouldn't have to make camber adjustments in the rear. Very very little if any, but I don't think it'll be necessary.
You'll need to roll your rear fenders.
Amir Ghadiri
Amir Ghadiri is offline   Reply With Quote
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
Slick (06-25-2014)
Old 06-24-2014, 11:35 AM   #2432
Yamaha_R6
Yamaha_R6's Avatar
Drives: V8 280Z || AP2 S2K
Currently on XXR 527s 18x8.75, +35, 235/40. Thinking of switching to XXR 522s 18x9.5, +38. Will the 235s be good on 9.5, or should I switch it up to 245s? Thanks!
Yamaha_R6 is offline   Reply With Quote
Old 06-25-2014, 06:00 PM   #2433
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I have a deal on two XXR 530 18x8.75 +20. I'm currently on stock height but planning to drop on 1'' springs with stock strut. Can they fit or too much poke ? Would they be better suited at the front or at the rear ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 06-28-2014, 06:25 PM   #2434
Jigglybus
Drives: fR-S
Hi... newbie here.
I think I've done a fair bit of research, but thought I'd post to double check.
Will this fit?
Stock suspension. 18x8.5-35 front, 18x9.5-42 rear, 245/35-18 all around.
It's a DD, and I never track or race at all. I like the 'meaty' look rather than stretched, and don't really want to lower it, as there are a fair amount of potholes/curbs on my regular route. I also would prefer a fair amount of sidewall in the interest of ride comfort.
Do you think I could use the same set up with 245/40's instead?
Jigglybus is offline   Reply With Quote
Old 06-29-2014, 11:05 AM   #2435
MPRESIV
Drives: Toyota GT86
Hi guys ,
My GT86 is currently stock but next month I'm going to get her a new set of wheels - Enkei RPF1 ( 18x9.5 ET38 ) + H&R lowering springs ( 25mm all-around )
Which tire setup should I choose: 245/35/18 square setup or 235/35/18 in the front and 255/35/18 in the rear ?
Yes , it's my daily driver but that doesn't matter , as I'm interested in the best street performance tire setup.I'm a fan of staggered setups on RWD cars ( loved the one I had on my previous BMW E90 ) but as far as I've read it doesn't quite benefit the GT86.
All suggestions are welcome.
Thanks in advance !
MPRESIV is offline   Reply With Quote
Old 06-30-2014, 06:20 PM   #2436
mush
mush's Avatar
hello. ill be needing new tires soon and want to go wider tires if possible this is my set up right now
swift spring 1inch drop, alignment to stock spec
18×8.5 +33 and 18×9.5 +40
225/40/18 and 255/35/18
the front wheel pokes out a little from the tire and the rear does too but less, i would rather have the tire flush with the wheel if possible
thanks!
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
