Old 06-21-2014, 11:15 AM   #1597
NCItaly
Drives: 2013 BRZ Limited
Just noticed this one yesterday. But it wasn't there at the end of the day...
[ame]http://youtu.be/OoLo3712hC4[/ame]
NCItaly is offline   Reply With Quote
The Following User Says Thank You to NCItaly For This Useful Post:
D-VO (06-22-2014)
Old 06-21-2014, 11:57 AM   #1598
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by zERoTu View Post
the charger wine is fine, its high pitched and is normal. the noise im referring to is the whistle echoing noise as i give it gas. it happens around 3-4k rpm with load. as im going faster, the noise isnt there. so i dont think its the wind???
New noise now!!! FML sounds like a pulley or belt.
It is the belt. If I remember correctly when I had that when my belt tension is bit too much. Try adjusting your belt tension it should clear the noise easily.
Also using a cogged pulley the 21mm (recommended) between the plate and under the bolt would be too loose and will give you a lot of belt wobble/play. It will need a bit more based on my experience in installing the kit.
BTW: The more tension the more whine, so play with the tension a little bit until you hit your sweet spot.
zoth is offline   Reply With Quote
Old 06-21-2014, 12:12 PM   #1599
zERoTu
Drives: 1st RBv2 10 Series FRS
Thx I'll give that a try, I'm using the smooth idler pulleys. Cogged ones have yet to come in.
zERoTu is offline   Reply With Quote
Old 06-21-2014, 01:10 PM   #1600
zoth
zoth's Avatar
Remember you have to loosen the idler pulley next to the tensioner to adjust the tension and bolt down everything to specs again when done.
I think this applies to @NCItaly as well...
The Following 2 Users Say Thank You to zoth For This Useful Post:
NCItaly (06-21-2014), zERoTu (06-21-2014)
Old 06-21-2014, 03:35 PM   #1601
noob001
Drives: frs
normal?
Can someone tell me if this sound normal?
[ame]http://youtu.be/C7EoFF5z7vo[/ame]
noob001 is offline   Reply With Quote
The Following User Says Thank You to noob001 For This Useful Post:
D-VO (06-22-2014)
Old 06-21-2014, 03:39 PM   #1602
NCItaly
Your video is set to private
Old 06-21-2014, 03:46 PM   #1603
noob001
Drives: frs
what about now? I think i forgot to hit publish
Old 06-21-2014, 03:53 PM   #1604
zERoTu
All of it sounds the same
Old 06-21-2014, 05:19 PM   #1605
zoth
zoth's Avatar
Check your belt tension guys... sounds a little too much tension. And make sure that the cogged belt does not bounce to much up and down.
Correction if the belt moves to much then you have to add more tension and that sound will go away as well.
Old 06-21-2014, 05:27 PM   #1606
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
That's what I thought too since the first time I had a similar noise, the tension was not enough (belt was a bit loose) once the tension bolt is set to ~21mm it should go away
glamcem is offline   Reply With Quote
Old 06-22-2014, 01:27 AM   #1607
D-VO
Drives: Whiteout FR-S, Evo 8 RS
@NCItaly and @noob001
Mine sounds exactly like that. I'm gonna loosen the belt tomorrow for the ride to work to see what happens.
D-VO is offline   Reply With Quote
Old 06-22-2014, 02:31 AM   #1608
zERoTu
Kraftwerks Supercharger Owners Thread
Mine was set to 22mm with smooth pulley. Set it to 21mm spec, still has same noise. Should I tighten more ??, the belt does not move at all.
Old 06-22-2014, 02:33 AM   #1609
SPCorBUST
SPCorBUST's Avatar
Would wait for @KraftWerks to chime in on that so there aren't any warranty issues...
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
glamcem (06-22-2014)
Old 06-22-2014, 04:17 PM   #1610
zoth
zoth's Avatar
Compare the flex with the serpentine OE belt and go from there. There should be some flex but not to much.
Also have you re-check the torque on all the idler pulley's.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
