Old 06-23-2014, 12:09 AM   #6371
s2d4
s2d4's Avatar
OK, do what you want.
Seat belts be damned, street racing is awesome, "Beating" "victims" boost my ego and makes me cool, who cares about my own safety or any body else's.
It's not surprising how people can't take constructive criticism and choose to call names and dribble emotionally in retaliation due to bruised ego.
Old 06-23-2014, 01:54 AM   #6372
Thatruth2001
Drives: Raven FR-S
So after driving with the ESC for about 10 months now, I find myself fine "tuning" the engagement switch that sits under the throttle pedal. The most inconsistent aspects of installing the system from user to user is the ideal placement of this switch to engage the esc unit. I started playing with the android app torque earlier this evening to measure accelerator pedal input and throttle position with 4 following scales:
Absolute Throttle Position B
Accelerator Pedal Position D
Accelerator Pedal Positon E
Absoute Engine Load (Cannot Monitor input until engine started and road testing)
Turn on your car (without starting) then launch torque and load the above dials. Prior to doing anything else, while watching the screen apply pressure to the accelerator and monitor the % the pedal travels and absolute throttle % to the engagement switch "click" sound starting the unit. Take a note on the torque the reference of the pedal and throttle % locations, this your "HOME" location.
While under your steering column adjusting the flexible plate to bolt down the engagement switch move and bend accordingly then measure with the Torque app to reference the throttle and pedal engagement points. Currently my positions set are a little difference because I also installed a spacer to raise the engagement switch to more aggressive engagement position. The settings are:
72.9% - Throttle
40.4% - Pedal position.
While road testing the unit kicked in between 90-95% absolute engine load. Additionally, the unit kicks on more consistently to provide a more "integrated" feeling into the car's drive train for DD or back road fun.
I am intrigued if anyone else has come up with other ways to measure the relationship of pedal location and engagement for maximum enjoyment..... I so please speak up.
Thatruth2001 is offline   Reply With Quote
The Following 5 Users Say Thank You to Thatruth2001 For This Useful Post:
DAEMANO (06-23-2014), Gums (06-23-2014), keen as (06-23-2014), Namuna (10-02-2014), s2d4 (06-23-2014)
Old 06-23-2014, 03:02 AM   #6373
s2d4
s2d4's Avatar
Did you measure boost vs rpm after that? It may be smoother because it isn't producing as much as early?
Old 06-23-2014, 09:49 AM   #6374
Thatruth2001
Drives: Raven FR-S
No, those references in my opinion are too variable, because the car can still be driven without engaging the unit. Using this approach is purely related to pedal travel until engagement.
Old 06-23-2014, 10:11 AM   #6375
Jac
Drives: Fiat Abarth
Does this mean we should paint our compressors black? May help reduce intake temps.
Anyone want to test it?
http://www.carthrottle.com/painting-...-engine-happy/
Phantom Supercharged BRZ | 205WHP / 185WTQ
Nameless FP/OP Combo
Jac is offline   Reply With Quote
Old 06-23-2014, 11:35 AM   #6376
Jonsey
Jonsey's Avatar
I imagine the gains would be negligeble since, unlike an intercooler, the supercharger is not designed to transfer heat. The surface area for the radiation to escape is rather small compared to the volume of air moving through it and the wall thickness is substantially greater than an intercooler, which will also inhibit transfer. With that said, painting it black likely wouldn't hurt anything.
Jonsey is offline   Reply With Quote
Old 06-24-2014, 10:21 PM   #6377
jflogerzi
jflogerzi's Avatar
@fenton Do we have any idea on when in july the next batch will be ready?
Old 06-24-2014, 10:26 PM   #6378
fenton
It will be ready at the end of July. Once Rob has solid dates on when all the parts will arrive he may be able to give a closer date.
Needless to say if it is within his power he will always do his best to make the date.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
jflogerzi (06-24-2014)
Old 06-24-2014, 11:10 PM   #6379
keen as
keen as's Avatar
Drives: 86 GT MT
Time for a bit more praise!!
I like to think the Phantom has F1 engine technology. Look at the "compressor" and "MGU-H" in the diagram. It is connected by a shaft to the turbo to eliminate lag. (It also has second job while turbo boost is high, it can generate electricity). Imagine the current required!!!http://www.formula1.com/news/technic.../923/1197.html
keen as is offline   Reply With Quote
The Following 2 Users Say Thank You to keen as For This Useful Post:
DAEMANO (06-24-2014), Gums (06-26-2014)
Old 06-25-2014, 05:22 AM   #6380
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
This might be a stupid question, but would it be possible to turn off the system that reduces lag? I know this would not be a good idea on a dd, but I was thinking it might help those who are using it on a track. Don't need it spinning that turbo on deceleration, for example. Would probably be more beneficial to them if it were recharging at full speed. Just a thought, sorry if it has already been discussed. Been trying to keep up with this thread, but it's huge!
Sent from my XT1053 using Tapatalk
xxBrun0xx is offline   Reply With Quote
Old 06-25-2014, 06:16 AM   #6381
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I do not think that the compressor motor is being powered under decel. The compressor should not restrict air enough to cause the drag reduction to kick in, but maybe someone else has actual experience to back it up instead of theory.
Target70 is offline   Reply With Quote
Old 06-25-2014, 09:01 AM   #6382
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Target70 View Post
Jesus never used force against anyone.
I think the money lenders might disagree with you.
In fact when it came to the stoning of the prostitute, which was the legal punishment for her crime, he effectively went against the law by saying "he who is without sin, cast the first stone". Assuming he knew the outcome of this action, It shows that he believed it was wrong to punish someone for committing a crime against themselves or sinning against God, just because the law wants to legislate morality.
Jesus was an unemployed carpenter. He probably figured she had skills it would be a crime to lose.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 06-25-2014, 09:04 AM   #6383
mid_life_crisis
Originally Posted by Jac View Post
Which makes sense considering its low RPM instatorque benefits, and probably better (less complexity/less fuel) than using a belt-driven supercharger for twin charging.
Selfishly, I'm interested in this tech going mainstream so folks don't look at me sideways when i say I've got an electric supercharger and automatically assume I've been duped.
Originally Posted by fenton View Post
Takes a while to figure out how to deal with those people. I start of by saying it is super charged. The system used the cold side of turbo just like vortech however instead of being driven by a belt it is powered by a electric motor that draws 4.5kw from a discrete 24v battery bank.
when people see it in the engine bay you can tell that it is the real deal.
Just show them how fast it is. Nothing more convincing than results.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
DAEMANO (06-25-2014)
Old 06-25-2014, 09:25 AM   #6384
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
This. I took a couple of the skeptics for a ride yesterday and they couldn't believe I got that much for that price point.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
